Old 08-21-2012, 12:59 AM   #51
altezza2impreza
Member#: 95516
I love this, but If I bought an n7 I would want the ability to remove it with little ease. This would also pose a problem with theft, but it would be as simple as removing it and hiding it under the seat taking it in the house etc. I'm going to look into this. Thanks and great job!!!!
altezza2impreza is offline   Reply With Quote
Old 08-21-2012, 11:57 AM   #52
Shiv9
Member#: 329699
I was going to do that but I got a really good deal on an avic before the 7 come out.
I'd suggest dropping the HU for a signal processor or installing the HU in the rear with a remote face.
Shiv9 is offline   Reply With Quote
Old 08-29-2012, 10:45 PM   #53
black thunder
Member#: 210047
im a scooby guru
really
last piece of the puzzle. torque app for engine diagnostics
needs some tweaking tho
black thunder is offline   Reply With Quote
Old 09-17-2012, 06:30 PM   #54
pikebike
Member#: 272991
this has so much awesome.
Are there any adapters to allow use of the steering wheel controls, or is that asking too much?
Also, in some of your pics it looks like there's a slight difference between the left and right bezel overhang. Is that just bad picture angles or is it actually like that?
pikebike is offline   Reply With Quote
Old 09-17-2012, 11:21 PM   #55
blessthekellen
Member#: 273859
MY98
WRX
Absolutely you could do steering wheel controls.
You just need to do an aftermarket deck that has the option for it, then buy the module for it and wire it up (:
blessthekellen is offline   Reply With Quote
Old 09-23-2012, 06:31 PM   #56
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
why not use an Alpine KTP 445 for an amplifier, and then you can just use the Nexus to control the volume output? would make for a much simplier install i think.
Old 09-25-2012, 12:54 AM   #57
minhha2006
Member#: 154914
2005 WRX
UGM
Any updates?
minhha2006 is offline   Reply With Quote
Old 09-25-2012, 04:59 PM   #58
black thunder
Member#: 210047
im a scooby guru
really
its in there centered and symmetrical
not audio savvy enough to know that
Originally Posted by minhha2006 View Post
Any updates?
nothing new to update. been using it perfectly since last update. only thing i havent figured out is the charging issue. but the nexus will last 4-5 days on a charge so i just pop it out and charge on the weekends.
Old 09-25-2012, 05:11 PM   #59
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
you would just need a 3.5mm to RCA cord to hook up to the amp.
Old 09-25-2012, 06:55 PM   #60
black thunder
Member#: 210047
im a scooby guru
really
true, i do have the cable already. whats a good amp?
Old 09-25-2012, 07:25 PM   #61
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I just put a ktp445 in my car, I'm impressed with it. You could ditch the hu if you went that route
Old 09-25-2012, 07:48 PM   #62
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
That is awesome bro...
uspopo is offline   Reply With Quote
Old 09-26-2012, 07:04 AM   #63
band wagon
Member#: 273851
03 wrx
how did you get your icons on the bottom instead of the top? My setup is similar and i think its better to still run a radio. I currently use slacker as my primary source for audio and the radio comes in use when my doesn't have service or slacker is acting up
band wagon is offline   Reply With Quote
Old 09-26-2012, 09:47 AM   #64
black thunder
Member#: 210047
im a scooby guru
really
those buttons are from an app called media buttons. they used to work on my kindle but dont work on my nexus 7 yet probably because of jelly bean
Old 10-04-2012, 09:10 PM   #65
ta_forever
Member#: 305609
Would there be a way to hook a backup camera into this setup?
ta_forever is offline   Reply With Quote
Old 10-07-2012, 09:58 AM   #66
razrielle
Member#: 205698
so....heres my question. How do you turn the tablet on and off? Do you have it to where when it gets power the screen is always on? I dont have the Nexus 7 but every tablet I have seen has the power button on one of the sides.
razrielle is offline   Reply With Quote
Old 10-07-2012, 07:11 PM   #67
03WrxWagon112
Member#: 334412
02 Wrx
That is fantastic
03WrxWagon112 is offline   Reply With Quote
Old 10-09-2012, 01:32 AM   #68
black thunder
Member#: 210047
im a scooby guru
really
i dunno maybe. look in the app store if theres a corresponding app then you got your answer.
its linked to the cars ignition. so when i turn on the car accessories itll turn on the tablet screen. when i turn it off, itll turn off the screen on the tablet but not completely shut down. all this is done thru the tasker app which basically has a task to follow if the usb is plugged (car on) or unplugged (car off). i do have a widget button to do a hard reset tho if needed.
Old 10-10-2012, 02:49 PM   #69
SPIRK
Member#: 251707
2011 WRX 4d Wingless
Wire in an aux 12V accessory plug (lighter port) and plug a 1 amp usb charger into it. They sell them at any parts store and they're pretty simple to install. It will turn on and off with the car and keep the nexus charged enough to where you never have to remove it.
SPIRK is offline   Reply With Quote
Old 12-10-2012, 01:40 AM   #70
konradlip
Member#: 324795
2004 WRX wagon
I love this post. I'm going to do something similar to this. I really don't want to use a radio since it will be an extra battery drainage. I found that a Clarion Equalizer does the job even better than a radio since it have 7v outputs and I don't even use the radio. A good place to mount it will be where the cup holder is. Also to make it look more fancy i would trim the radio bezel so you can see the whole black glass screen of the nexus. This would also bring it closer. I do have a question about the wiring tho. How it the battery holding up? Did the nexus die on you yet?
konradlip is offline   Reply With Quote
Old 12-12-2012, 10:12 AM   #71
jcolomde
Member#: 339410
2005 STI
Is that app accurate? how does it get the readings?
jcolomde is offline   Reply With Quote
Old 12-12-2012, 10:36 AM   #72
luan87us
Member#: 335013
2013 Premium WRX 5dr
There's a few type of bluetooth OBD II scanner you can use with android devices.
Old 12-12-2012, 11:18 AM   #73
jcolomde
Member#: 339410
2005 STI
ohhh okay.. well they plug the same place that my AP does so that kills that idea lol. thanks
Old 12-12-2012, 12:11 PM   #74
luan87us
Member#: 335013
Well do you have to have your AP plug in all the time? I thought once you flash the ECU you can remove the AP. Just use the tablet as the info screen for your ECU instead of the AP.
Old 12-12-2012, 01:43 PM   #75
jcolomde
Member#: 339410
2005 STI
I'll have to find out if ALL the settings get saved on to the ecu.
