Old 11-27-2012, 05:23 PM   #201
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
That sounds like a winner. You using this on a 2.5 or 2.0l?
ericz is offline   Reply With Quote
Old 11-27-2012, 06:07 PM   #202
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
2.5L I'm not going to push it too hard, as the car still has its stock block and transmission. 76k and growing
I'm sure the turbo will easily be capable of making one or both go boom.
I emailed kmak, specifically about there sts turbine wheel hopefully they get back to me about that and it's not too ridiculously priced.
1600 dollars seems kind of ridiculous for a non ball bearing turbo, new technology or not.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 11-27-2012, 09:31 PM   #203
2011boostdwrx
Member#: 263470
I will ahve my KAmak 20-GTX STS 9-blade tuned in a month after break-in. I had my compressor cover thermal coated red to match my IC piping.
This will be running off a full stage-2 motor build (all forged internals) ELH, GS UP-Pipe, PTP turbo blanket, Full stage-2, TGV deleted, Air Pump deleted etc.......you can check my build thread.
Old 11-28-2012, 02:51 AM   #204
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
GS-uppipe is a poor choice for your turbine housing, too small ID, and not a fan of 2-bolt flange, flex-joints... you should have gotten an ELH 3-bolt with uppipe combo, ID would match your turbine.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 11-28-2012, 08:47 AM   #205
2011boostdwrx
Member#: 263470
Thank you for your recomendations, I can always change later, got a steal on the ELH (300) brand new! Couldnt resist that temptation. I can always have my tuner weld on a 3-bolt flange and make an up-pipe i guess.
Old 11-28-2012, 09:03 AM   #206
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
So how much did you end up paying for the Kamak STS turbo?
Old 11-28-2012, 12:02 PM   #207
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Issue is not the 2-bolt flange or flex joint, issue is the ID is 6.5mm smaller than your turbine. You could have bought a Kinugawa ELH with proper uppipe for $450.
The Kinugawa uppipe that came with the ELH is huge (51.5mm ID) vs a high-flow Grimmspeed EWG 2-bolt Uppipe (45mm ID), it is a perfect match for the TD06SL2 turbine housing (50mm ID).
GS Top / Kinugawa Bottom
Grimmspeed Uppipe
Kinugawa Uppipe
Turbo Turbine Inlet, I will probably port match it to uppipe outlet 51mm
Old 11-28-2012, 05:41 PM   #208
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
This is a video i made today. Didn't rev it that high because of traffic and cams that i have yet to install but its there to show how much lag to expect from this turbo. Its uploading as of 11/28/12 @ 4:33pm Eastern time and should be done around 6:00pm
8CM TD06H/60-1 2.4" cover
EJ25 Hybrid
Turbo back exhaust
edit:5 spd
Purpose_Built is offline   Reply With Quote
Old 11-28-2012, 07:27 PM   #209
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Hard to read the gauges from reflections. What rpm does full boost come in?
Old 11-28-2012, 07:46 PM   #210
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
EJ25 Hybrid
Turbo back exhaust
Video Link: http://youtu.be/2vLaLorJg1g
Is that 3rd in a 6 speed?
wrxsubiemod is offline   Reply With Quote
Old 11-28-2012, 08:10 PM   #211
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
On my car between 3400 and 3800. Depends on the gear and how hot the headers are. This tune is retarded a bunch. On my more advanced tune it picks up much quicker under boost but i didnt have it flashed for that because my computer was at home.
It's 3rd in a 5spd. If it was in a 6spd it would have went through the gear much quicker.
Old 11-28-2012, 08:13 PM   #212
rob1n1
Member#: 276425
2013 335is
Alpine White
5 speed, I think he added that later.
Old 11-28-2012, 09:26 PM   #213
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Log a pull and put up a virtual yno
theotherguy is offline   Reply With Quote
Old 11-28-2012, 10:10 PM   #214
2011boostdwrx
Member#: 263470
I have the 20 GTX STS, is this the STS 9-blade exhasut wheel? As far as the up-pipe I wastold not to go with an overly big diameter as the gases slow dramatically, dont know if thats true. At least that was what I was told with the HTA68 turbo.
Old 11-28-2012, 11:03 PM   #215
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
I'll try to get it to work tomorrow. Hasnt worked with the Carberry Sd rom on my car because ecuexplorer puts the right values in the wrong columns in XL. Romraider logger doesnt work on my computer either.
Old 12-10-2012, 03:18 PM   #216
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
I have the legacy style td06sl2 20g 8cm with a 2.4 inlet on my 2011 forester xt 4eat and can say that this turbo is so much better then my vf52 i had on it befor. I expected it to much more laggy but im seeing 20psi by 3800 rpm in 3rd gear and its almost instant. I find it to be a much more easy turbo for day to day driving because the power is more linear and comes in later with the torque and boost compaired to a high strung 23psi vf52. We have not finished tuning it yet and im very eager to see what more lies with this turbo as we have it tapering hard for safety until the road tune wednesday looking to peak around 22psi on e85.
nate_fisher is offline   Reply With Quote
Old 12-10-2012, 05:06 PM   #217
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Good to see another Kinugawa owner on board.
I installed my billet 18G over the weekend. I'm trying to find time to install the injectors and work up a solid map. So far, I can comment that the billet actuator is rock solid with boost control @ 1 bar spring pressure. I'll add my install findings to this thread later this week.
Old 12-11-2012, 11:54 PM   #218
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Things I noted during my install.
The included braided steel oil line was too long for my taste, and there was no way to comfortably retain my hotside blanket and Cobb heatshield with this line. I understand the braided line is longer to fit non AVCS engines where the turbo oil feed is down on the head. I used the original VF39 oil line with the appropriately threaded banjo bolt supplied in the kit.
The larger compressor cover interferes with the block vent/AOS drain. I noted the same issue with a Dom1.5XTR I installed over the summer. Not a big deal, just thought it was worth mentioning. I had enough give in my hoses to just flex the adapter forward.
I had to bend the top coolant pipe a bit to clear the Hyperflow TMIC. Also normal for upsized turbos and intercoolers.
DW 850cc injectors and initial tune will be done tomorrow night, I'll post some logs as soon as I can.
Old 12-18-2012, 10:48 PM   #219
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
You guys have me close too buying a TD06SL2-20G soon. Once I break in my built motor in my forester I may have to swap my vf48 out for one of these.
Ian @ Performance Auto Solutions
rexworx is offline   Reply With Quote
Old 12-19-2012, 12:35 AM   #220
2011boostdwrx
Member#: 263470
I had a few fitment issue with the 20G on my11 Built block, there was actually a spacer we had to use to clear the block. There is a spacer included with the kit, dont know if it is for the 20G only though. IT comes with extended studs as well.
In the last pic you can see the spacer in between the GS upipe and housing.
Old 12-19-2012, 10:04 AM   #221
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Yeah Ive installed a few different brands that came with a spacer like that. Most recently was a ATP GTX3582
Old 12-19-2012, 12:02 PM   #222
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Thats a first for me. Why are the spacers needed? I'm sure interference issues but where?
Old 12-19-2012, 02:11 PM   #223
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Originally Posted by 2011boostdwrx View Post
I have the 20 GTX STS, is this the STS 9-blade exhasut wheel?.
There's a guy with the STS wheel on the EJ207 thread. He has it with the GTX 16g, which under my opinion is similar with a non-billet, classic mitsubishi 20G. He has this with an EJ207, which is 2.0 with AVCS.
I think the STS spools slightly faster than a regular or even SL2 turbine, but it seems to me that the torque drop from the max is slightly sharper than otherwise.
Old 12-19-2012, 03:25 PM   #224
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
- STS Turbine wheel:
It comes with 9 blades high flow and KAMAK fastest response type, only 1/3 weight of other types which can reach low-end torque and top-end power.
Old 12-19-2012, 04:16 PM   #225
EvileyeZ88
Member#: 233501
99 outback sport
Now if only they would sell just the turbine wheel....
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 08:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 02:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 08:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 05:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 11:29 PM
