#26 |
Member#: 317988
Vehicle:07 WRX wag Black |
#27 |
Member#: 317988
If the intake caused that much problem, it would have thrown a CEL and possibly gone into limp mode (limp mode limits boost psi) but it hasn't.
#28 | |
Member#: 133597
SCIC
OP, check the BCS or if you don't feel comfortable take it somewhere. You can't rule it out until you test it. |
#29 |
Member#: 337197
Take intercooler off and look into the inlet(part that bolts to turbo). My engine and turbo blew and plugged up the intercooler. No boost on the outlet of intercooler but lots before it. That's where I would start looking its an easy part to get off. I was able to clean mine out and it had full boost again
#30 |
Member#: 177891
Tri-State
Vehicle:06 wrx wagon child seat/tow hitch cgm |
is the wastegate stuck wide open???
#31 | |
Member#: 249219
SCIC
Vehicle:2007 WRX TR World Rally Blue |
Ummm, im not too sure if it has a stock down pipe? As for the butt dyno it pulls but not as hard as I think it should... |
#32 |
Member#: 249219
SCIC
Sorry guys ive been working my ass off lately! I am going to check for the restricor pill first thing tomorrow morning.
#33 |
Member#: 319017
Vehicle:2005 SAABARU 18g xt JDM 6 speed |
#34 |
Member#: 177891
Tri-State
on a side, are you sure the exhaust is 5in? or is just the muffler tip 5?
to find the diameter of the piping without taking it off, get measuring tape around the exhaust pipe and divide that measurement by Pi(3.14). also from the pics, that looks like the stock heat shielding for the stock dp. |
#35 |
Member#: 249219
SCIC
OK so... I checked the vac line and no restricter pill.
#36 | |
Member#: 249219
SCIC
OK so it is a 3" exhaust with a 5" tip. |
#37 |
Member#: 324808
E. Canada
Vehicle:2006 IWL Stg2 OBP |
dont make the same mistake previous owner did. buy a stock intake/cobb accessport/pill restrictor. put stock intake and restrictor pill, flash to stock tune then eventually to stage 1, using octane 91 always, occasionaly do drive bit hard to heat up and seal the piston rings and do proper break in process on new engine(lucky), down the road, a turboback exhaust(bellmouth downpipe included) and go for stage 2 and tune because of the SPT intake. I cant wait to have my st2 mode on soon!
#38 |
Member#: 249219
SCIC
Well... I installed the restrictor pill and I do notice a little more power and I can hear the turbo spool up a lot quicker but my boost gauge is only showing about 8psi now. I am going to get some new vac lines today... Anyone know of a tuning shop in the San Diego area? And how much does a basic stock map install go for?
#39 |
Member#: 324808
E. Canada
#40 |
Member#: 330625
NESIC
Vehicle:2006 WRX WRB |
