Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 12-10-2012, 12:46 PM   #1
Dran1341
Member#: 290186
04 WRX
Default Help!!!
I'm at the Ampm on garden grove blvd and haster. Can someone meet me here? To diagnose why my car won't start.
I'm not sure but maybe my starter?
Dran1341 is offline   Reply With Quote
Old 12-10-2012, 12:55 PM   #2
Dran1341
Member#: 290186
04 WRX
When I crank it, it sounds like a weird spinning sound? If that makes sense
If anyone could even maybe walk me through it over the phone? My number is 5628331626
Old 12-10-2012, 01:15 PM   #3
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
Really hard to describe something over the phone what was the occurrence?
EPlascencia60 is offline   Reply With Quote
Old 12-10-2012, 01:16 PM   #4
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
Starter solenoid is a possibility, you can beat on it or push start
Old 12-10-2012, 01:18 PM   #5
Dran1341
Member#: 290186
04 WRX
Won't start. I pulled into the gas station to get gas. When I got back in and try to crank, it makes a spinning sound?? Is the best way I could describe it. It seems like there is no resistance( like not turning the flywheel or something)
Old 12-10-2012, 01:25 PM   #6
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
All I can recommend at this point is push start it and get it home/shop. It does sound like a starter problem, battery terminals on properly? Any tampering of electrical components?
Old 12-10-2012, 01:26 PM   #7
Dran1341
Member#: 290186
04 WRX
No,terminals are good and didn't mess with anything electrical. car started and ran fine earlier this morning. Anyone in the area that can help a brother out? I got a final in 2 hours
Old 12-10-2012, 01:42 PM   #8
EPlascencia60
Member#: 254170
1997 Legacy GT
GW- Socal F4 #46
Sorry I'm over 2 hours away. Good luck.
Old 12-10-2012, 01:55 PM   #9
Dran1341
Member#: 290186
04 WRX
Not a problem, tow trunk is on the way with the tow. Anybody want to help me diagnose the issue later on in the week?
Old 12-10-2012, 02:22 PM   #10
highwayman
Member#: 100697
06 STI
CGM
From your description, sounds like a timing belt issue and no compression.
highwayman is offline   Reply With Quote
Old 12-10-2012, 03:03 PM   #11
Dran1341
Member#: 290186
04 WRX
I hope not, car ran fine before I stopped and got gas.
Old 12-10-2012, 03:15 PM   #12
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
Probably a starter issue. The starter gear is Probaly not getting pushed out and engaged
And it wouldn't be a timing belt issue of the car ran fine before.
thisisthenewsic is online now   Reply With Quote
Old 12-10-2012, 03:21 PM   #13
highwayman
Member#: 100697
06 STI
CGM
First thing to confirm is with the hood opened is the motor spinning when u try to start? If so you have bigger issues. If not a check of the starter/battery is next.
And yes, I've had vehicles towed in with skipped timing belts, in the same situations as the op posted.
Old 12-10-2012, 07:46 PM   #14
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
Sounds like starter is not engaging or busted timing belt.
Like some one said are your accessory pulleys turning. ( like alternator, power steering) ?
bubba03wrx is offline   Reply With Quote
Old 12-11-2012, 12:17 AM   #15
Dran1341
Member#: 290186
04 WRX
Hey guys, I was able to push start the car with ease but as soon as I got home and shut the car off. Does the same thing. I will check tomorrow if the engine spins when I crank it.
Old 12-11-2012, 01:57 AM   #16
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
starter...
you can try hitting the back of the starter solenoid with a hammer, they stick sometimes...it's an old school thing, but then again...you should just replace it and do it right
get a a subaru part...not a napa or other no-name, that stuff is okay for a chevy or ford small block
rubrduk is offline   Reply With Quote
Old 12-11-2012, 03:32 AM   #17
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
Check your battery then go from there.
HighRevimpreza is offline   Reply With Quote
Old 12-14-2012, 01:05 AM   #18
Dran1341
Member#: 290186
04 WRX
I found out what my problem was!! How the hell this happened? Beats me???
Old 12-14-2012, 01:27 AM   #19
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
^^ ouch, knew it had to be the starter.....and ive never heard of that happening on a subie before but atleast its an easy fix......
Old 12-14-2012, 01:54 AM   #20
Dran1341
Member#: 290186
04 WRX
Do you have to do anything special to align the teeth or just put it in? Lol
Old 12-14-2012, 02:50 AM   #21
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Nope just insert and tighten up...but do make sure neg battery cable is disconnected or POW!!
recce02 is offline   Reply With Quote
Old 12-14-2012, 03:11 AM   #22
zman519
Member#: 118086
2003 WRX
36.9 ft-lb on the Starter Bolts
zman519 is offline   Reply With Quote
Old 12-14-2012, 09:56 AM   #23
Dran1341
Member#: 290186
04 WRX
Thanks for the help guys! Now I need a starter. But first 24 hour shift today
