Old 08-29-2012, 02:41 AM   #1
lj8915
Member#: 329252
2012 Subaru WRX
Default OEM HID headlights into base 2012 wrx?
Can I just buy the OEM headlights directly from the dealer and swap them in my base wrx (which has oem halogen headlights)? Is this a direct plug and play, or do I need to modify anything to make them fit, or mess with the stock wiring?
Thanks.
lj8915 is offline   Reply With Quote
Old 08-29-2012, 06:46 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes and no is the answer as if you buy all the stuff, it can be swapped relatively easy depending on your skills which is the X factor. You better check the price of the swap before you get wrapped around the axle though as it will be damn expensive. Why swap to HID when you can get bulbs for your car that will OUTPERFORM the HID lighting for less than $50 from www.danielsternlighting.com is the real question though.
Old 08-29-2012, 09:17 AM   #3
Wrexflex
Member#: 326301
2012 WRX LR - Sold
2015 Forester Premium CBS
The answer is Yes. I just did it. 2011 HID's into a base 2012 wrx, perfect bolt-in, plug and play. As long as you get the ballasts and everything you need, it will work great.
Wrexflex is offline   Reply With Quote
Old 08-29-2012, 12:51 PM   #4
lj8915
Member#: 329252
2012 Subaru WRX
I'm sorry, but halogen bulbs will never outperform a true hid setup. I already have the h9 swap in my car.
Old 08-29-2012, 12:59 PM   #5
xbeamelite
Member#: 281250
2007 STi Ltd
UGM
^ agreed and I did contact Daniel Sterling. Although a big improvement from stock (and cheap, just bulbs), one day I will still be retrofitting.
xbeamelite is offline   Reply With Quote
Old 08-29-2012, 02:01 PM   #6
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Keep in mind you won't have the power adjustment for beam height so aim accordingly.
Old 08-29-2012, 02:20 PM   #7
Vossatron
Member#: 276634
2011 4dr WRX
SSM Whale Tail
How much did this cost you? Do you have the power beam height adjustability?
Vossatron is offline   Reply With Quote
Old 08-29-2012, 03:30 PM   #8
mattesonb
Member#: 139607
DGM Wrapped Satin Black
i have 2012 sti headlights in my 11 base wrx. everything is plug and play except the leveling motors.
look in my previous post history if you want to see how to add the leveling
here are the details
its a pretty intense process but its doable. i tracked everything as i did it, this post has all the details to make it work.
this has all the wiring details http://www.hidplanet.com/forums/show...in-11-base-WRX
you will need the leveling switch (i got mine off ebay, and 08+ sti and wrx premium came with the switch) http://www.ebay.com/itm/220984809824...824%26_rdc%3D1
2 triangle shaped plugs that can be purchased from toyota suppliers http://www.toyotapartszone.com/oem/90980-11016.html
6 wires to go into the 2 plugs from the same toyota supplier http://www.toyotapartszone.com/oem/t...998-12440.html
then you basically tap your power and ground to the switch from the dimmer switch next to it behind the dash.
you pas 2 wires through the firewall to the headlights (the one that tells them when to move)
and you tap power and ground in the engine bay for the levelers (i tapped into my hella horns for this)
mattesonb is offline   Reply With Quote
Old 08-29-2012, 05:15 PM   #9
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
+1.
Average halogen headlight: 1800 lumens
Average HID headlight at 4300K: 3200 lumens
Difference: 78% more light on the road
Good luck finding a halogen bulb that can do that.
Ziggyrama is offline   Reply With Quote
Old 08-30-2012, 12:49 AM   #10
lj8915
Member#: 329252
2012 Subaru WRX
Ok, $1500 for 2 headlights. No thanks.
Now I'm looking at a retro. Buy from TRS or lightwerkz? Let's say I already have a standard PNP 35w H11 HID kit...do I need to buy the full miromoto retro kit, or do I just need the projectors and brackets? In other words, what bulbs size fits in the miromoto projectors?
Old 08-30-2012, 10:26 AM   #11
cjeckert
Member#: 235032
2010 WRX
I did the TRS retrofit. Not for the light hearted as it involves baking your headlights but a doable weekend project.
cjeckert is offline   Reply With Quote
Old 08-31-2012, 09:57 AM   #12
Wrexflex
Member#: 326301
2012 WRX LR - Sold
The 2 HID's used, but in great condition, set me back $600. But then I sold my non-HID headlights for ~$400 So in the end it wasn't too much. Yeah the auto levelling is missing, but it's doable, and they aren't off very much so it could not even be worth doing it. Mine are pretty level
Old 12-12-2012, 12:53 PM   #13
turboman38
Member#: 119306
2011 SWP WRX
My main question is where does the factory plug come out of the wiring harness to plug into the leveling motor on the back of the headlight? I can't believe the wiring harness isn't already wired to do this since the limited version of a 2011 WRX has HIDs. I have the premium version which is one model down from the limited.
Does anyone know where the leveling motor plug connects to the rest of the factory wiring harness under the hood?
turboman38 is offline   Reply With Quote
Old 12-12-2012, 01:51 PM   #14
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Looks like you've already posted in the right forum:
http://forums.nasioc.com/forums/show....php?t=2442367
They're going to have better answers for you over there.
Loyale93 is online now   Reply With Quote
Old 12-12-2012, 03:36 PM   #15
turboman38
Member#: 119306
2011 SWP WRX
The thread I posted in was just a question on the ability to plug and play. I know now that I can do that. My question here is strictly about where the leveling plug on the back of the HID lights joins the factory wiring harness. More specific is the wiring harness under the hood of a 2011 WRX premium different than that of a 2011 WRX limited because of the HIDs?
Old 12-12-2012, 04:11 PM   #16
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Right... and which forum do you think will have better information on that?
Newbies & FAQ's ?
or
Electrical...
Just a thought.
Old 12-13-2012, 08:03 AM   #17
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Retrofit s2000 projectors (the best projector in that size, hands down) for less than the cost of new OEM HID lamps.
Old 12-13-2012, 02:10 PM   #18
jeanluconze
Member#: 272413
nevermind
jeanluconze is offline   Reply With Quote
Old 12-13-2012, 03:38 PM   #19
turboman38
Member#: 119306
2011 SWP WRX
I have two used STI HID complete assemblies for less than $500 and will be able to get more than half that for my stock halogens. I just would like to get the leveling working.
Old 12-30-2012, 09:37 PM   #20
turboman38
Member#: 119306
2011 SWP WRX
Thanks to all of you especially mattesonb, who helped answer my questions with my install. Lights are installed with the factory leveling system and work flawlessly.
Happy new year!
Old 10-08-2015, 02:53 PM   #21
90crxfreak
Member#: 318642
2012 WRX Premium
subscribed
90crxfreak is offline   Reply With Quote
Old 11-22-2015, 01:27 AM   #22
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
following. just boyght a quad retrofit with limited headlights. was wanting to make the levelers work but seems like alot of work
rosedaleny806 is offline   Reply With Quote
