Old 12-08-2012, 11:50 AM   #26
sdmideas
Possible Scammer - Buyer Beware
Member#: 280920
2003 wrx
white
^who assembled? what were clearances if you don't mind?
sdmideas is offline   Reply With Quote
Old 12-08-2012, 06:23 PM   #27
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Originally Posted by sdmideas View Post
^how did it turn out? Break in? Noise? Power? Response?
It has been an adventure. The first one the machine shop messed up the bore so I took a chance and put it together loose and it had to much piston slap. So I threw together a stock one to run while I built the new one, It lost a cam seal (1st time ever) and lost all the oil. Built the new one and put a fresh rebuilt tomei 7760 on it. That went 143 miles and the compressor nut came off and junked the turbo. Rebuilder won't fix it pos. Couldn't find the nut pulled everything, installed vf48 and nut showed up again junked another turbo ( must have been in the bypass hose). Just installed fp td06-20g, still tuning.
Old 12-09-2012, 10:38 AM   #28
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^ Ouch. I rebuild turbos, why couldn't he do it? Must be that damaged huh. Sucks to hear and good luck
Old 12-09-2012, 12:09 PM   #29
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
He forgot the loctight and is trying to blame me saying I installed it wrong. I have installed 6 turbos in the last 2 months with just that 1 failure. Yea i'm pissed. $1000 for the used tomei, $900 for the vf48 that the nut trashed, $650 for the fp 20g used = $2550 to put a used 20g on my fresh 2.1.
Old 12-09-2012, 06:10 PM   #30
sdmideas
Member#: 280920
2003 wrx
white
Ouch, sorry to hear about your troubles. Gl with the 20. I ran one with 91+meth and had pretty good success on track. A bit laggy day to day but ok.
Old 12-10-2012, 02:56 AM   #31
Champion_nsk
Member#: 301527
Hi. Sorry for my question but I can't find answer. I need to buy long length connection rods for EJ20. I need it strong and tested. Thank you.
Champion_nsk is offline   Reply With Quote
Old 12-10-2012, 04:59 AM   #32
Champion_nsk
Member#: 301527
Is there anyone who use this type of conrod? RogerClarkMotorsport RCM2409 +1mm
Old 12-11-2012, 05:10 PM   #33
sdmideas
Member#: 280920
2003 wrx
white
chirp chirp
Old 12-11-2012, 05:22 PM   #34
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
I would def get rods not worth having to tear your motor apart after bending/breaking the oem rod! I personally thought I was going to be good with the oem STI rods but I thought wrong! I was at 550whp for around 5000 at 30psi with no probs. I turned the boost down to around 24lbs for winter and bent a rod around 4500 partial boost! So my point do it right the first time so you don't have to rebuild your block!
02rex62 is offline   Reply With Quote
Old 01-16-2013, 09:32 PM   #35
philly15
Member#: 223137
14' super ultimate
race car project
^i second what he said sick picture though tyler i might be doing a stroker motor next fall not sure if i wanna use the STI rods i have laying around or at least get some eagles or possibly some manleys but then again my goal is only 350 whp
philly15 is offline   Reply With Quote
Old 01-16-2013, 10:17 PM   #36
jasonwestenskow
Member#: 301446
06 STI
black
That's a nasty picture. Since there's already been talk about eagle rods I thought I'd ask what people have to say about them? I've read positive and negative things about them. Starting assembly on my rebuild here shortly and was hoping someone could shed some light? Thanks
jasonwestenskow is offline   Reply With Quote
Sleeved NA 2.5L hybrid OR 2.1L stroker??? cueballsi Built Motor Discussion 13 01-20-2012 10:07 PM
FS : SoCal: New 2.1L stroker kit (Alamo), and RAW cross drilled crank Thran Engine/Power/Exhaust 9 06-13-2011 11:04 AM
2.1l Stroker build oil? jakedademon Built Motor Discussion 20 03-16-2011 09:26 PM
FS : 2.1L stroker kit (Alamo), and RAW cross drilled crank Thran SCIC Private Classifieds 11 01-25-2011 07:56 PM
Off the shelf pistons for a 2.1L stroker. Touge Tune Built Motor Discussion 21 03-27-2008 09:45 PM
