Old 11-30-2012, 09:18 PM   #76
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
warantee? buy a honda..my 12 has had rotella and wix since 2k
BigRob74 is offline   Reply With Quote
Old 11-30-2012, 09:24 PM   #77
Slurpyy08wrx
Member#: 256155
Wix? Doesn't fram make wix? I use oem blue filters.
Slurpyy08wrx is offline   Reply With Quote
Old 12-01-2012, 07:38 AM   #78
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
Originally Posted by Slurpyy08wrx View Post
Wix? Doesn't fram make wix? .
no...
Old 12-01-2012, 09:59 AM   #79
bluesubie
Member#: 767
04 FXT
Originally Posted by WRXLTD View Post
Maybe you can shead some light Dennis as to why the foot notes in the owners manuals state verbiage along the lines of "Severe Conditions" requiring oil changes at 3750 miles, and that turbocharge engines automatically fall under these severe condition requirements.
I haven't seen that. Anyone have pics?
-Dennis
Old 12-01-2012, 01:13 PM   #80
kingme
Member#: 280943
'11 WRX
So Walmart doesn't have a 1 quart of t6 can I buy the shell T 15w-40 triple protection to add the last .4 quart? I did it on my 08 but not sure if its safe for my 2013?
You can use any synthetic you like. Last winter I was using 4 qts RT6 and topping off with Subaru Syn 5W-30.
kingme is offline   Reply With Quote
Old 12-02-2012, 12:59 AM   #81
thescreensavers
Member#: 333820
2013 WRX Limited
Notice to the right it states "Note 1"...what does Note 1 say?
Yup here you go
thescreensavers is offline   Reply With Quote
Old 12-02-2012, 10:14 AM   #82
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
Originally Posted by thescreensavers View Post
Yup here you go
Exactly. And while not on the list, spirited driving falls under severe conditions too. So unless your doing all highway cruising the oil should be changed at 3,750 unless you have UOA's proving your oil can go longer in your exact situation.
ERL2011wrx is offline   Reply With Quote
Old 12-02-2012, 11:00 AM   #83
sc00by4life
Member#: 97135
Yeah....I doubt that.
Old 12-02-2012, 11:30 AM   #84
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
You doubt the spirited driving falls under that category or that UOA is a good way to evaluate longer drain interval?
Ziggyrama is offline   Reply With Quote
Old 12-02-2012, 12:23 PM   #85
fresh_
Member#: 339465
Rotella all the way
fresh_ is offline   Reply With Quote
Old 12-02-2012, 02:29 PM   #86
sc00by4life
Member#: 97135
That spirited driving falls under severe conditions.
Old 12-02-2012, 04:04 PM   #87
ERL2011wrx
Member#: 268931
2012 wrx
ice silver
That's your call. I'm just not willing to save the $30 for an oil change every 3 months when I'm spending $55 when I get gas. At least not without a UOA.
Old 12-02-2012, 04:44 PM   #88
subi400
Member#: 216984
1996 Impreza outback
Green
Originally Posted by bluesubie View Post
There's a lot of misinformation in this thread, but i'm busy so I'll just respond quickly.
Subaru of America has allowed 7,500 intervals since mid-2011 MY.
http://drive.subaru.com/sum12_QuickStops.aspx
Yes, this is on 5W-30 and, as noted by others, the manual only refers to 5W-40 CONVENTIONAL for replenishment only. There is no such thing as 5W-40 conventional!!!
To those running Motul 5W-30, it is not API SN certified. IMO, this is a good thing but some people are afraid of not running SN oil. A dealer will not ask you if your oil is SN or not. Motul Eco-nergy is a thin 30 weight and is SL rated with a stronger anti-wear package. X-clean is a thick 30 weight that meets Euro ACEA A3 specs like GC. It also has a nice shot of zinc and meets API SM specs.
Amsoil OE and XL lines are fully API SN / ILSAC GF5 certified.
Mobil1 5w-30 API SM shears from just shaking the bottle, but the API SN has shown decent uoa results in a WRX. Check bitog. There's just not much data on it.
Rotella T6 meets API SM specs for gasoline engines.
Royal Purple xW-30 API SM has been shown to shear like Mobil1 and EVERY other Energy Conserving 5W-30. RP High Performance Street is their good non-girly man oil.
Reflash your ECU or mod your car and your powertrain warranty is out the window anyway. Warranty schmarranty. Buy M1 5W-30 for the receipt and exchange it for M1 0W-40. Not that I condone this behavior.
To those that think one or two random $30 uoa's are useful in comparing wear between brands, this is not true.
http://www.bobistheoilguy.com/used-oil-analysis/
Note that the manual says that 5W-30 synthetic is required for "optimum engine performance", not that 5W-30 API SN is required for warranty coverage. BTW, there is no industry definition of synthetic. It is only a marketing term.
-Dennis
The bold sentence up top would be a good thing for new 11-13 subaru wrx owners looking to stay with a 5w30 and in compliance with their warranty.
There needs to be a new thread stickied with the now available 5w30's that are good like this Motul X-clean 5w30
subi400 is offline   Reply With Quote
Old 12-02-2012, 07:00 PM   #89
thescreensavers
Member#: 333820
2013 WRX Limited
^ Yep looks like X-Clean is a good candidate since its a thick 30wt. Been going nuts trying to figure out what oil to buy lol
Edit: is the Motul energy/resource conserving?
Edit2: does not look like it. Would the dealers have an issue with this?
Old 12-13-2012, 03:25 PM   #90
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Is Castrol edge 5w 30 fine? Don't wanna start another oil thread lol.
13_DGM_Hatch is offline   Reply With Quote
Old 12-13-2012, 05:50 PM   #91
bluesubie
Member#: 767
04 FXT
Depends what you mean by fine. It's a Resource Conserving oil designed for fuel economy. The good Castrol 30 weight is Edge SPT 0W-30 (aka German Castrol/GC) which meets Euro ACEA A3 specs for shear stability, it has the old API SL additive pack, and meets a whole slew of German manufacturer specs.
If you drive like an old lady then Castrol Edge 5W-30 is fine. Want an oil that meets Porsche, VW, Mercedes, and BMW specs, then go for German Castrol 0W-30.
-Dennis
Old 12-13-2012, 11:06 PM   #92
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
-Dennis
So I have to drive like a grandma? Lol
Old 12-14-2012, 02:15 AM   #93
J-hop
Member#: 318428
To get that 71$ for a oil change is why they lied lol, you can change it yourself, but need proof of receipts and what not, I'm gonna go with rotella screw the dealership and oil changes ha.
Ok I am not understanding these "rip off" comments, ~$70 will be barely more than what you will pay for good oil and a filter.... That is a really good deal, my VW was ~$100 at the dealer when I used to get it done there.
Plus this is for a 2013 subaru wrx.... they were not meant to be wallet friendly vehicles.....
J-hop is offline   Reply With Quote
Old 12-14-2012, 07:43 AM   #94
sc00by4life
Member#: 97135
What?
4 quarts of royal purple is only $50, and an oem filter is $6.
Old 12-14-2012, 10:49 AM   #95
WRXLTD
Member#: 136314
2014 Grand Cherokee
4 quarts of royal purple is only $50.
What a rip off for that thin a$$ oil.
I'd pay the $5 per quart for Mobil 1 Extended 5w30 (when it goes on sale) before I'd buy Royal Piss.
WRXLTD is offline   Reply With Quote
Old 12-14-2012, 11:29 AM   #96
J-hop
Member#: 318428
What?
Yea so you save a measly $14 or so dollars.... Exactly my point.
Old 12-14-2012, 01:12 PM   #97
WRXLTD
Member#: 136314
2014 Grand Cherokee
When I change my oil myself, it costs me about $41.
5 quarts of Mobil 1 Extended 5w30 (bought on sale) and a Subaru oil filter (bought by the case on eBay)
Old 12-14-2012, 02:20 PM   #98
J-hop
Member#: 318428
I think my point has been lost, what I'm getting at in a round about way is if you are in the financial position to afford a 30k+ vehicle being charged $70 for an oil change isn't unreasonable in the least. Which is why I own a POS
Don't get me wrong I am all about saving money but still..
Old 12-14-2012, 02:42 PM   #99
WRXLTD
Member#: 136314
2014 Grand Cherokee
Do you think I change my own oil solely because of the money savings?
Hell no...I do it because:
a) I enjoy working on my own car
b) I don't trust the people who do oil changes at the dealership/Jiffy Lube
Old 12-14-2012, 02:57 PM   #100
dsn112
Member#: 332561
2016 WRX LTD
I use motul and it costs me $51. I do it because I enjoy it and because I hate to go to the dealer, spend $70 for oil that may not be as good, and then wait an hour or two, when I know they are spending most of that time not working on my cAr. Nothing worse than having an appt at. 10, then have your car sit outside till 10:45 before they start. Then they leave it to drain for like 10 mins and send you on your way.
Personally I am much happier popping the valve on my fumoto open letting it go for an hour while I have some coffee on my couch. Then coming out and swapping the filter, filling it up and being on my way.
dsn112 is offline   Reply With Quote
