Old 11-28-2012, 12:31 PM   #2451
Maxwell Power
Member#: 190729
Originally Posted by TPG Tuning View Post
As will ProEFI, AEM Infinity and Motec! :-)
Nate
TPG
did proEFI finally release a WRX/STi board? Last I talked to them they only had the SVX and had NO INTENTION of ever doing the wrx/sti.
Old 11-28-2012, 12:40 PM   #2452
explicithero
Member#: 15893
2004 STi
The color of the burgh
Nate
TPG
But who the hell knows when AEM will actually release the infinity though. The supra board came out last summer but no updates to the rest of the line from what I heard.
explicithero is offline   Reply With Quote
Old 11-28-2012, 12:45 PM   #2453
TPG Tuning
Member#: 185725
I was just mentioning it for reference that the ProEFI has an awesome flexfuel setup for blending fuel/timing/boost maps based on ethanol content.
http://proefi.com/info/product-list/flex-fuel/
Last I talked to Jason the SVX was the only PnP application using the adapter harness off the shelf. All of the EVO and GTR units we've worked with use a similar style adapter. I'm sure it wouldn't be hard to make it work on a WRX/STi chassis.
Nate
TPG
TPG Tuning is offline   Reply With Quote
Old 11-28-2012, 01:23 PM   #2454
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
For reference Haltech also has awesome flex fuel capabilities. They even make their own flow through sensor
jnorth85 is offline   Reply With Quote
Old 11-28-2012, 01:38 PM   #2455
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Haltech does not have a PnP choice for a Subaru though.
buddsautoparts.com is offline   Reply With Quote
Old 11-28-2012, 01:58 PM   #2456
TPG Tuning
Member#: 185725
You could buy an Infinity today and wire to work with an EJ engine as long as you use a supported cam/crank trigger. The 2J isan't a different board, just an Infinity box with an adapter harness for a stock 2JZ wiring harness.
http://www.aemelectronics.com/files/...tion_Guide.pdf
Some of the engine protection strategies in the Infinity are pretty badass with thresholds for AFR, oil pressure, and coolant temp among others like the link G4 Maxwell Power mentioned earlier.
Nate
TPG
Old 11-28-2012, 01:59 PM   #2457
TPG Tuning
Member#: 185725
Motec does and they're on sale!
http://www.motec.com/pluginecus/reducedoempricing/
lol
Nate
TPG
Old 11-28-2012, 02:46 PM   #2458
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
lol
Nate
TPG
Oh I know this ;-) we will talk at QSL next week.
Old 11-29-2012, 12:05 AM   #2459
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Nate
TPG
I hear ya but I dont own any of those. I do however own a Hydra and the 2.7 upgrade is only a few hundred dollars away.
dexterous is offline   Reply With Quote
Old 12-05-2012, 03:40 PM   #2460
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Ha, ha is does anyone have your best interest at heart, Tom? No, just yourself, you've plowed your own path, and you've come to your own conclusions. Nobody owns your car, nobody has your blood, sweat, tears, and emotions invested in this car, only you. I know you want your car to run like it used to and your Hydra always gave you what you wanted.
What people don't realize is that by having the business model we do with the Hydra EMS, it allows me to share maps and help anyone regardless of who tuned it. There are no secrets and no locking of the maps I provide (tuners can lock if they choose) because no matter how much I help someone or how much effort I poor into a base map, the Hydra sale always comes back to Element Tuning. I always want to empower my customers and to teach them to help themselves so they at least have a basic understanding of the engine management system. There are only a few really good Hydra tuners out there but there are a whole bunch of customers who are really good at tuning their own Hydra. I've always had an open door tuning policy with Hydras but I can also understand with the Cobb AP business model a tuner wanting to protect his/her work but that never benefits the customer.
The Hydra 2.7 can do more than anyone can imagine now. All your Flex Fuel support maps automatically adjust, fuel, timing, and boost for ethanol content. I've been using the Hydra 2.7 boost control now with a 30hz 3 port solenoid (same as hondata, cobb, aem, turbosmart solenoids) and it works perfectly switching between high boost E85 and low boost pump gas maps.
The Hydra output controls now are endless as we use "expressions" to command whatever we want. In my case I wanted to increase solenoid duty as RPM increases (due to my small internally gated turbo) and I also wanted specific control over temp changes. I was able to add an expression to the output for the boost control which assigned a 3D Map that I could define RPM vs. Air Temp and adjust my boost control duty cycles beyond the closed loop control.
We've tried our best to "dumb" down the Hydra interface as much as we could to make it easier for "tuners" but it's not "stupid" proof. Most tuners tune from a OEM map and then tweak, they don't have to tune an engine from ground zero like I have to for any new platform we develop. When you have to do this you become very intimate with the engines and the software. Tuning an STi engine is like taking candy from a baby even with 2200cc injectors. Try tuning a Hydra EMS from zero for a BRZ FA20 engine with simultaneous direct and port injection, DI injector phasing, DI injector MS, DI response, DI flow rate based on pump pressure, DI pump phasing, DI pump pressure targeting, DI pump pressure duty%, DI pump dump valve response time, quad variable intake and exhaust cam timing with advance and retard, traction control, PID controls for all the above closed loop targeting, and all on top of the normal port injection mapping you would do on an STi. There are a whole lot of talkers and not doers in our industry!
Between what I can do and what you want to do Tom the sky is the limit with Hydra 2.7.
So as I'm sure the Hydra or myself will get flamed because the next, completely unproven, best engine management system since sliced bread is so superior to the Hydra, I'm posting and leaving.
Old 12-12-2012, 08:41 AM   #2461
dexterous
Member#: 23553
2014 WRX - Daily
Some times things just work out! For example, I just found out that Hydra is running a sale for the month of December and they are offering the Flex-Fuel support add-on for all 2.7 upgrade customers for FREE! I am glad I waited. My ECU should be back by Christmas and I already have an appointment to see Phil during the first full week of January to get the 2.7 calibrated. As soon as I am done with that, I will be pulling the motor so Element can re-enforce the block.
Old 12-12-2012, 08:57 AM   #2462
bboylocob
Member#: 151809
2007 WRX
Sweet!!!!
bboylocob is offline   Reply With Quote
Old 12-13-2012, 08:41 AM   #2463
stiguy2008
Member#: 332709
Hey guys sorry to but In & I know this has nothing to do with motor builds but do any of you guys have any knowledge about the ver4 jdm sti motor? Just lookin for some usable info thanks!
stiguy2008 is offline   Reply With Quote
Old 12-13-2012, 08:57 AM   #2464
explicithero
Member#: 15893
2004 STi
WTF use the search button buddy!
Old 12-13-2012, 08:58 AM   #2465
bboylocob
Member#: 151809
2007 WRX
Really???? gtfo
Old 12-13-2012, 09:13 AM   #2466
stiguy2008
Member#: 332709
Couldn't really find anything
Old 12-13-2012, 09:33 AM   #2467
bboylocob
Member#: 151809
2007 WRX
If u gng to ask ask in the appropriate thread. Make a new thread or something.
Old 12-13-2012, 09:53 AM   #2468
stiguy2008
Member#: 332709
Will do
Old 12-13-2012, 09:54 AM   #2469
stiguy2008
Member#: 332709
Yeah will do
Old 12-13-2012, 10:37 PM   #2470
dexterous
Member#: 23553
2014 WRX - Daily
Damn, this thread has seen just about everything...
Old 12-13-2012, 11:51 PM   #2471
Jdub.csu
Member#: 283784
2013 EVO X GSR
That is the beauty of it
Jdub.csu is offline   Reply With Quote
Old 12-14-2012, 12:04 AM   #2472
TwinscrollGT35R
Member#: 256810
I like this ecu path. This thread is the cats meow.
The problem with ecu is finding the support and or a tuner that doesn't use your car as a learning curve. I have been watching out for something other then Cobb. I don't like the way tuners are. I am liking the Motec and now because of this thread liking the Hydra. To me the after sale support is key to my money. If and when I dig my pile out of the garage I'm looking at Hydra.
TwinscrollGT35R is online now   Reply With Quote
Old 12-14-2012, 11:56 AM   #2473
bboylocob
Member#: 151809
2007 WRX
This. When I had Cobb no one here could tune it. The closes was 6hrs away and not very reputable. So i did some research and what path i was gng with my build. It was simple. Phil built my motor and he is probl. The best with hydra. Yea he is 16hrs away. Alot further but he knows my setup he knows my ecu and i will make a family vacation out of my tune trip so it wont be so bad.
Old 12-14-2012, 10:05 PM   #2474
dexterous
Member#: 23553
2014 WRX - Daily
Phil is pretty close to me (5hrs) so its workable. I haven't used the Hydra 2.7 yet but the 2.6 software seemed pretty easy to me. In fact, I found it easier to understand than the Cobb AccessTuner Race software.
Old 12-14-2012, 10:12 PM   #2475
bboylocob
Member#: 151809
2007 WRX
Yea i have 2.6 and isnt so bad. Its pretty user friendly. Ima get the upgrade within the next mnth after Christmas.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
