Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 12-12-2012, 10:54 AM   #26
Tarpley219
Member#: 297676
2009 360whp WRX
E85
Originally Posted by Steelydan1972 View Post
for stage 2 go with catback exhaust and a catted dp.... thats it!!
Technically, you only actually need the down pipe to go stage 2.
Tarpley219 is offline   Reply With Quote
Old 12-12-2012, 07:00 PM   #27
Gomes316
Member#: 340178
2009 WRX 265
Originally Posted by wrxftw619 View Post
Everyone on nasioc are a**holes. It's hard to get a good answer. Stage 1 mods r anything that doesn't touch the downpipe and or turbo. So stage 1 mods can be suspension, cold air intake, access port.
But once u upgrade your downpipe and get a turbo back, ur now stage 2 and your access port will be needed. Or u can skip the access port and get a pro tune.
Your access port allows u to change the ecu to compensate for the higher hp, without having to get a pro tune. In my opinion, an access port is good if u plan on modding slowly, which a pro tune will be useless because once u add another power mod, ur gna most likely need another pro tune. To save money, keep your access port, get a protube when you're done with all your power mods.
What I did was intake, access port, sways and endlinks, and springs. By far, suspension mods makes me so happy and makes the car that much more enjoyable to drive.
Stage 1 all depends on the person, you can call it wtv you want to! I know for Lachute performance, a stage one is a down pipe, a stage 1 flash, and a new air filter. Like I said, you can call it wtv you want lol
Gomes316 is offline   Reply With Quote
Old 12-12-2012, 07:22 PM   #28
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Whole lotta assuming going on in this thread. OP never did tell us what he drives so for all we know, we're telling him to flash his Yugo with an Accessport stage one map.
Number one thing for newbies to remember: Help us to help you. Fill out your profile and give us as much information as you can about the problem you're facing or the question you have. Telling us which car you drive is important in this case, don't ya think?
Gallo2011 is offline   Reply With Quote
Old 12-12-2012, 07:25 PM   #29
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Originally Posted by ColeBerkenbile View Post
Dp- downpipe
Ebcs- electronic boost control system
Close, but not quite correct.
EBCS = Electronic Boost Control Solenoid
Old 12-12-2012, 08:36 PM   #30
SubeizRippin
Member#: 336616
Charcoal Gray
Originally Posted by keonigt View Post
Would there be a major difference, in stage 1, between having a protune with exhaust and using the OTS (off the shelf) map?
An OTS map is more of a general tune for example and a pro tune is more of a tailored tune for your car exactly and how it behaves and its health so you can say you would see a difference but not too significant.
SubeizRippin is offline   Reply With Quote
Old 12-13-2012, 10:11 AM   #31
s2ktosti
Member#: 70151
2011 WRX Limited
Originally Posted by S3XCWRX View Post
BTW guys i have 2013 WRX SEDAN WR BLUE
If you install a CAI on that model year without a tune you'll be buying a new engine.
Read the stickies.
s2ktosti is offline   Reply With Quote
Old 12-13-2012, 11:23 AM   #32
bouncing_soulz
Member#: 175427
2015 STi
Any change in air flow should be tuned to accommodate the change.
bouncing_soulz is offline   Reply With Quote
Old 12-13-2012, 04:46 PM   #33
SWP n Gold
Member#: 110783
2010 WRX
You don't need a custom tune for a catback and intake, you could use Cobb's Stage 1 + AEM cai map, but you'll make more power on a custom tune and it will be tailored to your car so it will potentially be safer as well. I would recommend Torqued Performance for your Stage 1 + AEM cai map since you don't have to buy a $500 AccessPort. Or you could go to a local tuner and get a custom tune on a dyno.
SWP n Gold is offline   Reply With Quote
