Old 12-05-2012, 01:27 PM   #551
RancerEvorution
Member#: 235190
2011 STi
Updates:
50-100mph Time: 7.39 seconds
^Sorry, I don't see 7 flat. Stepping frame by frame gives me 7.39 seconds. Still a great time. Very, very good shifts! My car on E85 did a similar time! You have more mods and better driving, which is quite an accomplishment to do on pump gas! My was also trapping around 110-112mph and made 340WHP on the dyno, so the 50-100mph metric does seem to correlate fairly well to trap and dyno numbers. I think you trapped higher recently, do you have any new 50-100mph video?
Thanks! My car just recently took the "stage 2" mph record on 93, trapped 114.7 in the 1/4 mile. It was less then 40 degrees out and I had removed some weight. Considering I had a 210lb passenger and trunk full of luggage when i recorded that video and the car was also full weight, i think i can shave a couple tenths off that time.
I'll be back !
RancerEvorution is offline   Reply With Quote
Old 12-05-2012, 01:48 PM   #552
idratherbesurfing
Member#: 282972
2006 Sti
cgm
Thanks..I made 294hp 320tq on AKUMA's mustang dyno. Im going to film another video 0-100 it should be faster and a better camera! lol
idratherbesurfing is offline   Reply With Quote
Old 12-05-2012, 02:55 PM   #553
07wrxstage2
Member#: 262366
07 wrx-sold 06sti-
sold 00rs-rip 05 GRP LGT
Decided to try a 50-100 pull real quick on my way home yesterday but im going to do it again in a couple days when I can mount my phone to the wheel. Didn't feel very confident at those speeds with one hand and didn't do a great job shifting. Certain I can do better!
4th-5th pull(Will do a 3rd and 4th next time to see the difference)
Vehicle: 2006 sti
Weight: stock
Mods:
Spt intake
Invidia divorced wastgate dp
Sr*s exhaust
cobb ots stage 2-93 octane
50-100MPH: Around 7.5-8 sec(Maybe someone can give me exact time)
NOTE: Also may want to do 51/52-101/102mph. Looks like I may have started my pull a little after 50mph.
07wrxstage2 is offline   Reply With Quote
Old 12-05-2012, 02:57 PM   #554
07wrxstage2
Member#: 262366
07 wrx-sold 06sti-
Fixed*
Old 12-05-2012, 05:09 PM   #555
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Updates:
50-100mph Time: 4.73 seconds
50-100mph Time: 6.16 seconds
^Is the DOM3 really slower than he Green? Or is it the tune? I double checked the video, and that time is right.
50-100mph Time: 4.52 seconds
^Your shifts are right at 100mph so it's hard to get a good time. You are probably a tenth or two quicker than this if the gearing matched up.
50-100mph Time: 4.3 seconds
^If only everyone had a VBOX! It would save me hours of stepping through low res cell phone videos!
50-100mph Time: 4.48 seconds
^This one is also hard to get a good time for because you brake boosted slightly over 50mph. Your car is obviously much faster than that 50-100mph time indicates. Maybe roll into it at 30 or 40mph and it will be somewhat spooled as it goes through 50mph?
50-100mph Time: 3.89 seconds
^That's fast!
50-100mph Time: 4.33 seconds
50-100mph Time: 6.99 seconds
^Didn't start at 50mph to it's hard to get an accurate time. Probably could be slightly quicker than what's listed above if you post a valid run.
50-100mph Time: 5.38 seconds 20psi
50-100mph Time: 4.91 seconds 24psi
50-100mph Time: 4.37 seconds 27psi
50-100mph Time: 7.83 seconds
^Hard to tell exactly because you didn't quite hit 100mph on the speedo.
50-100mph Time: 8.27 seconds
^Good baseline run. Nothing wrong with that time for the mods you have. What did Akuma's dyno say you made?
Damn, I didn't think me being 50 WHP down from lowering the boost would make that much of a difference!
Old 12-05-2012, 06:52 PM   #556
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'll be back !
Yeah, it should be able to do a little better time with the lower weight and temps.
Great. Good to have a reference point for the Stage 2 cars out there.
vid.mp4 video by wrxsti4life - Photobucket
Vehicle: 2006 sti
Weight: stock
Mods:
Spt intake
Sr*s exhaust
I'll take a look at this when I get a chance. Not being quite at 50mph makes it hard to compare though.
In my testing I found that each pound of boost lost about 15HP and 1/10th of a second off the 50-100mph time.
Old 12-06-2012, 12:11 AM   #557
dmjhockey19
Member#: 258009
04 sti
wrb
when i have more time to mess around with rev limit, more boost and some quicker shifting I should move up a few pegs. Hopefully i can get some sub 4's in to join you josh haha
dmjhockey19 is offline   Reply With Quote
Old 12-06-2012, 05:50 AM   #558
AirManCam
Member#: 219513
2006 STI
It's very well possible, your car is fast as hell man. Let's just hope that dom5 doesn't start huffing when you start raising the boost I think with e85 and the new intake manifold another and 100-125whp I should be able to hit 3.5s
AirManCam is offline   Reply With Quote
Old 12-06-2012, 07:49 AM   #559
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Didn't you hit around 3.8 or 3.9? From xlubens testing it seems every 15whp is good for 1/10 second off ur time. If that's the case about 75whp should have u at or below 3.5...
Slimsti is offline   Reply With Quote
Old 12-06-2012, 08:25 AM   #560
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
In my testing every 40WHP increase gave me 1/2 second. I think I did my math wrong before. That's 80WHP per second or 8WHP for 1/10 sec. That seems a little optimistic, but that's what I saw. Also consider that's within a limited range and also only using 1 gear. Peak power doesn't necessarily correlate to the powerband you have. Simple math says:
Code:
WHP    50-100
300    7.0
350    6.4
400    5.8
450    5.1
500    4.5
550    3.9
600    3.3
650    2.6
Overall it seems like it could be ballpark correct, but not perfect. I'm sure the linear relationship will not hold up with higher power (or possibly lower power). I will try to do a better correlation sometime. If more people had power numbers it would be a little easier..
Old 12-06-2012, 10:38 AM   #561
freshsti
Member#: 90099
2005 ewg gt52 sti
cgm
One day im going to give it a try.Gt52 with meth 390hp on mustang dyno.
freshsti is offline   Reply With Quote
Old 12-06-2012, 04:06 PM   #562
AirManCam
Member#: 219513
2006 STI
Yeah. Like I said, I'm still on pump gas and 24psi. Going to put E85 in and turn it up to 30 or so and do a few pulls. My tuner Visconti trapped 134mph with this setup at 26psi on e85 and his car is full weight..mine is much lighter.
Old 12-06-2012, 06:50 PM   #563
Slimsti
Member#: 155696
Jesus man u have a lot left in that thing. Not even with the e85 just off the extra 6lbs of boost you'll see 60-80 more whp. That cars already a beast... I need a bigger turbo. Lol
Old 12-08-2012, 05:24 PM   #564
theSlothy1
Member#: 173321
2007 SWP WRX
dom2.5xtr w/ meth & 6spd
My speedo is only in KPH, hope this is acceptable.
50m/h = 80.4672 Km/h
100m/h = 160.9348 Km/h
Vehicle: 07 WRX TR
Motor: Built EJ257
Turbo: Blouch Dom 2.5xtr 10cm
Boost: 21psi
Transmission: JDM Ver8 6spd
Redline: 6600
Upgrades:
... AWDtuning stage 2 shortblock, stock heads & cams
... id1000's
... KStech 73mm CAI
... Grimmspeed EBCS
... stock STI tmic
... 3" catted dp, 3" SRS baffled exhaust
... 91oct w/ meth injection
... e-tuned with Ron of Phatbotti tuning
Weight: 3500ish with me in it.
50-100MPH: 6.0
Start
End
theSlothy1 is offline   Reply With Quote
Old 12-13-2012, 09:08 AM   #565
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Here is a link to my baseline post with my setup:
7.83s vf39 16psi
I upped the boost to 18psi until 5500rpm tapering to around 16.5psi at 6500rpm...everything else is the same.
2-3-4, power shifting.
Frame by Frame in iMovie says 6.9 to 7.0 seconds. I'll wait for the official report.
Overall I am really happy with the way this car is performing.
I think it has a lot left on the table, but we'll see. Still on the stock WRX catback and TMIC...even has the stock plastic intercooler y-pipe.
I'm cheap.
tachrev is offline   Reply With Quote
Old 12-13-2012, 09:20 AM   #566
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's a nice improvement! I'll take a look at it sometime.
Old 12-13-2012, 09:36 AM   #567
tachrev
Member#: 115260
04 WRX
Thanks for all your work in this thread, it's a good one. It's great to be able to correlate a change in the tune to a change in performance. Then you know you're doing something right.
I'll be hitting the track next year as well, we'll see how it does there.
Hoping for low 12's, wishing for high 11's.
Old 12-18-2012, 09:49 AM   #568
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Just saw these two:
http://www.motortrend.com/roadtests/...gts/specs.html
2013 Corvette ZR1
50-100mph Time: 4.5 seconds
POWER (SAE NET) 638 hp @ 6500 rpm
TORQUE (SAE NET) 604 lb-ft @ 3800 rpm
WEIGHT TO POWER 5.2 lb/hp
CURB WEIGHT 3344 lb
ACCELERATION TO MPH
0-30 1.6 sec
0-40 2.2
0-50 2.8
0-60 3.4
0-70 4.3
0-80 5.1
0-90 6.0
0-100 7.3
QUARTER MILE 11.4 sec @ 128.8 mph
2013 SRT Viper GTS
POWER (SAE NET) 640 hp @ 6200 rpm
TORQUE (SAE NET) 600 lb-ft @ 5000 rpm
CURB WEIGHT 3357 lb
ACCELERATION TO MPH
0-30 1.5 sec
0-40 2.2
0-50 2.8
0-60 3.4
0-70 4.3
0-80 5.1
0-90 6.2
0-100 7.3
QUARTER MILE 11.4 sec @ 128.7 mph
I suppose I could scour the web for some more baseline numbers. The list in the first posts is a bit old now.
Old 12-18-2012, 10:57 AM   #569
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
I don't know much about the new Viper, but the ZR1 should be faster than 11.4s in the 1/4. Bad driver/track/tires. I've seen it pull 10.6 easy on stock tires, and 10.1 on sticky tires.
pet3r is offline   Reply With Quote
Old 12-18-2012, 11:14 AM   #570
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
ET varies a lot with launch. Trap and 50-100mph are less affected.
Old 12-18-2012, 11:32 AM   #571
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I don't trust GPS data on anything that accelerates this quickly and I don't trust logged VSS from driven wheels or the tranny, but that's the only option for most AWD cars. That said...here's the data.
User: jasv11
Vehicle: 1996 Subaru Impreza
Motor: Innovative Tuning built 2.5L STI
Turbo: 6262
Boost: 20-27psi
Transmission: Stock 6 Speed
Fuel: E85
Upgrades: many (drag car).
Weight: ~2750 with driver
50-100 MPH: 2.40-2.55 seconds (times recorded during back to back 9.5X second 1/4 mile drag passes at Midwest Subaru Shootout)
Logged at 25 HZ via ViPec from stock VSS sensor in transmission.
VSS calibration set on dyno with drag tires on.
Innovative Tuning is offline   Reply With Quote
Old 12-18-2012, 12:01 PM   #572
J_Maher_WRX
Member#: 290307
Sub 11 second isn't possible with a zr1 corvette on stock tires... And the stock tires they used were R-compound semi-slick tires with only an 80 tread wear... I would call them sticky....
J_Maher_WRX is offline   Reply With Quote
Old 12-18-2012, 12:06 PM   #573
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
User: jasv11
Turbo: 6262
Boost: 20-27psi
Fuel: E85
Great time! Have any video? What numbers did it do on the dyno?
I think he's referring to this list:
http://forums.corvetteforum.com/c6-c...fast-list.html
With the trap speeds they do, I'm sure it's possible to get into the 10's. Either way, the 50-100mph time is no launch related (although traction could be an issue with the RWD cars).
Old 12-19-2012, 03:12 PM   #574
radbitt
Member#: 309675
2012 WRX Premium
Lightning Red
I think you said logs were acceptable?
Here's the baseline for my WRX. Just shifting normally... no powershifting for me.
Vehicle: 2012 Subaru WRX
Motor: Stock
Turbo: Stock
Boost: 16.5
Transmission: Stock 5 Speed
Redline: Stock
Fuel: 93
Upgrades: Cobb Accessport - OTS Stage 1, 91 Oct
Weight: Stock
50-100MPH: 9.5 - 9.6sec
I know it's nothing impressive to you guys, but I'm interested in seeing how much of a difference stage 2 (and so on) will make with my own driving style.
radbitt is offline   Reply With Quote
Old 12-19-2012, 03:24 PM   #575
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep, that's perfect! It's great to have baseline numbers!
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
