Old 12-04-2012, 12:51 AM   #76
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Those cameras are fantastic tools. I wish I had one...
Old 12-04-2012, 02:24 AM   #77
Kyle_J
Member#: 292364
ISM
The dealership I work for has one, hmmm maybe they'll let me borrow it lol
Kyle_J is offline   Reply With Quote
Old 12-04-2012, 10:54 PM   #78
Kyle_J
Member#: 292364
ISM
Found a nice site for diagnosing different engine noises http://www.foxvalleymarc.com/Tech_se...ne_noises.html
Old 12-10-2012, 10:27 PM   #79
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
So.... any news?
Old 12-12-2012, 12:45 PM   #80
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
you should be able to unscrew a few 10mm bolts to pull the drvr side timing cover off and do a quick once over..
99imprezd is offline   Reply With Quote
Old 12-14-2012, 01:08 PM   #81
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Update yet?
05_wRex is offline   Reply With Quote
Old 12-16-2012, 12:18 AM   #82
Kyle_J
Member#: 292364
ISM
Pulling the motor right now. The suspense is killing me I'm probably gonna be up all night just so I can figure out whats wrong with it.
Old 12-16-2012, 12:24 AM   #83
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
cool, I'll go to bed and let you work. I look forward to results and pics
SenorDucK is offline   Reply With Quote
Old 12-16-2012, 07:01 PM   #84
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Sooooo?
Flat 4 Motorsport is offline   Reply With Quote
Old 12-16-2012, 07:10 PM   #85
05_wRex
Member#: 170097
Originally Posted by Flat 4 Motorsport View Post
Sooooo?
What he said. Lol.
Old 12-16-2012, 07:22 PM   #86
Kyle_J
Member#: 292364
ISM
The cam gear bolts are holding me back right now. I'm gonna go and see if I can find a 1/2-3/8 adapter quick so I can use my impact to get them loose
Old 12-16-2012, 08:22 PM   #87
TwinscrollGT35R
Member#: 256810
Are you not checking the valve lash 1st?
TwinscrollGT35R is offline   Reply With Quote
Old 12-16-2012, 08:34 PM   #88
Kyle_J
Member#: 292364
ISM
I did that while it was in the car and it was still in spec. If I move the flywheel slightly I can hear and feel something loose inside the block
Old 12-17-2012, 11:14 AM   #89
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
That sound is exactly what my NA build sounded like. Mine was due to me using the wrong HG (a tiny bit too thin) & the piston tops crashing into the heads.
I had quite a few listen to it, but while everyone had guesses, piston top crash was not one of them.
Curious what you find out. Hope it's minor (other than pulling the engine yet again.....)
Old 12-18-2012, 01:49 AM   #90
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Updates?!
ckyguy68 is offline   Reply With Quote
Old 12-18-2012, 09:40 PM   #91
Kyle_J
Member#: 292364
ISM
The play I could feel in the rotating assembly was the crank sprocket shifting back and forth on the crankshaft. For the drivers side head off and everything looks normal so far. I'm going to pop those two pistons out tmr after work and see what the wrist pins look like
Old 12-18-2012, 11:50 PM   #92
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
You could take the oil pan off and wiggle the rod if you suspect a bad rod bearing. Good luck let us know how you make out.
Old 12-19-2012, 01:17 PM   #93
Maxwell Power
Member#: 190729
There shouldn't be any play at all.... Maybe you found the cause right there.
Maxwell Power is offline   Reply With Quote
Old 12-19-2012, 01:23 PM   #94
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yup take off the oil pan and have a friend hold a breaker bar with a 22mm socket on the crank bolt while you examine the rod's closely have him wiggle it back and forth. Good luck Sr.
Old 01-05-2013, 08:34 PM   #95
Kyle_J
Member#: 292364
ISM
UPDATE!!! Finally had some more time to pull 2&4 pistons out. Whoever was betting on cyl 2 wrist pin you are a winnar! Ill get some pics up in a bit
Old 01-05-2013, 09:45 PM   #96
Kyle_J
Member#: 292364
ISM
This is the piston and wrist pin from cyl 2
And this is the piston from cyl 4
And for ****s and giggles my wrist pin and piston removal tools made from battery holddowns lol
Old 01-06-2013, 01:38 AM   #97
TwinscrollGT35R
Member#: 256810
Oh snap! Glad you caught that.
JE pistons huh. Do you know what the clearances were?
Old 01-06-2013, 02:22 AM   #98
Kyle_J
Member#: 292364
ISM
I never checked wrist pin clearances, everything was new so I didn't think I'd have any issues. Now to see if JE will sell me one piston and if I can press a new bushing into the connecting rod
Old 01-06-2013, 02:58 AM   #99
TwinscrollGT35R
Member#: 256810
I'd pull that whole engine down and inspect it. Main bearings and all.
Old 01-06-2013, 03:32 AM   #100
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Hey you used my battery hook trick
That's ****ty man Look's like an oiling issue from the rod. How's the rod bearings look on the cylinders with the scored pin's?
Do you know bearing clearance? Who built this engine? Was oil pump packed for start up? Look's like it happened on start up.
BUT WHAT DO I KNOW LOL
