#5076 |
Member#: 41097
SCIC
Vehicle:2005 WRX Aspen White |
Yes, it's the one by the battery with the brown and black plugs. Both are missing.
#5077 | |
Member#: 175334
TXIC
Vehicle:2003 Impreza WRX JDM v8 EJ207 WRB |
http://www.iaperformance.com/product...oducts_id=3217 ... it is different from their AVCS bulkhead wiring kit, which most people need to wire up their ECUs. |
#5078 | |
Member#: 41097
SCIC
#5079 | |
Member#: 56203
Vehicle:00 RSTI Coupe |
After a quick search I saw one lap in a Suzuki Swift Sport was 99 euro and it goes up from there. |
#5080 |
Member#: 856
International
Vehicle:2005 JDM STi Black |
#5081 |
Member#: 56203
Ooo. I thought that was the price of renting/running a STI down the track...lol
That makes alot more sense and seems reasonable |
#5082 |
Member#: 203011
Vehicle:02 Impreza WRX Flat Black Viny Wrap |
Nice "My Cousin Vinny" reference
#5083 |
Member#: 856
International
#5084 | |
Member#: 107170
Vehicle:2002 ver 7 EJ207 WRX WRB |
Jeff |
#5085 | |
Member#: 287080
TXIC
Vehicle:2004 WRX PSM |
Just remove the pwr steering, alt, and ac then use wrenches. |
#5086 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
#5087 |
Member#: 197062
Vehicle:1998 Swapped Impreza black |
There are 3 or 4 hard to get to bolts under the manifold that connect the fuel hard lines and their plastic shielding. Having done it once I wouldn't hesitate to do it again, but its definitely not as simple as the 8 bolts you can see from the top.
#5088 | |
Member#: 191495
Vehicle:'05 WRB GTX3071R JDM V8 EJ207 USDM 6MT |
I wouldn't remove the rails without pulling the Mani unless I was wrecking them but the harness can be done |
#5089 | |
Member#: 59837
SWIC
#5090 |
Member#: 197062
#5091 |
Member#: 107170
If you've pulled the manifold off once, it gets easier everytime. Yes, there are the "easy" bolts, and then there are the bolts that hold the plastic harness rail to the manifold underneath. What I was trying to get at was that, if you need to replace the harness, why not pull the manifold off and do some things (e.g. swap turbo inlet, and the fuel rail if you're encountering the smelly raw fuel issue, which I have) while you're at it.
And to lukeskywrx, isn't that the ver. 8 manifold with the long runners? If it is, you're lucky enough to not have to remove the TGV deletes like most of us ![]() Back to the OP regarding the cut harness, I think your best bet is to switch the WRX harness over, get a AVCS harness, and add/repin according to the DS1 instructions if you're not getting the IA Performance wiring kit. -Jeff |
#5092 |
Member#: 79643
Vehicle:04 EJ207 Swapped Mikey tuned 271whp/287wtq |
So here's where I'm at with my swap.
04 wrx V8 ej207 Jdm ecu Currently no avcs Engine starts but idles at ~2100 Engine won't rev past 3000 Unplugging the MAF stalls the engine. Cleaned the MAF because it was nasty, idles smoother but no change. Could this be due to the JDM ecu and no AVCS? If you have any ideas while I search through the thread they'd be appreciated. |
#5093 | ||
Member#: 59837
SWIC
No AVCS is going to trigger a bunch of trouble codes, is your CEL on? If so you are pry in safemode.
Also is your IACV OK? they tend to break in shipping so you might want to try your WRX one. Try your WRX ECU and see if it is better once you check the IACV. Quote:
It is the V9 spec-C manifold, same thing as the v8. I don't mind pulling the manifold, I run e85 so I get the delicious raw ethanol smell ![]() Quote:
#5094 |
Member#: 287080
TXIC
#5095 |
Member#: 291949
Is the mouth of the V8/V9 DP cast iron? It looks rather beefy in the few pics I could find. Also, is the mouth of the DP split to separate exhaust gases and waste-gate flow?
Just curious as to how well subaru designed their DP to help spool |
#5096 | |
Member#: 59837
SWIC
![]() Last edited by lukeskywrx; 12-12-2012 at 12:47 PM. |
#5097 |
Member#: 79643
After some research it does sound like AVCS induced limp mode (CEL is on)
We're working on wiring up the harness now. Thanks |
#5098 |
Member#: 110078
Vehicle:2005 92x - 02 wrx silver 92x-wrb bugeye wag |
Sounds like a bad IAC, lack of avcs won't do what you are describing, I'm able to drive my car with avcs disconnected on a v8 ecu, check engine light on from avcs sensors. Put the IAC from your wrx engine in, try it.
#5099 |
Member#: 59837
SWIC
But would the IACV keep the motor from revving past 3k?
#5100 |
Member#: 79643
We're sorting out the AVCS right now anyway. I also swapped over the WRX IAC with a new gasket. I'll update with changes shortly
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
