Old 12-12-2012, 05:39 PM   #1
mash740
Member#: 310419
2002 wrx
Default ej20 pistons and rods
I have a ej20 and i'm needing some reccomendations on what kinda pistons and rods you guys think I should get.. I'm not doing anything crazy to it just want to have strong internals.
Thanks.
mash740 is offline   Reply With Quote
Old 12-12-2012, 06:24 PM   #2
04ScoobyWtf
Member#: 287974
04ScoobyWtf is offline   Reply With Quote
Old 12-12-2012, 07:33 PM   #3
tja1618
Member#: 181995
Before you rebuild that 2.0, why don't you sit back and think about what yourr budget is and what your end goals are. I was about to rebuild my 2.0L, even bought pistons and rods. Then I did more reading and talked to a few shops and it turns out buying a new 2.5L OEM STI block and machining the 2.0 heads for a hybrid wasn't that much more expensive than rebuilding the 2.0L. Not only that but you end up with a stronger, brand new motor.
Just take a look at a cheap hybrid build with an OEM shortblock before you commit to a 2.0L build.
Good luck!
tja1618 is offline   Reply With Quote
Old 12-14-2012, 08:17 PM   #4
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Good luck!
I conqur... go 2.5, you wont regret it
99imprezd is offline   Reply With Quote
