Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 12-10-2012, 04:11 PM   #1
GraverD
Member#: 94137
2002 Legacy "STi"
Silverstone Metalic
Default Odd question: Timing Belt or Build Shortblock?
Right now I have an STi shortblock with stock internals at around 110k miles and I think I may be on borrowed time with the timing belt. With the current tune it dynod at 330whp and 320 torque which may be on the high end for stock internals so here is my question.
I have a new ej257 shortblock in my garage. Instead of doing the timing belt on my current engine would it be more cost efficient to build the new shortblock with stronger internals and swap that in with a new timing belt? My worry is that I will pay for the timing belt and risk something else happening because the shortblock already has high mileage.
Am I being paranoid and stupid?
GraverD is offline   Reply With Quote
Old 12-10-2012, 04:35 PM   #2
04ScoobyWtf
Member#: 287974
If the belt breaks you'll belt a valve and have to spend more on new heads. Install the shortblock with the new timing belt have the heads refreshed and call it a done deal. And you won't have to worry.
Just my .02
04ScoobyWtf is offline   Reply With Quote
Old 12-10-2012, 04:41 PM   #3
GraverD
Member#: 94137
2002 Legacy "STi"
Silverstone Metalic
Just my .02
Thats exactly how I felt, now how much do I put into the new block?
Also does anyone know what an 100k mile ej257 shortblock with the internals would go for? I imagine I can probably cut a lot of the costs if I do a compression test and sell the old built shortblock.
Old 12-10-2012, 06:22 PM   #4
04ScoobyWtf
Member#: 287974
Get comp numbers but I'm guessing like 650-800 depending on compression
Old 12-10-2012, 06:25 PM   #5
GraverD
Member#: 94137
2002 Legacy "STi"
Silverstone Metalic
good to know, I will run a compression test before pulling it
Old 12-11-2012, 09:11 AM   #6
GraverD
Member#: 94137
2002 Legacy "STi"
Silverstone Metalic
any other feedback? What would a job like this cost assuming I had the parts? Assembly, re-surfacing heads, swapping
Old 12-11-2012, 09:31 AM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I would base it more on compression numbers over that of miles on the motor. If you think you're living on borrowed time, do the timing belt. If you have the money then build a block.
Old 12-11-2012, 09:47 AM   #8
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Do a leak down, and see what the overall health of the motor is.
Then go from there.
Honestly I would replace the t-belt and pulleys, if the numbers come back good.
No sense in tearing it apart if everything checks out. Unless you have disposable income.
My . 02
-Phil @ F4M
Flat 4 Motorsport is online now   Reply With Quote
Old 12-11-2012, 09:53 AM   #9
GraverD
Member#: 94137
2002 Legacy "STi"
Silverstone Metalic
Thanks, after a good sleep and talk to the wife I came to the same conclusion. I am waiting to see the shops estimate and then I will do a leak down and compression test. If those come out ok I will just get the belt taken care of.
Thanks for all the input
Old 12-11-2012, 10:17 AM   #10
04ScoobyWtf
Member#: 287974
Alldata call for around 19 hours and 19 x 100 (labor hour) is 1900 in just labor and I'd say 300-500 on head refreshing gasket kit 250. Timing but 270. Misc oils and gaskets 200.
There's 3400 before the internals
Old 12-30-2012, 08:37 PM   #11
Grippen
Member#: 329712
2005 Sti
Uea thats crazy. Just do it yourself if you have any knowledge about it. If not search for meaty's thread!
Grippen is offline   Reply With Quote
Old 12-30-2012, 09:54 PM   #12
cowboy_Rob
Member#: 194062
2003 Impreza WRX
just do the timing belt. if you know someone with the right tools its not even an afternoon job
cowboy_Rob is offline   Reply With Quote
