Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 02-27-2012, 01:26 AM   #1
MikeyMeyagi
Member#: 231209
1994 Legacy Wagon Mi
Matador Red Mica
Default My 2.2 n/a-turbo. all stock parts, 213awhp.
figured id share my setup i built for my winter beater, i built it out of spare parts i had laying around. my total cost to build this car was <$100 including the shell.
its a 93 impreza wagon 5mt.
Motor:
2.2 n/a block w 150k on it
2.5 sohc heads
^^ this combo produces ~8:1 comp ratio, SAFE for boost!
2.5 sohc intake mani
92 legacy turbo throttle body and tps. (No iac due to the 2.5sohc TB being wrong for the ecu and the leg turbo TB not having one on it. fast idle is acheived with a emmisions VSV and a toggle switch.)
wrx manifolds/crossover/uppipe w hollow cat
VF39
custom inlet tube made from exh pipe and DSM intercooler hose
wrx top mount, with custom y pipe made from the stock plastic one/DSM hose
440cc wrx injectors
92 legacy SS ecu pinned into factory 1.8 harness (simple and works awesome)
apexi afc to scale for injectors
outback 2.5 clutch
3" dp, to 3" home made catback
techedge wideband.
Notes:
car is currently running 8psi of boost. i have no doubts this setup would handle 10-15psi no problem, but unfortunatly the turbo legacy Hitachi maf sensor is maxed out at 8psi. the outback clutch slips sometimes in 3rd gear, i have a better one, just havent installed it.
the iac situation is mickey mouse. i had a phase2 2.2 TB on it originally, but the ecu didnt like that tps, and the Tleg tps wouldnt fit the newer TB. if the temp is above 40-50deg, it starts and idles no problem. below that, the fast idle switch is needed. not a big deal, just annoying.
This build is the result of me putting my STi swapped 94 legacy away for thge winter and not wanting to drive a n/a car, or a nice car that id care if it got smashed up.
Question reliability? I have beat the absolute crap out of this thing, drifting in the snow, sliding around a lake in 3rd on rev limit for 4-5 hours, and taken plenty of decent trips. it runs perfect.
Want proof? Here you go, this was on a land&sea Dynomite at Kinetic motorworks in NH (stock sti puts down 225awhp on this dyno)
dyno vid
heres a pic of the motor
there is alot of mickey moused hackery on this thing, mostly because i didnt really care. it was an experiment, and i wanted to have next to nothing in the project. bottom line is, it works, makes power, and has proven reliable. Winning in my book
enjoy
-Meyagi
MikeyMeyagi is offline   Reply With Quote
Old 02-27-2012, 03:42 AM   #2
kevinb721
Member#: 188314
wrb
seriously, winning. awesome build
kevinb721 is offline   Reply With Quote
Old 02-28-2012, 11:09 AM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
I love seeing old rusty Subbie engines bays that are still kicking ass! I bet your car is fasted than most turbo subbies 15 years newer lol. What crank did you use the EJ22 crank ?
GEE-OTTO is offline   Reply With Quote
Old 02-28-2012, 01:53 PM   #4
MikeyMeyagi
Member#: 231209
Matador Red Mica
thanks! the block is a completely stock 94 ej22e with 150k on it. Yeah, its pretty quick. stays right with/beats much newer cars. i ran my buddies stock '11 wrx and we were dead even up to 70mph
Old 02-29-2012, 01:12 PM   #5
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
Very nice build. i spent a bit more money, made 200whp/210wtq with my 1.8 and td04 although its fwd
you should enter that in Grassroots $2012 challenge!
imprezaL2345 is offline   Reply With Quote
Old 03-01-2012, 01:06 PM   #6
amoore131
Member#: 222708
Going to be doing this exact build this summer, already have my heads, turbo, pipes, etc. using my stock PI ej22 shortblock. I'll be using my stock EJ22 ECU and apexi SAFC
Couple of questions:
Are you using the EJ251 cam gear or ej22e one and sensor?
I saw you tried using a PII ej22 TB but what about the stock PI TB on the 2.5 IM?
Would my stock MAF sensor max out if I ran more than 8psi of boost even with the SAFC?
Any issues with knock?
Did you use the OEM EJ22 head gaskets?
EDIT: Re-read so I'm assuming you are using a turbo/notched xmember?
amoore131 is offline   Reply With Quote
Old 03-02-2012, 03:21 PM   #7
Its_Stevoh
Member#: 209765
sell me this
Its_Stevoh is offline   Reply With Quote
Old 03-02-2012, 11:50 PM   #8
Swimfan_LGT
Member#: 310548
1997 Legacy
Red
My friend "granny" is almost done his turbo build, ill have him post his build thread so maybe it will answer some of your questions. Car looks good. What ECU did you use?
Swimfan_LGT is offline   Reply With Quote
Old 03-03-2012, 02:38 AM   #9
MikeyMeyagi
Member#: 231209
Matador Red Mica
ej22 cam gear, sensors are the same
im using the 92 legacy turbo TB on the PII manifold. i had to make a block off plate for the iac port though on the manifold.
No. the plastic JECS maf can read enough airflow for 18-19psi on a VF turbo.
The turbo legacy metal Hitachi maf has a much lower reading ability
i havent tried to run more boost and scale it with my afc, due to the simple fact that it works fine the way it is and i dont feel like messing with it.
none that im aware of, i have no way to monitor it, but if it had knock issues, it would have blown up long ago after the abuse ive put this motor through.
i used ej251 head gaskets from napa.
yes, notched Xmember. swapping that out for a turbo one was more effort then i wanted to put into this car.
Im using a 92 legacy turbo hitachi ecu.
as far as selling, make an offer. id rather keep it for next winter though.
Old 03-04-2012, 01:44 PM   #10
bbron12
Member#: 312440
GC's GC Swap, BRAT
i really like the car! total sleeper!
bbron12 is offline   Reply With Quote
Old 03-05-2012, 01:06 AM   #11
amoore131
Member#: 222708
Okay thanks. Seems like all the answers I was hoping for. One thing I was wondering was that you said you used the ej251 HG but I've read that you always want to use the hg for the block you are using? (i.e. EJ22 gasket)
Im assuming this is working fine for you but what is your take on this?
Old 03-06-2012, 11:48 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You can get a little more power/boost out of it with the current MAF with my MacGyver setup. It works best with slightly larger injectors but can be used with the stock ones. I assume you have a fuel cut defender already?
Put pipe elbow into the intake after the filter but before the maf. Have a short piece of hose with a ballco-ck valve and plumb that back into the intake after the maf but before the turbo. This is now a controlled amount of unmetered air. Watch the air fuel ratios at WOT and open this ballco-ck to the point that the AF is still safe. This will have to be balanced to the larger injectors so that the closed loop fueling is still within the ECU's fuel additive range.
Edit: lol nasioc is censoring ballco-ck
ciper is offline   Reply With Quote
Old 03-07-2012, 12:10 AM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Kudos to your setup and thanks for providing the dyno numbers.
Haven't thought about doing anything to my Outback Sport but this......this is nice. I'm particularly interested in the 440cc WRX injectors and the 2.5 sohc heads. I think that is all I need now. Probably will PM you for some more info.
Again....cool setup.
Kevin Thomas is offline   Reply With Quote
Old 07-25-2012, 12:30 AM   #14
SoupedSuby
Member#: 327104
2006 WRX Wagon
Hello all, I'm Cam and I'm new to the world of Suby's and to forums, so forgive me if I'm trying to restart too old a post.
On that note, I was wondering why you chose the lower compression heads. I was under the impression that the higher compression and boost was why a turboed ej22 was a bit more potent? Or is that why you're not able to boost the 2.2's too much? Thanks in advanced, I'd like to slap a turbo in the 96 Impreza I just purchased so it'd clear some things up.
SoupedSuby is offline   Reply With Quote
Old 12-08-2012, 11:54 AM   #15
MikeyMeyagi
Member#: 231209
Matador Red Mica
car recently got a little makeover.
still running the same setup, zero issues, 100% fun
total cost of car, less then $400 everything included. looks i get driving around, priceless.
Old 12-10-2012, 03:51 PM   #16
gc22Jake
Member#: 339131
this thing is ****in sick man, good job. I really want to do this with my $500 93 L sedan.
Just dropped a 120k ej22 in and this is just tits.
gc22Jake is offline   Reply With Quote
Old 12-10-2012, 04:57 PM   #17
gc22Jake
Member#: 339131
would i resolve the problems you ran into with the 2.5 intake manifold by using my stock 2.2 intake manifold parts?
Old 12-12-2012, 03:22 PM   #18
tunedbysti
Member#: 334146
1998 Honda Accord LX
2000 Chevy Silverado 1500
WOW! That's a truly amazing build.
tunedbysti is offline   Reply With Quote
Old 12-16-2012, 08:19 PM   #19
Storm
Member#: 5218
96L Most Over-
Developed Beater
This is what it's all about (to me). Low cost fun using good ol' ingenuity instead of spending metric tons of money on shiny stuff to get the same result.....
ROCK ON!!!!
Jay
Old 12-18-2012, 12:26 PM   #20
Kevin Thomas
Member#: 110
1989 1989 XT6
Any recent pics of the motor and rest of setup? That pic isn't showing for some reason. This is for the late comers. Again, congrats on a nice setup.
Old 12-18-2012, 12:42 PM   #21
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
This.Rules.SO.HARD.
Dislike paint -- but thats just opinion. Very well done!
gdoggmoney is offline   Reply With Quote
Old 02-01-2014, 07:00 PM   #22
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Reviving this from the dead. I really wanna do this now haha
FastAdams is offline   Reply With Quote
Old 02-11-2014, 01:14 PM   #23
Austs91Leggy
Member#: 380695
1991 Subaru Legacy
Im goin to do this to my 22e with only 110xxx miles
Austs91Leggy is offline   Reply With Quote
Old 02-12-2014, 02:14 PM   #24
wheelerboy12
Member#: 381487
I'm also using this build as some inspiration for mine, I'm going to use a 22e bottom with STI rods and pistons, and 25d heads with upgraded valve springs and cams with an 06 STI vf39 turbo.
I'm hoping to hit around 350awhp.
Good luck with your build!
wheelerboy12 is offline   Reply With Quote
Old 02-13-2014, 10:10 PM   #25
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Sounds fun. There are no STI pistons that fit the ej22. You will have to go aftermarket.
geronimo81 is offline   Reply With Quote
FS : **SOLD ** 2005 OBP STi, orig 39K miles, AP Stage 2 + all stock parts...just smogged! MaxSTi05 Private Vehicle 'For Sale' Classifieds 8 09-15-2011 08:44 PM
FS : 2005 OBP Sti, only 39K miles, Stage 2 + all stock parts, just smogged! MaxSTi05 SCIC Private Classifieds 1 09-08-2011 07:24 PM
FS : MD - Huge part out, wrx, 2.5rs, obs performance and stock parts gren737 MAIC Private Classifieds 27 03-16-2011 12:20 PM
FS: all stock parts .. need to make room and money iloveturbos Bay Area Impreza Club Forum -- BAIC 2 09-08-2003 04:19 PM
Yellow wrx w/all stock parts+hid banjo Vancouver Impreza Club Forum -- VIC 5 05-03-2003 10:16 PM
