Old 12-10-2012, 03:19 PM   #1
bluewrx02
Member#: 43342
blue
Default 2.1 stroker kit
Hi everyone. Was looking into getting a 2.1 stroker kit for my 02 WRX. Would this kit be complete or would i need to buy other parts to fininsh the kit? I have a VF34 turbo and sti pinks already. Or do you think i would need to go bigger? Im not looking to break any HP records here just get some good numbers. EX. 300-350. Thanks guys
bluewrx02 is offline   Reply With Quote
Old 12-10-2012, 09:43 PM   #2
02wrxej208
Member#: 295496
2002 ej208 vf34 wrx
We need a LOT more information here. Are you talking about like a Brian Crower/Cosworth/or Manley stroker kit With just the internals Or do you plan on buying a stroked short block? You can always piece together your own set up, for my stroker build I bought Mahle pistons(460$), BNIB eagle h rods with arp rod bolts(200$), a lightly used 2010 crank(150$), ACL race main and rod bearings for 75$, which is a fair amount cheaper than most kits.
If you buy a pre-assembled kit like the ones above it should contain all the items you need to assemble the bottom end besides case halves, then you will need machine work and depending on the kit, everything balanced.
I think Sti pinks will be maxing out with that set up, with a proper tune a vf34 will hit the 300s. You should also get the heads refreshed, a timing belt kit, all new gaskets, and I would do new head studs just to be safe.
02wrxej208 is offline   Reply With Quote
Old 12-11-2012, 03:19 PM   #3
bluewrx02
Member#: 43342
blue
Yes I was looking at getting a kit. What size injectors and turbo would you suggest for this build? Thanks
Old 12-11-2012, 03:50 PM   #4
spackyscooby
Member#: 169257
2000 impreza rs
millenium jade
Are you going to do any work on your heads/cams, where do you want your powerband, what is your goal power wise and reliability, what amount of maintenance are you willing to do and how regularly(are you willing to tear it down and inspect, redo rings and such)? The answers to these can get toward what turbo to use.
spackyscooby is offline   Reply With Quote
Old 12-11-2012, 03:58 PM   #5
bluewrx02
Member#: 43342
blue
Would like to have it to were I will not need to tare down at all. Its going to be a daily driver. So not really going to be racing around in it. Just want some extra power for those kind of days
Old 12-11-2012, 06:53 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
2.1L vs. 2.0L is not really about turbo sizing. It's about putting the torque band where you want it.
2.1L will shift your powerband left from the 2.0L. More torque off-boost, boost will happen sooner, and very high RPM capability will be slightly worse. However on the EJ205, high RPM performance is non-existant due to the heads, so you end up in a win-win on an EJ205. You gain on the low and give up nothing on the high end since the heads are the limiting factor.
My opinion is that the 2.1L is just a better shortblock match to the stock EJ205 heads and it's always a better option for a street engine... it's just a matter of whether the extra cost is worth it to you.
A moderate turbo actually works to the strengths of the 2.1L with stock EJ205 heads. I'm not sure a TD04 would be great for it, but it would work. The 5MT might not like that pairing so much. vf39- GT3071 ish are good sizes to match with stock heads.
You can always start with your vf39, then move up if you feel like it (or funds allow).
Old 12-11-2012, 09:06 PM   #7
chris the man
Member#: 287783
08 predator evo X
RR
this is perfect^^^ couldnt agree with you more.
it just depends on what you want blu...
for that price you could normally just drop in a complete v7 engine, and then sell all of your old parts...
chris the man is offline   Reply With Quote
Old 12-11-2012, 09:18 PM   #8
bluewrx02
Member#: 43342
blue
I was looking into a 207 but the motor alone is $6000 on eBay. Was looking to spend around that for a whole setup.
Old 12-11-2012, 09:21 PM   #9
chris the man
Member#: 287783
08 predator evo X
RR
vendors on here that locals i know have bought from sell for 3000-4000 dollars.
i never seen a v7 go for 6000, thats a complete ripo off.
after build work, blue printing, decking, and parts... your easily at 3000 for your 2.1
Old 12-12-2012, 01:59 AM   #10
Cortiti
Member#: 340376
Cortiti is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:00 AM.
