Old 12-12-2012, 09:31 AM   #1
Mojambo
Member#: 102581
2006 STI-USDM
SGM
Default thread/pitch size for oil galley plugs in B25 head
Hey guys,
I've been searching all over for this and can't seem to find it. I'm looking to confirm the size of the small set screws/plugs in the heads. You know the ones that snap the 5mm allen keys and always strip .
I know they are available as a dealer part at $5+, but I want to know the size so I can replace all of them at less than $5 ea.
from what I can measure, they are 1/8"-28 BSP(Taper)
Can anyone confirm my findings?
Thanks!
Eric
Mojambo is offline   Reply With Quote
Old 06-20-2013, 01:38 PM   #2
TheFugitiveMind
Member#: 98012
2006 Aspen White STi
2015 XV Limited - Orange!
Bump, looking for the same answer
TheFugitiveMind is offline   Reply With Quote
Old 06-20-2013, 01:45 PM   #3
Subie-Lifer
Member#: 344958
Where is the plug on the cylinder head I will try to look asap. But an easy way would be to use a box wrench to see the MM 10-12-14 ect. and the thread is probably a 1.25-1.5 thread
It probably won't be 1/8" considering it's metric. Put a pic up if possible or try breaking the old ones free with an impact driver like the one used to remove rotor screws. Hope it helps
Subie-Lifer is offline   Reply With Quote
Old 06-20-2013, 02:00 PM   #4
TheFugitiveMind
Member#: 98012
Not my pic, but it is the small plug to the left of the "B25" casting stamp.
There should be 6-8 of them per head and i think all the oil related items on the car are in PT or BST but not sure.
Thanks for the help!
Old 06-20-2013, 03:22 PM   #5
TheFugitiveMind
Member#: 98012
I think i found the size - 1/8"BPST
again, not my pic.
Link to buy - http://www.streettunedmotorsports.co..._bspt_plug.htm
Old 02-16-2015, 08:48 PM   #6
notaduc
Member#: 373327
They are definitely 1/8 BSPT
notaduc is online now   Reply With Quote
Old 02-17-2015, 07:34 AM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
Easiest way to remove them without destroying them is heat. Small map gas torch will get them loose
Sent from my iPad using NASIOC
sidewayz is offline   Reply With Quote
Old 02-17-2015, 01:47 PM   #8
ALOKIN
Member#: 348177
2013 WRX STI Limited
550whp IAG CD goodness
I used some fancy Loctite hydraulic sealant on them when reinstalling them too. Don't remember the number but its $60 for a small bottle. We use it for high-pressure (3K psi), high heat applications.
ALOKIN is offline   Reply With Quote
