Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 11-29-2012, 11:00 AM   #1001
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
I has 400+whp on a stock longblock!!
And a catch can being put to work for it.
Old 12-03-2012, 06:23 PM   #1002
babyrex
Member#: 337130
2002 wrx hybrid
psm
There is just no need for any thing near 4xx awhp. Its all about power to weight ratio, there is nothing wrong with 325-350ish, but any thing after that you will be breaking things.(axles,rears,trans,throw out berring,etc) that being said it is a fight alone to get to any thing near the 325 mark,and still be reliable.
babyrex is offline   Reply With Quote
Old 12-07-2012, 03:12 PM   #1003
Cactusfog
Member#: 339336
Just want to have some fun and this post saved me a TON of money and heartache. A good tune is in my future and maybe some brakes. I need to learn how to stop these beasts.
Thanks for the great posts.
Cactusfog is offline   Reply With Quote
Old 12-08-2012, 07:06 PM   #1004
thewilfred
Member#: 325435
2007 WRX STi
Thumbs up
hmmmm really good for me to have read this...
thewilfred is offline   Reply With Quote
Old 12-08-2012, 09:04 PM   #1005
DDScooby
Member#: 161876
02 Impreza WRX
Me again:
Updated what the cost is for a true 400+whp car. This is for a 2.0l 16bit ECU...and is becoming a dinosaur in the Subie tuning world. In reality, to make it "easier" so to speak, a Hydra EMS system would be ideal; however, I want to retain the car being as close to street "legal" as possible, and this adds cost to the build. -not to mention heartache to the tuner. haha
Build specs to date on the shopping list:
-Kelford 199-E cams ($850)
-SuperTech +1mm oversized int/exh valves ($220)
-SuperTech Springs/Ti retainers (possibly not necessary, but HIGHLY recommended)($320)
-ID 1000cc injectors ($520)
-coated intake manifold ($125)
-new head gaskets ($80)
-machine shop labor costs (~$800)
-short block inspection/ring/bearing replacements (~$300)
-Garrett GT3582R .82A/R (rotated/single scroll)($1550)
-custom FMIC/Up-pipe piping on top of APS DR525, custom downpipe, custom inlet/intake (retaining MAF pull through system) ($800)
-COBB Speed Density (new MAP sensor $200)
-Exhaust headers ($600)
-crap ton of heat wrap ($200)
-44mm EWG ($350)
-Element Tuning AOS/Catchcan ($299)
-Tune ($350)
This is on top of already existing on the car:
built ej257 motor
-CP 99.5mm 8.2CR pistons
-Manley rods
-newer OE STi Nitrided crank (Stock stroke)
-FULL STi 6spd swap w/Brembos, R180 rear end, and DCCDPro
-upgraded ACT SB4-HDSS clutch ($625)
-new OEM STi flywheel ($209)
...in addition to all this there are a crap ton of chassis/steering/suspension upgrades to make all this power "safe". But seriously, nothing beats common sense when behind the wheel and knowing your own capabilities. Not to mention being honest with yourself about said capabilities.
I don't even want to add that up because I'm sure I'll hang my head and do a facepalm. But this'll be a true 400+whp car on probably 99% of the dynos out there, and much fun for me to have.
Previous to this car made 327whp/310wtq with pretty much all bolt on stuff with an OE mounted turbo (Blouch 1.5XT-R).
The purpose of this is not bragging rights, but a realistic cost analysis for a reliable 400whp car, so that anyone else out there new or veteran subie owners can make an informed decision. Obviously this is isolated to a 2.0l 16bit ECU car. The later models, 06+ will have a different variant of modifications needed more than likely.
DDScooby is offline   Reply With Quote
Old 12-11-2012, 08:49 PM   #1006
DoomsdayFAN
Member#: 320580
What is it like driving a 400+ whp AWD Suby? Like, for example, lets say you're in a stock Ford Focus and you press the gas pedal down three inches.... you're going to get a nice but slow and steady increase in speed. Now, if you press on a 400+ whp AWD Suby gas pedal that same amount in first or second gear, is it going to be a smooth and controlable gain, or will that same pressure on the pedal make the car lunge like a rocket, thus making it extremely difficult to drive in traffic of any kind?
In other words, how gingerly do you have to milk the pedal when the car is that powerful?
DoomsdayFAN is offline   Reply With Quote
Old 12-11-2012, 09:49 PM   #1007
DDScooby
Member#: 161876
02 Impreza WRX
A 400whp subaru is more than likely going to have a fairly large sized turbo on it. So unless the driver has the car in, say, third or fourth gear at 3500-4k on the tac, then yeah it's gonna rocket off when the gas pedal is mashed to the floor. But it's a turbo, not a on/off switch like a supercharger might be. So it's going to have to spool up first, but it's going to be a hard spool and start pressing the driver into the seat. A gradual increase on the throttle will be a gradual increase in speed. ...generally speaking.
Old 12-11-2012, 09:53 PM   #1008
Stangy
Member#: 329676
1999 GC8 R-STI
Good question. Since most high HP subarus have large turbos, it would depend on what gear/rpm. For instance your on the hiway cruising and push the pedal down "three inches", it will accel quicker then the focus for sure...but the lag from the big turbo would not give you an instant and unmanagble power increase. If u slammed it and were in the correct gear (passing someone for instance) where the turnbo was spooled then this is when you would get the rush quickly. Example: you may be crusising at 2000rpm on the hiway, punch it in 5 gear, but with your gearing and low rpm it will take a while to get that neck breaking push. On the flip side your in 3 waiting to pass some shmuck on the on ramp..find an opening and floor it- you will hit your sweet spot (3500rpm for say a big gt30r turbo) and BOOM your off!
long story short..it is not unmanagble. I have driven high hp 1700lb volkswagens, HUGE hp supras and 330whp sti's (mine)..none of which are unmanagble unless your a dummy
Stangy is offline   Reply With Quote
Old 12-12-2012, 12:12 AM   #1009
DoomsdayFAN
Member#: 320580
I see. I was worried that if I ever, for whatever reason, got my car up that high in the power range it'd be an uncontrolable wreck in slow traffic. (There is a video of this guy on youtube who has a Z06 with a fully built NA motor, but he says driving it in slow traffic is terrible and it's like driving a cement truck). I would never want the Suby to feel like that.
Speaking of the slow spooling huge turbos, like the GT40R... what can be done to make them maintain their monsterous power, yet spool up quicker? Port & Polish?
Old 12-12-2012, 08:48 AM   #1010
Stangy
Member#: 329676
1999 GC8 R-STI
Good question: Few things..
  • Increase stroke
  • Increasing compression
  • Larger IC piping
  • Larger DP
  • Optimal sizes intake piping/filter
  • Wrap your turbo/dp/header
Old 12-12-2012, 08:49 AM   #1011
Stangy
Member#: 329676
1999 GC8 R-STI
....or get a smaller turbo
Old 12-12-2012, 12:46 PM   #1012
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
It should have a consistent powerband and that is key. Whether your car is stock or 500whp doesn't matter. You WILL need to re-learn how to drive your car when you do major mods.
Old 12-18-2012, 02:49 AM   #1013
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
I really want to build my wrx the right way to run safely around the 350 range. I'm waiting a little to see if i really want to dive in because i know by the time I'm done ill have at least 10 grand in it. Id love to do a full build (motor tranny suspension) and make around 500 but we all know that unless you're rich thats not happening lol I've driven a few very powerful cars but they were all rear wheel drive and man was that **** ridiculous... i drive my brothers 5.0 mustang every once and a while on 7.5 psi (centrifugal) that made 586 to the wheels and its very true when you say you're at 100 mph before you know it. and breaking traction at 60+ mph when boost comes in is kinda scary haha the other car was a built Z06 that dynoed at 842, it was fully built and spray along with some boost and honestly i got on it once and backed out because i didn't want to **** up someone else's car lol don't ask me the point of my post because i have no idea what it was lol but the OP is right. anything near 400 whp is nothing to **** with unless you have experience with powerful cars. Oh and i drove my cousins GLI thats bored out and fully built block and head with forged internals on 28 psi which made 482 at the wheels. It hooked better than i thought... after 80 lol but thats a lot of power for a 2004 gli.. and the owner is still scared to drive it hard because he is not used to driving such a powerful car. even though its his DD haha
Gregor91 is offline   Reply With Quote
Old 12-18-2012, 08:34 AM   #1014
cond
Member#: 339416
2015 STI
Thank you Defiant, this post cleared a lot up for me.
cond is offline   Reply With Quote
Old 12-18-2012, 10:18 AM   #1015
Davenow
Member#: 23676
  • Increase stroke
  • Larger IC piping
  • Larger DP
pre-turbo water injection
pre-turbo nitrous (just a quick like half second blast)
flipped intake manifold (shorten the pipeing from IC to manifold=less volume=faster response)
Old 12-18-2012, 03:45 PM   #1016
Damian07sti
Member#: 340607
2007 WRX STI
Originally Posted by rek888v2 View Post
My old STi was roughly 320-340 (Never offically dyno'd) and that scared the hell out of me on city streets. My STi now is 269/290 with a consertive tune (wife driving her while Im in Iraq) and she still ran a 12.83 while I was on leave 2 weeks ago. She scares me too! These kids putting all this money into their cars need to take that money, put it away in savings or buy driving lessons.
The best mod you can ever do is tune the nut attached to the steering wheel (thats yourself for you slow people!)
+1 on this getting Stickied. Very good thread!
I am new to this forum and currently i am at work but when I read this I started laughing soo hard i almost cried. nothing like tuning yourselves lol.
btw how do you even get your wife to run your car at the track. I tried forcing my girlfriend to do a run in my old 12 second civic but unfortunatly that was a fail
Damian07sti is offline   Reply With Quote
Old 12-18-2012, 05:04 PM   #1017
Scooby_DeuceX
Member#: 288562
2011 STi
Read it again. He stated that he ran it while on leave.
Scooby_DeuceX is offline   Reply With Quote
Old 12-20-2012, 11:54 AM   #1018
staystranger
Member#: 341140
awesome article. Good read and very resourceful.
Now starting to feel silly about trying to build a 400hp GC8 for track lol...
staystranger is offline   Reply With Quote
Old 12-21-2012, 12:49 AM   #1019
nursedarry
Member#: 341212
Did you ever take it too the drag stip and go all out to see what kind of times you could run? Think it's possible to hit in the 11s with 400 whp? (Especially if youve got on lighter wheels)
nursedarry is offline   Reply With Quote
Old 12-21-2012, 09:56 AM   #1020
petitelamb
Member#: 341242
Stage 1 is just a tune, stage 2 is a tune with a downpipe. You can go directly to any "stage" you want really. You could go straight to a turbo swap with all the supporting mods if you want, just need a tune for it.
petitelamb is offline   Reply With Quote
Old 12-21-2012, 06:08 PM   #1021
goose247
Member#: 341274
Default Great post
I would have to agree with everything said. I have gone from acura and Honda to Volvo turbo and audi. And now diving into subaru I recently purchased a 04 forester xt which has been seriously built. Engine rebuilt ground up with new pistons, rings, valves, ported and polished. Full turbo XS rotated turbo system with huge TMIC. Huge header with screamer pipe and larger up/down pipes and custom exhaust with all cats removed and ECU replaced with sti one and re worked to throw no codes for smog. I met with the previous owner and the tuner and the two mechanics at the shop it was built at before I bought it. And it's been awesome and dyno sheet showed 343 HP 347 torque. And even those numbers are shocking when driving it u do have to be ready when you throw all that to four tires cause things in front of you get close fast! My debate on if I wanted more power was quickly answered. And while I may shoot for 10-20 more getting to 400 is really not necessary.
goose247 is offline   Reply With Quote
Old 12-22-2012, 12:27 AM   #1022
kndt
Member#: 341308
Great article.good
kndt is offline   Reply With Quote
Old 12-30-2012, 02:49 AM   #1023
ObsOwner98NA
Member#: 337247
2004 Wrx Wagon
i really like this post. i recently got away from my strange OBS obsession and upgraded to an 04 wrx wagon. ive got the slightly ambitious goal of 400whp on the 2.0 possibly more if i can swing it. but ive had too much time behind the wheel of many different high powered FWD and RWD cars to underestimate a subaru. i consider myself a fairly experienced driver but when i first drove a subaru it was an automatic 97 OBS and the entire FEEL of the car is different. The AWD is a whole new animal to those like me used to older muscle cars and american vehicles in general. yes im shooting for 400+ at the wheels but my biggest goal is to do it slowly enough to continue to get used to how a subie drives. by the time i get to 400 i want to have gone through a large range of power levels in my car. and to anyone who even has experience with the FWD and RWD high powered vehicles i recommend doing the same in an import.
ObsOwner98NA is offline   Reply With Quote
Old 12-30-2012, 09:11 AM   #1024
Davenow
Member#: 23676
If you have driving experience with those high power cars, ok fine, YOU may be safe.
But the cost doesn't change. And I would bet whatever cars you are used to, are cheaper to hit 400whp reliably than a Subaru. I can't think of many cars that are more expensive to get to 400whp, reliably, than a Subaru.
Nowadays your best and easiest path to 400whp is a used 2012 mustang, an intake and a reflash. Boom. 400whp. Hell a bolt on magnussen supercharger a catback, a pulley a boost a pump and some tuning (under 10k) will put you over 600whp pretty reliably.
Old 12-30-2012, 10:31 AM   #1025
BoostedBuggy
Member#: 338125
Very informative. Thanks for the input.
BoostedBuggy is offline   Reply With Quote
Public service Announcement for all you white guys. obyone Off-Topic 12 06-24-2009 10:20 AM
the following Public Service Announcement is brought to you by P.A.C.T Amazake New England Impreza Club Forum -- NESIC 16 11-27-2003 09:43 PM
A public service announcement Midwayman Mid West Subaru Owners Club Forum -- MWSOC 15 02-25-2001 06:34 AM
SVX Public Service Announcement CRZ_MSL SVX Forum Archive 2 11-22-2000 11:24 AM
Public service announcement (AKA: Tony eats crow) Tony General Forum Archive 3 10-18-2000 06:12 AM
