Old 09-23-2012, 03:19 PM   #51
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
Originally Posted by Angelus911
Just to chime in, I checked my Impreza with about 5700 miles on it, and noticed my coolant was almost at the low line as well! I had an oil change at 2800 miles, so I assume they would have checked it then. In any case, thats a decent amount consumed in under 6000 miles:
Is it worth it to bring to the dealership, or should I just buy coolant and top it off myself?
My coolant level looks like yours when cool but right at the full line when hot. I am at 5100 miles.
subypete is offline   Reply With Quote
Old 09-23-2012, 03:55 PM   #52
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Mine looks like that when my engine is cold too. I always check my fluids when my engine is cold (mainly because it's easier to read the oil dipstick), so I'm not sure where the coolant level is when it's hot.
sgoldste01 is online now   Reply With Quote
Old 09-25-2012, 06:05 PM   #53
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, I just checked mine after driving home from work. When the engine is hot, my coolant level falls perfectly on the FULL line. So what you showed in your picture is my cold level, and the FULL line is my hot level.
Old 09-25-2012, 08:10 PM   #54
Angelus911
Member#: 89967
2012 Impreza Sport
Ok, good to know, I guess that's normal then!
Angelus911 is online now   Reply With Quote
Old 09-26-2012, 12:16 AM   #55
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Right after driving home from work, I had a look and my coolant is over the full mark. It basically is level with the top of the "FULL" lettering.
Old 09-26-2012, 04:54 PM   #56
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Is this with the engine cold? (Like first thing in the morning cold?)
jay25RS is offline   Reply With Quote
Old 09-26-2012, 05:22 PM   #57
ocellaris
Member#: 302559
I am in the "it still has plenty of coolant if the heater is working" school of thought about this.
ocellaris is offline   Reply With Quote
Old 09-28-2012, 07:30 PM   #58
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Does anyone know what could cause the smell of antifreeze that isn't antifreeze? I smell it all the time, but after the car is warmed up the coolant is always at the full mark, right on.
goregasm is offline   Reply With Quote
Old 09-29-2012, 09:20 AM   #59
jay25RS
Member#: 4273
2011 GR-STI
Might be cosmoline. Used to be a popular topic that was posted about even pre USDM arrival of the WRX back in the 2.5rs days. It was a coating on the engine that smelled unique.
Old 12-10-2012, 02:41 PM   #60
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Well, I finally brought my car in to check on this issue. My car has lost the amount of coolant represented by the full and low marks (confirmed when cold or hot) In a Span pf about 400i. They ran a pressure test and also shows me a full visual inspection including having the car on the lift and taking th undercover off. Sigh. At lest they did it all with good faith diligence. Guess they will too it off and I'm glad it's in the system for now in case this gets worse as time goes on.
Old 12-10-2012, 03:05 PM   #61
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I wonder if it would be worth submitting an oil sample for a Used Oil Analysis, to see if there's coolant in your oil.
Old 12-10-2012, 04:04 PM   #62
nubsub
Member#: 313575
Hmmmm. Interesting suggestion. If this persists I may do that. Ill be changing my oil in the next couple of weeks and see I'd anything is notable by eye. I did have a head gasket leak on an old car way back when where that was happening.
Old 12-10-2012, 04:36 PM   #63
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Just an FYI if you decide to pursue this further, you can order a free UOA kit from Blackstone Labs, and only pay if you decide to send in a sample. You might want to order the kit now so that you'll have it in a couple of weeks, if you want to use it.
http://www.blackstone-labs.com/
Old 12-10-2012, 10:48 PM   #64
nubsub
Member#: 313575
good idea: thanks!
Message Board Statistics All times are GMT -4. The time now is 08:49 AM.
