Old 11-10-2012, 05:32 PM   #26
von Wachtstain
Member#: 52726
Originally Posted by hanta20 View Post
Do you have any other images of the car with the steel wheels on taking further back (ie. so you can see the whole side profile of the car with the wheels)???
Yup. Car is dirty after the storm. I included one picture with Rotas on the car.
von Wachtstain is offline   Reply With Quote
Old 11-10-2012, 07:49 PM   #27
hanta20
Member#: 320594
2012 Impreza Limited
Dark Gray Mettalic
Awesome! Thanks so much. Where did you get your wheels from?
hanta20 is offline   Reply With Quote
Old 11-10-2012, 08:09 PM   #28
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
A bit off topic, how's your paint after the snowstorm? Mine is a bit scratched up, the DGM scratches so easily.
Old 11-10-2012, 08:38 PM   #29
von Wachtstain
Member#: 52726
I hear ya. But this snowstorm wasn't that bad so no additional imperfections or at least I dont see any YET. Still I like this color.
Old 11-10-2012, 08:39 PM   #30
von Wachtstain
Member#: 52726
Tirerack
Old 11-10-2012, 09:34 PM   #31
pkL
Member#: 313093
2012 Impreza 2.0i
I love the color too but the starches are so obvious when you get one. Even light scratches or minor ones in the clear coat appear to be white and stick out like a sore thumb.
Old 11-11-2012, 01:56 AM   #32
HinGurl
Member#: 293678
2012 Impreza 2.0i
5 Door Limited. Silver
Newbie question: I know if you don't install TPMS on your winter tire/wheel setup, you get the light on the dashboard. But what happens when you install your summer tire/wheel setup after a few months, when winter is over? Will the light on the dashboard not light up like normal, or since the wheels/tire haven't been on for a while you have to "reset" something?
HinGurl is offline   Reply With Quote
Old 11-11-2012, 04:04 AM   #33
pkL
Member#: 313093
2012 Impreza 2.0i
The TPMS light will turn off once you have your OEM rims and tires with TPMS mounted again. I haven't had to "reset" anything yet.
Old 11-11-2012, 07:24 AM   #34
finklejag
Member#: 318622
2012 Impreza
What's the offset of these Tirerack wheels? The rear looks like a space saver spare. Does these wheels need hub rings?
finklejag is offline   Reply With Quote
Old 11-11-2012, 08:35 AM   #35
von Wachtstain
Member#: 52726
Offset on these is 50mm. So only 2mm difference. Reason they look weird is probably because tires are 195/60/16.
I really hate doing tirerack job and free advertising since they really messed up my wheels. Every single one came scratched up. I imagine they have monkeys mounting tires Ha! Amazon sells the same for cheaper. But last time I checked no winter tires and no free mounting. They will ship for free though. If I could do it again I would get them from amazon. I am really mad about all the scratches.
Old 11-11-2012, 08:49 AM   #36
hanta20
Member#: 320594
Dark Gray Mettalic
Disappointing to hear that. It seems TR is my only options as the local shops are equally if not more expensive even when including TR shipping plus I would have to get TPMS to have the car "legal." My one concern with TR UPS shipping is if there is a signature required or do they just leave 4 huge tires on your front step? I work until early evening so I don't want someone to walk off with my tires, but at the same time I want to make sure they actually get delivered without anyone being home. Would love to hear your experience on that end of the transaction!
Old 11-11-2012, 09:41 AM   #37
von Wachtstain
Member#: 52726
Two years ago they just left tires on my porch even though I have sign "do not leave packages here" I don't live in bad area but packages get "lost" So this year I went to distribution center to pick it up myself.
Old 11-11-2012, 10:49 AM   #38
HinGurl
Member#: 293678
2012 Impreza 2.0i
From what I read, they don't have to install TPMS if you put the tires and wheels on your car yourself. If I understand it correctly, you can just have them mount the tires to the wheels, without TPMS. Take them home and do the install yourself. Is this correct? This is how Tire Rack is able to sell you non TPMS combos. They even have a disclaimer about this during checkout.
However, if your state requires you to have TPMS, then you need them regardless of who does installation. I live in Missouri so TPMS is not required to pass inspection, but for the states who require them, just place your summer tires on. I have never heard anyone getting a ticket for not having TPMS installed.
Old 11-11-2012, 01:07 PM   #39
hanta20
Member#: 320594
Dark Gray Mettalic
That seems to be correct. I just order them off of TR mounted and balanced without TPMS so I will just have to swap them onto the car. I am glad my inspection is in October so hopefully I can pass with flying colors with my summers on!
Old 11-11-2012, 09:09 PM   #40
pkL
Member#: 313093
2012 Impreza 2.0i
Be glad they are just steelies, if the scratches really bother you that much you can touch them up with black paint or plasti dip them I guess.
Old 11-13-2012, 09:56 AM   #41
von Wachtstain
Member#: 52726
True and I don't mind doing that especially when wheels are on the car for some time. You are bound to collect some scratches. But to have them look all scratched up BEFORE you even put them on blows my mind.
Old 11-13-2012, 10:18 AM   #42
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
I'm sure you had reached out to them but if you didn't, you should. They had mounted a directional tire on backwards on a set I had ordered with my last car. I had the shop flip the Tire and Tire Rack cut me a check. Maybe they will do something? Figured I'd put my $0.02 in.
-Brian
BoxerSport2.0 is offline   Reply With Quote
Old 11-13-2012, 11:06 AM   #43
von Wachtstain
Member#: 52726
I would if they were aluminum rims. Thanks for advice nonetheless
Old 11-13-2012, 06:24 PM   #44
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
I understand, you're very welcome.
Old 12-12-2012, 02:21 PM   #45
subie_lawyer
Member#: 312236
12 Imp Sport black
12 Imp Prm sdn DGM-wife's
Bump.
Anyone else have steelies on their '12 or '13 Impreza? I'm thinking about getting some for my '12 Sport and wondering if anyone has a black set on their black Sport and could graciously provide pics?
subie_lawyer is offline   Reply With Quote
Old 12-12-2012, 02:34 PM   #46
M45
Member#: 333446
2013 Impreza SL CVT
Originally Posted by subie_lawyer View Post
Bump.
if I go with steel wheels I'm thinking of getting black covers for the wheels. I like to try to protect the hub and lugs a little bit from extra snow/salt/ice if possible.
M45 is offline   Reply With Quote
Old 12-12-2012, 02:50 PM   #47
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Bump.
Here's mine in oem steelies & Blizzaks.
Old 12-12-2012, 03:31 PM   #48
subie_lawyer
Member#: 312236
12 Imp Sport black
This might be a total n00b question, but when you say "OEM steelies" do you just mean the size? Or did you actually get these from Subaru? I'm presuming that they didn't come with your car since it looks like you have a Sport... And if you don't mind me asking, what are the size specs and how much did you pay for them?
Tirerack has a set of 16x6.5 for $58 each. I'm wondering if I can get some cheaper somehow...
Old 12-12-2012, 04:12 PM   #49
Angelus911
Member#: 89967
2012 Impreza Sport
I got a set of WRX wheels for mine with winter tires already on them for about $500 from a member on here. That's another option for some
Angelus911 is online now   Reply With Quote
Old 12-12-2012, 04:19 PM   #50
M45
Member#: 333446
2013 Impreza SL CVT
is there a way to filter the classifieds by region? pretty annoying to try to find stuff in there...
Message Board Statistics All times are GMT -4. The time now is 11:45 AM.
