Old 11-29-2012, 01:43 PM   #351
yudangorgor
Member#: 151107
where do i find this radio support?
yudangorgor is offline   Reply With Quote
Old 11-29-2012, 11:52 PM   #352
Ultimateone
Member#: 48025
17 CWP STI
Go to a site like Crutchfield, they will show you need a Metra bracket to mount the new headunit
Ultimateone is offline   Reply With Quote
Old 11-30-2012, 09:05 AM   #353
ruetzal18
Member#: 330542
2013 WRX
otherwise if you buy off amazon just scroll down to other related products should be in there. On the first page the op states the model # of the metra bracket.
ruetzal18 is offline   Reply With Quote
Old 12-10-2012, 12:18 PM   #354
GM02WRX
Member#: 16989
Cobb Stg.2 PSM
Originally Posted by CamaroSS View Post
Oh, and my LAST question: the pioneer harness has a yellow wire with a black stripe that is labeled mute. Was I supposed to connect that to anything?
For the 'magical' bypass that people are buying up relays and kits for - You can simply move the yellow MUTE wire over ONE slot on the harness and ground it along with the light green PARKING wire. This allows the HU to play movies and use blutooth while driving. Works like a charm.
GM02WRX is offline   Reply With Quote
Old 12-11-2012, 03:58 AM   #355
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
That trick only applies to Pioneer AVIC models (e.g., AVIC-X940BT). Not AVH models.
And did you notice his post was nearly 7 months ago?
slowhat already answered it for the AVH-P4400BH and similar models...
Originally Posted by slowhat View Post
nope, no need to mess with that.
you will not use the mute wire. tape it up.
For AVIC models, I have extra wires with the proper pin you can use instead of needing to relocate the mute wire.
Also, on recent AVICs, you no longer need to ground the HU's parking brake lead -- just the secret bypass wire.
Old 12-11-2012, 09:53 AM   #356
ixwrxxi
Member#: 334215
2015 Forester
Does any know if I can use the OEM Stereo mounting plates for the HU or I will need something like this Metra Subaru Double DIN installation kit?
ixwrxxi is offline   Reply With Quote
Old 12-11-2012, 12:44 PM   #357
ruetzal18
Member#: 330542
2013 WRX
the oem HU has the mounting points built in to the unit so you can't take them off and convert to your other radio. You need metras kit.
Old 12-15-2012, 11:00 PM   #358
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The 2013's factory radio mounting brackets are removable pieces, in the same way as on previous years. You can use them with an aftermarket HU, or not. See pictures in this post (#24 in that thread). [ADDED: that's a 2012 Impreza, which changed to a different dash design than WRX and STI]
You will need a kit in any case. The factory HU's faceplate is a nonstandard size (8" wide). The kit fills the gaps.
The aftermarket dash kits typically include plastic brackets that you're supposed to use in place of the OEM metal brackets. But some people opt to use the metal brackets for a sturdier mount (and then modify the kit's plastic brackets to hold the kit's fascia piece in place).
Also see this post for pics and info about dash kits.
Old 12-16-2012, 02:39 PM   #359
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
SVXdc is right on the money. Here are images of assorted JDM AV Panels that are in stock in the USA (unlike Japan Parts).
Silver / Matte Black
Same Silver/Black finish as the USA WRX and STi come with from the factory. The black has a rubber feel and is matte in color.
Silver / Gloss Black
Same as above, but the black is gloss and not the matte rubber finish
Graphite (seems to match 08-09 WRX the best)
Light Silver (matches the silver around the door handles/window switches)
Carbon Fiber (photo coming soon)
3 in stock already
[email protected]
IA Performance is offline   Reply With Quote
Old 12-16-2012, 02:48 PM   #360
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
^ PM will be sent requesting a quote. Edit: nevermind I'll just order from the site.
nightdown fox is offline   Reply With Quote
Old 12-27-2012, 10:32 AM   #361
UpAbove13
Member#: 327272
honestly didnt scroll through 15 pages, just wondering if the satellite radio works with this?
UpAbove13 is offline   Reply With Quote
Old 01-03-2013, 11:32 AM   #362
Jdmoon86
Member#: 283328
2011 SWP WRX 4-door
TorquedPerformance Stage2
Not sure what satellite radio you are referencing but it supports hd radio and sirius. Hope this helps. This head unit improves the sound in your car so much. That alone is worth the money.
Jdmoon86 is offline   Reply With Quote
Old 01-04-2013, 09:12 PM   #363
Aronos
Member#: 342588
This was hugely helpful in my first installation of my single din deck in my 2012 Impreza. Everything went smoothly.
Aronos is offline   Reply With Quote
Old 01-07-2013, 01:44 AM   #364
ghost911
Member#: 342819
i installed my z110bt with the 20 pin harness. the issue i have is that the address, nav settings and few other options on my navi system is not illuminated there for i cant use those options. But the gps works map mode and i can listen to music with my sound system... what is the issue here?
ghost911 is offline   Reply With Quote
Old 01-09-2013, 05:33 PM   #365
cratagus
Member#: 187160
2010 wrx hatch
graphite
i am about to install my 4400 Pioneer and am not sure if it needs a 4 channel amp...can anyone tell me if this unit has enough power on its own or do you need a separate amp?
I am upgrading the front door speakers and adding an underseat sub as well.
thanks
cratagus is offline   Reply With Quote
Old 01-09-2013, 10:16 PM   #366
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
Whelp my AVH-P4400 just flat died on me driving home tonight. The buttons on the front still light up, but the screen will not come on and the unit itself beeps faintly twice every few seconds like some kind of error code??
I pulled it completely out and checked all the wires, which I soldered and shrink wrapped myself. Checked the fuses as well but no dice- it won't do anything other than light up and beep at me. I am completely at a loss?
I can't find a reference for these units 'beeping' anywhere, not even in the manual. Unit has been flawless until today...Anyone have any ideas on what else it might be?
I just had to replace our main TV in the house for a couple thousand bucks so this is not good timing at all!
TIA!
RockyMtnGT is offline   Reply With Quote
Old 01-10-2013, 08:13 AM   #367
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Did you try to cut the power completely (break the connection) and then turn it back on, then use a pin to reset it?
My HU has a little pinhole to reset it.. It's not a 4400, it's a "Pioneer AVH-P3300BT DVD Receiver" so maybe yours doesn't.. i'd try that first anyway.
BWX is offline   Reply With Quote
Old 01-10-2013, 09:16 AM   #368
moviet
Member#: 341415
moviet is offline   Reply With Quote
Old 01-10-2013, 09:43 AM   #369
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Not unless you have a regular 1980's style car-phone.. LOL.
Old 01-10-2013, 10:01 AM   #370
oharao2
Member#: 229802
2008 WRX STI
I ordered the Forrester TomTom Radio bezel from the local Subaru dealer and it was a perfect fit for my Pioneer 4400 and it matches the color of my '08 STI's factory bezel. The part number 66065SC130. It was $64 after taxes and took 3days for the dealer to get in. If you don't have a dealer near by Mastro Subaru has an online site as does Huerberger in Colorado. It looks just like the pict of RockyMtnGT's that the op Posted.
Please note the Tom Tom bezel isnt matted but once installed you would never know it was suppose to be matted. Plus you wont have to worry about it rubbing off.
oharao2 is offline   Reply With Quote
Old 01-10-2013, 10:04 AM   #371
oharao2
Member#: 229802
2008 WRX STI
Not sure if anyone mentioned this but for the power wire on the bypass i used the Sub control wire as my trigger. It turns on and off with the car so the signal works just like it needs to. When crimping them i added a wire extension so that i will still be able to control my sub once its added.
Old 01-10-2013, 03:13 PM   #372
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
I did break the connection pulling the entire stereo out and back in a few times but did not check for a pinhole to do a reset. I will check it out when I get home. Thanks for the heads up!
As my backup plan, is anyone running anything in the AVH-xX5XX series yet? (Looking at a x5500 or AVIC-x940 as a replacement if this thing is bricked)
Old 01-10-2013, 04:13 PM   #373
oharao2
Member#: 229802
2008 WRX STI
Before you buy anything i would check with Pioneer or the place you purchased it at. They may be able to replace it under warranty or repair it.
Old 01-10-2013, 04:15 PM   #374
oharao2
Member#: 229802
2008 WRX STI
I used the OEM brackets to install mine. Then purchased the Tom Tom Bezel to replace the OEM with an 8" opening. Now it looks like the Head Unit came from the factory with the car.
Old 01-10-2013, 08:10 PM   #375
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
Any pics or install tips on how to use stock bracket?
Bobert540 is offline   Reply With Quote
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-16-2013 11:22 PM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-24-2012 11:35 PM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 01:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 04:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
