Old 12-11-2012, 07:08 PM   #526
SubieEngineer
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
^ Yeah, that.
Originally Posted by Squidz View Post
Isn't that considered changing the pick-up point of the control arm? I see what you are saying, and agree with you, in fact i argued the same thing at a Divisional event...but have been told otherwise by some SCCA officials.
If *SP specifically allows offset suspension bushings, and alignment changes as a result of those bushings, then I don't see why an offset bushing that changes a suspension point wouldn't be allowed *SP and beyond. I'd challenge that to an SCCA official in a heartbeat.
This
Originally Posted by *SP
Suspension bushings may be replaced with bushings of any materials
(except metal) as long as they fit in the original location. Offset
bushings may be used.
Followed by this
Changes in alignment parameters which result directly from the use
of allowed components are permitted.
SubieEngineer is offline   Reply With Quote
Old 12-11-2012, 07:09 PM   #527
polyol
Member#: 73422
04 STi
JVP
You can change the mount...but it has to bolt into the stock location and the bushing cant be offset from the original location.
***^^^Beat me to it***
polyol is offline   Reply With Quote
Old 12-11-2012, 07:31 PM   #528
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Ah I stand corrected 16.1 E
But then thinking you can pick and choose between rule sets. I would choose the *sp bushing language for this paticular mod and leave the mount alone on the cheap if I read that correctly.
Or build control arms with all the geometry you want and use spherical that attach to factory locations. If money is of no interest.
I think I've had this conversation with myself before...
mccanixx is offline   Reply With Quote
Old 12-11-2012, 08:06 PM   #529
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Originally Posted by mccanixx View Post
HA!!! Sorry. You know why I'm peaking in here more lately...
hmmm 9k revving SM goodness for 2014
Bring it surfer boy. My little white GC will totally spank that black bugeye of yours
Also, if you're thinking of running the 2.3 deal, after chatting around the consensus was it's not worth it unless you bore it back to 2.5 for the low end torque. I know it's not as big of a deal at the big show, but just sharing the 20 minutes of talking I did.
subydude is offline   Reply With Quote
Old 12-11-2012, 08:54 PM   #530
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
btw I dig yer bugeye!
Thanks! She's a lot of fun so far.
This is pretty much the same thing i said...offset bushings are not legal.
ALK attaches in the stock location...and is not legal because it relocates the bushing even though it mounts to the stock location. So, again, confused.
I was gonna ask about 16.1 E up top...but i see you already stumbled across it. It's a slippery slope...agreed. I however, did loose this argument with a protest at one of our Divisional races.
I see what you mean about the ruleset not lining up there...you should be able to use the *SP ruleset and call it a day. I would think as long as the housing remains stock, the bushing should fall under the open bushing rules...but they claim the bushing is the pickup point for the control arm...which isn't wrong either.
Anyone else been involved in a protest or decision on this topic?
Squidz is offline   Reply With Quote
Old 12-11-2012, 08:56 PM   #531
polyol
Member#: 73422
04 STi
JVP
But ALK attaches in the stock location...and is not legal because it relocates the bushing even though it mounts to the stock location.
Correct...
Old 12-11-2012, 09:39 PM   #532
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
It's the pick and choose part that makes the bushing legal if you don't choose the other allowance. 16.1 B
I don't know if it's still [email protected] anymore or if there is a different email address for technical, rule questions now. That is who I'd ask for clarification.
My car would be SM legal coming from ESP. I have them.
Old 12-11-2012, 10:02 PM   #533
subydude
Member#: 80649
It's still bharmer and that's who I asked for clarification.
Old 12-12-2012, 04:21 AM   #534
griceiv
Member#: 162781
parts that move with vertical suspension displacement are unrestricted in SM. the bushing housing pretty clearly doesn't move when you displace the suspension (it is bolted to the chassis afterall) so you don't have any allowance to modify it. however one could make an argument that the bushing itself does move with vertical suspension displacement (via compliance or rotation, etc) and thus is unrestricted.
so an ALK that uses a replacement bushing housing that does not match the stock part dimensionally is illegal but an ALK that uses offset bushings inside a stock (or stock sized alternate per 16.1.P) bushing housing is legal.
griceiv is offline   Reply With Quote
Old 12-12-2012, 08:39 AM   #535
Leafy
Member#: 330625
2006 WRX
Offset bushings as explicitly allowed. We had the ALK protest in ASP at our national tour. The protestor achieved the effect with offset bushings the protestee used the offset mounts. The protest was upheld.
Old 12-12-2012, 05:02 PM   #536
polyol
Member#: 73422
04 STi
JVP
lol...all of this over a modification that would be lucky to net you a tenth.
Old 12-12-2012, 06:32 PM   #537
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Add them up
Old 12-18-2012, 08:40 PM   #538
polyol
Member#: 73422
04 STi
JVP
Add them up
Truth...
Old 12-19-2012, 08:48 AM   #539
Boxologist
Member#: 21118
not the point. The ALK can simply be resolved w/ a 0.1s penalty if it goes to protest. The issue is what does taking the ALK to an extreme mean? You're changing a suspension pick up point so why not change the point much further so it actually can make a huge difference. Take it further, what happens when your competitor changes a suspension pick up point and that different car is dramtically different. That's what is important to stress to the n00bs who don't understand why SCCA classes are seperated the way they are.
Boxologist is online now   Reply With Quote
Old 12-19-2012, 11:09 AM   #540
subydude
Member#: 80649
Truth...
One of my cousins went through boot camp and came back with a saying that applies to cars as well as ruck sacks. Ounces make pounds and pounds make pain. Even if it's only shaving an ounce here or there, or making a small modification, they all add up.
I've had a lot of people ask why their 2.5rs hood on a regular L impreza puts them in SM. After showing them a 2 lbs carbon hood that will almost bend in half it's so flimsy they get the point. The rules aren't built to be unfair, they're built to allow modifications far beyond what the noobs consider.
Old 12-19-2012, 11:26 AM   #541
polyol
Member#: 73422
04 STi
JVP
No no, I get it.
My point, (and this goes around in circles at my local club every year) is WRX/STi's show up (usually noobs) jump into SM and the ALK conversation always comes up and I have to explain. I usually dont even care if they do stay in SM because they are rarely a threat.
In the end there are other legal ways to gain caster than changing the lower suspension pickup geometry.
Old 03-18-2013, 02:01 PM   #542
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Crawford got 412WHP/453LB-FT out of their 2.0L BRZ at the Modified magazine shootout. Tons of low end torque.
The Innovate twin-screw supercharger also did well.
Now where is my extra $20K!
dwx is offline   Reply With Quote
Old 03-31-2013, 11:52 AM   #543
visibiliti
Member#: 211987
2004 STi
Hey guys, I am having trouble with figuring out an interpretation of the SM rules on the subject of engine bay bracketry.
We know from 16.1.D that drivetrain components are unrestricted (other than limitations on block origin, displacement, and fuel system requirements). Here are my questions on this:
(1) Is this rule why it is legal to run a turbo blanket or header/UP/DP wrap?
(2) Does this rule mean that ANY brackets in the engine bay are removable/replaceable?
(3) Does this rule mean that only brackets attached to the engine block itself are removable/replaceable?
My guesses are:
(1) Yes?
(2) No; only if they interfere with the new engine block you swap into the car (see minor bending, notching, adjustment rule)
(3) Maybe? If they allow complete engine swaps and say that drivetrain is "unrestricted", then can we say any bracket attached to said drivetrain part (engine) is part of the drivetrain?
(3) confuses me, because I would like to look into a lightweight alternator bracket now that I have removed my a/c system. But it seems like the rules are pretty specific on other things that can be removed or replaced. There is really no nomenclature in the rules on bracketry or coatings/wraps, which is why I wanted to ask you guys what your interpretation is.
visibiliti is offline   Reply With Quote
Old 04-01-2013, 08:40 AM   #544
Leafy
Member#: 330625
2006 WRX
Well you can run whatever alternator you want so long as it outputs the same or more than stock, so you should be allowed to modify/replace the bracket for it. Though I would say any bracket on the engine and almost all the ones in the engine bay can be removed from one allowance or another, at worst it would be one of the most weiny protests ever.
Old 04-01-2013, 10:14 AM   #545
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah considering you can swap the entire engine and the one you put in there might have a different alternator bracket I think you are probably safe.
I have a non-AC Impreza alternator bracket for sale if you want one.
Old 04-01-2013, 11:48 AM   #546
subydude
Member#: 80649
What does the non-AC bracket weigh? I pulled the AC off a long time ago, but left the big aluminum piece as there was other low hanging fruit. I'll likely build my own, but just curious on weight.
For the brackets, anything that attaches to the engine/trans/rear end/whatever I'll remove if it's not used. Example: the green brackets of death over the injectors were gone almost immediately. Any bracket that was used to hold an emissions sensor or what not has also been removed. The brakes and uprights are open, so you can remove bits there and grind on them if you wanted too.
Old 04-01-2013, 11:50 AM   #547
Leafy
Member#: 330625
2006 WRX
Yeah on my SSM car I cut off a tab and ground on the tranny for down pipe clearance. And I've got a huge stack of wiring harness brackets from that car that went on parts of the engine harness that are either not used anymore (like air bags) or completely moved due to different sensor locations on the engine.
Old 04-01-2013, 12:40 PM   #548
visibiliti
Member#: 211987
2004 STi
Ok, I guess this was a case of me coming down with the stupids. I will admit that after removing the a/c compressor and looking at that 1/2" thick bracket that held the compressor and alternator, that I thought it was made of steel and weighed quite a bit.
If it is truly just made of aluminum, then maybe the weight savings would not be nearly as much as I originally assumed. Whoops!
I didn't take the time to take it off the car to see, since I needed to get the car back to driveable to go to work.
Anyways, it was more of a question of how you guys are using the rules to back up the various brackets you remove, or the wraps and blankets you use. I just want to make sure I understand the rules correctly.
Per leafy's comment- what allowance or rule allows you to remove brackets from the engine bay itself? (not connected to engine. let's say connected to engine bay or strut towers) Agreed it's weiny, but still want to tear out things correctly!
Old 04-01-2013, 12:47 PM   #549
Leafy
Member#: 330625
2006 WRX
It all depends on what the brackets are connected to. And I think there is a standing rule in SM to not be a ****.
Old 04-01-2013, 12:57 PM   #550
btrenhol
Member#: 135241
Old NWS
Shiny
Well guys I can no longer be in SM. Different front bumper beam did it (V Mount). Ideas on what class to go up to so I can start looking at rules?
btrenhol is offline   Reply With Quote
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
