Old 12-02-2012, 03:14 PM   #126
Geerolla
Member#: 264827
2011 2.5i 5D
Many thanks for this. Set Loudness off and put it on Through Mode... much, much better.
Geerolla is offline   Reply With Quote
Old 12-06-2012, 09:21 PM   #127
SubiGT
Member#: 195841
2012 2.0i Sport Premium 5MT, Kicker Audio Package/Sub. Wife was pulling her hair out, that's how craptacular this thing sounded.
Before, was faded 3R, B -1. Just did the Loud off, EQ through. O.M.G. Now F0, B2, M1, T3. Sounds sooo much better. The Kickers actually do a pretty good job now!!
I had checked this thread and the others in the past, but a buddy told me it was updated with hidden menus for the Premium. Awesome!!
Didn't tell her I made adjustments. See if she figures it out....
SubiGT is offline   Reply With Quote
Old 12-07-2012, 03:33 PM   #128
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Did this the other day, so much less "booming" now. I also balanced the eq so that the bass was set to 0, the mid at -5, and the treb at -2. gives the same balance that I had before, but its not over-driving the speakers to get it. Sounds a ton better.
riccnick is offline   Reply With Quote
Old 12-07-2012, 04:12 PM   #129
wondras
Member#: 337076
2013 XV Crosstrek
Post
I'm so happy this is working out for people!
I just learned that the loudness sometimes turns itself back on if the battery is disconnected for a long period of time. It's strange that a hidden setting wouldn't be persistent, but hey, at least it's there.
It *does* remember the Sedan/Wagon/Through EQ setting, though.
wondras is offline   Reply With Quote
Old 12-08-2012, 05:12 PM   #130
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
Thank you for this hidden option!
I was really disappointed with the stock stereo sound, now at least I am okay with it till I replace the HU early next year. The default EQ settings seemed to hide entire segments of frequency playback, heavy bass in some frequencies, none in others. I kind of want to know how they came upon that stock EQ.
DKsiazek is offline   Reply With Quote
Old 12-10-2012, 10:43 PM   #131
mixplate
Member#: 340257
2011 WRX Limited
Another happy owner here! Thanks to all who made this possible!! I was ready to go out and buy some speakers! I still may buy a small sub later to give it some bass though...
mixplate is offline   Reply With Quote
Old 12-10-2012, 10:44 PM   #132
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
people in their early 20's want bass
Old 12-11-2012, 04:07 AM   #133
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Folks -- please post your radio model number (the one printed on the front), especially if it's a new one nobody else has documented here.
Old 12-11-2012, 10:49 PM   #134
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
I am in my mid 20's... I do like bass, but only if it is clean. Booming sucks.
Old 12-12-2012, 11:22 AM   #135
db9
Member#: 302440
Default Additional settings for SAT available?
While the Stereo in my 2012 Forester Touring (CP625U1) is OK I have a issue with the built in SAT side of the unit.
Can someone tell me why the display can't work like most FM stations, when on FM - the display can be set to scroll the station, artist and song.. so why can't the SAT system do the same? Is there a firmware upgrade or setting that I'm missing?
db9 is offline   Reply With Quote
Old 12-12-2012, 11:35 AM   #136
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That would be nice
Old 12-13-2012, 04:57 PM   #137
msuth1
Member#: 338505
This has also been driving me insane. Every mode scrolls except SAT. And that's the mode I use most! Everyone at Subaru has told me it just is the way it is and is likely an oversight.
msuth1 is offline   Reply With Quote
Old 12-13-2012, 09:55 PM   #138
Jejunum
Member#: 15773
2011 Impreza WRX
our (2011 wrx) mp3 via usb and cd doesn't scroll either.
Jejunum is offline   Reply With Quote
Old 12-14-2012, 12:05 PM   #139
screemindemon
Member#: 340596
2011 Impreza2.5iPrem
white
Default Worked perfectly!
Originally Posted by wondras View Post
YES, WE CAN!
I just picked up a 2013 Crosstrek with the CM621UB HU. (Do I get partial credit for having most of an Impreza?) By piecing together info from various posts here, the service manual, and documents filed with the FCC, I figured out that it *is* possible to disable both the loudness and fixed EQ.
To turn loudness on or off:
With the unit ON, press and hold 1, 6, and TUNE (right knob.) The display shows LOUD OFF or LOUD ON.
To disable fixed EQ:
With the unit OFF, press one of these combinations of buttons:
1 + 2 + TUNE for SEDAN
1 + 3 + TUNE for WAGON
1 + 4 + TUNE for THROUGH MODE
With these "features" disabled, it sounds significantly less awful, especially at lower volume levels. This should make it a much better candidate for use with upgraded speakers, or a line out converter and amps. From the schematics, I think it would be fairly easy to add proper RCA line outputs as well.
I don't know if these keys will work on earlier models, but hopefully they do.
Fantastic forum you've got here!
Muchas gracias! Both loudness and eq changes worked perfectly on my 2011 impreza 2.5i premium (CZ624U1). Might leave HU in a while longer and upgrade speakers / amp first!
screemindemon is offline   Reply With Quote
Old 12-14-2012, 01:37 PM   #140
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Thank you wondras and JohnNevets! I knew the components I'm running were capable of better sound. I was ready to give up on this head unit. I have it set to through mode, no loudness, flat tone. The improvement in clarity and imaging is significant and I no longer have to run bass at -7.
I also installed a subwoofer recently and was driving myself mad constantly adjusting the gain thanks to the 8dB swings of the loudness feature. Bass is consistent now and blends in much better.
Old 12-20-2012, 09:42 AM   #141
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Wow, you guys are amazing.... I gave up trying to find hidden settings for my CZ624U1 (12 WRX Limited sedan) after finding out most other Subie radios had them...
This. I stumbled on this thread trying to look up 96SVX info since I'm buying a AVIC-Z140BH early next year... Low and behold, the answers I've been searching for since I bought this car.
Loudness off, Through Mode: Suddenly, a wild subwoofer appears! I have a Rockford 2-channel pushing a Rockford 12 in the trunk, and I thought a bass bomb went off on this setting. Definitely cost me some ear health, use caution with this one.
Loudness off, Hatch Mode: Sounds less boomy than Through Mode, but definitely more boomy than Sedan mode. Obviously I'm running the sub off the rear speakers, probably the reason.
Loudness off, Sedan Mode: The Goldilocks fav porridge for my setup. The loudness off makes the sound at least passable until I get the new unit.
nightdown fox is offline   Reply With Quote
Old 12-20-2012, 11:32 AM   #142
bigalpha
Member#: 110485
2011 Impreza Outback
Originally Posted by carse View Post
CZ624U1
Loundness works but none of the EQ options.
Same HU - EQ options work, but not loudness.
bigalpha is offline   Reply With Quote
Old 12-20-2012, 01:15 PM   #143
screemindemon
Member#: 340596
white
Strangely, i was able to adjust the eq a few days ago. Today, i went to adjust and hu is behaving different. When this worked, "subaru" was displayed on hu. Now when i try, subaru displays but disappears rather quickly and hu goes dark.?
Old 12-20-2012, 01:28 PM   #144
screemindemon
Member#: 340596
white
Oops nevermind. It didnt respond because i was selecting option it was already set on. If you do this, it wont display anything.
Old 12-20-2012, 01:34 PM   #145
bigalpha
Member#: 110485
1 + 6 + TUNE still doesn't change the loudness for me.
Old 12-20-2012, 02:23 PM   #146
wondras
Member#: 337076
2013 XV Crosstrek
Back in this post you can see that the bass is seriously cut to the rears in the sedan and wagon EQ modes. I suggested caution to avoid damage to the rears, but I didn't think about the ramifications of a sub on the rear outputs.
Which model do you have? When I tested the CZ624U1, sedan and wagon measurements appeared to be identical. It's possible I mixed them up somehow, though.
These settings work well for me with the stock non-upgrade 6-speaker system. I dropped the treble another notch or two and haven't touched it since. At medium-high volumes, I'd go so far as to say it sounds "good."
Are you doing this with the radio turned on? The EQ has to be set with the radio OFF, and the loudness is set with the radio ON.
Perhaps a video would be helpful...? It's easier to show than to describe.
Old 12-20-2012, 02:38 PM   #147
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
all 3 at the exact same time? it only works if you get them all at the same time
Old 12-20-2012, 02:40 PM   #148
bigalpha
Member#: 110485
Perhaps a video would be helpful...? It's easier to show than the describe.
Oh ...
I'm a dumbass
Old 12-20-2012, 10:24 PM   #149
Sti_Kent
Member#: 290645
2011 Sti Hatch
Im in a 2011 sti hatch, going to try playing with the radio tonight wish me luck!
Hopefully I will return with many thanks for the thread.
Sti_Kent is offline   Reply With Quote
Old 12-20-2012, 10:58 PM   #150
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Haha yeah I saw that post, but I had no idea it would be THAT ridiculous!
I've got the CZ624U1 and I could hear a difference based on the sub... But like butt dyno versus real dyno, my experience is completely subjective to your actual measurements.
2011+ Impreza head unit into 2009? codingparadox Car Audio, Video & Security 6 12-31-2011 12:48 AM
2011 Stock Head Unit Audio Playlist Options cheezmunky Car Audio, Video & Security 2 12-02-2011 10:09 AM
WTB : WTB - non-navi 2011+ OEM Head Unit with Bluetooth. ofspunk7 Private 'Wanted' Classifieds 2 10-25-2011 12:40 PM
2011 STi head unit w/o nav RCA PORTS? sk8dc10 Car Audio, Video & Security 5 11-06-2010 10:01 PM
2011 stock head unit wiring question subiebosch Car Audio, Video & Security 10 10-08-2010 09:21 AM
