Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 12-13-2012, 01:38 PM   #1
my06wrx
Member#: 336376
2006 WRX CGM
TP Tuned @18psi
Default 06 wrx TBE question
Is it a bad idea to run a TBE on a stock turbo without an external waste gate? Ive heard about over boost, but i never seem to spike much past 16psi, and i have been running the stage 2 AP map. And are there any other areas of concern with a TBE on a completely 06 wrx with only the access port stage 2 map?
my06wrx is offline   Reply With Quote
Old 12-13-2012, 01:43 PM   #2
be0tch
Member#: 66206
2005 WRX STi
FP HTA Green Turbo
Overboost and boost creep seem to be less of an issue with a low wastegate duty cycle tune and especially with a catted downpipe.
Your experience may vary depending if you drive into a very cold weather environment or if you floor it at low rpms in high gear (which can cause overboost, sometimes).
Having said that, EWG will give you a performance increase as well as do a lot to prevent overboost/creep.
be0tch is offline   Reply With Quote
Old 12-13-2012, 01:45 PM   #3
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
Lots of people (read: almost everyone) run TBE's without changing the stock turbo out. It's generally referred to as "Stage 2", as you said.
So long as you have it tuned for it (OTS AP map is fine), you're fine. I ran an '04 STi for 4 years on the Cobb Stage 2 with zero problems.
Loyale93 is online now   Reply With Quote
Old 12-13-2012, 02:20 PM   #4
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
He was taking about the waste gate not the turbo.
OP you should be fine especially if your downpipe is catted. I think the 08+ models have had more of an issue with boost creep than the earlier models and that is still mostly due to a catless dp because the port on the waste gate couldn't handle the flow rate of the catless system
snowboarder2587 is online now   Reply With Quote
Old 12-13-2012, 02:39 PM   #5
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Boost spike is a tune problem, boost creep is a mechanical problem. If you get boost creep, an EWG will help alleviate it. Performance gains aren't much on a stock turbo, but it does free up some power that boost creep was robbing you of.
The stage 2 COBB map (I'll assume that's the one you were referring to) is a generic tune and might give you some boost problems, but that's to be expected. Look at getting a protune if you want a little more power from a tune made specifically for your car and climate.
Old 12-13-2012, 02:40 PM   #6
BoostinChick
Member#: 218971
2007 WRX
I have an 07' WRX and have been running a TBE with the stock turbo for almost 2-years now.
BoostinChick is offline   Reply With Quote
Old 12-13-2012, 03:56 PM   #7
my06wrx
Member#: 336376
2006 WRX CGM
TP Tuned @18psi
I probably should have mentioned that i have a "CATLESS" downpipe. If the EWG is the way to go, will i have to fabricate my turbo?
Old 12-13-2012, 04:05 PM   #8
Leafy
Member#: 330625
2006 WRX
You're fine. When I first put my DP in I left my tune with the stage 1 boost settings, and yes I was making like 1-2 psi above target in the mid range, not spiking. Now I've got a stage 2 tune I threw together on it, and I'm only hitting 19psi instead of 21 so I need to increase my duty cycle in the mid range. But now I've got too much torque for my stock 100k mile clutch, so I havent worked on dialing it in better. Now if you're making more than 12 psi at redline, that tune is either commanding it and is way to aggressive OR you have boost creep, which is a mechanical problem that would be solved with an ewg.
Old 12-13-2012, 04:05 PM   #9
mtarr07
Member#: 246990
2010 Wrx
Huh?
Some cars creep, some dont. In the 2007 and below models, it isn't as prevalent. You said yourself that you're only hitting 16 psi. If that is what the Cobb stage 2 map says is normal, then you are fine.
With a catless downpipe, you are more likely to creep, but it doesn't mean you WILL.
mtarr07 is offline   Reply With Quote
Old 12-13-2012, 04:14 PM   #10
my06wrx
Member#: 336376
2006 WRX CGM
TP Tuned @18psi
Originally Posted by mtarr07 View Post
Huh?
I read something about having to drill a hole in the stock turbo for the EWG, and then something like clamping down the stock waste gate. Im all for the EWG, i just really don't want to fabricate anything unless its vital to the cars health.
Old 12-13-2012, 04:22 PM   #11
sc00by4life
Member#: 97135
you heard wrong. you dont need to do it, stop reading about it. if you don't know what you're reading, you'll scare yourself. you dont need to drill ANYTHING to run an external wastegate, you just buy a bracket that holds the wastegate closed and disconnect the vacuum lines. but you dont need to worry about that.
just stop.
you'll be fine. install it, flash a tune, and have fun.
Old 12-13-2012, 04:42 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Stop...just stop. You're not experiencing anything that shows you have creep. Stop worrying about EWG if you don't have one. If you plan to get one, take it to a shop and have them do because they will know what to do.
You are in over your head big here. Calm down, relax, research.
Old 12-13-2012, 04:48 PM   #13
my06wrx
Member#: 336376
2006 WRX CGM
TP Tuned @18psi
just stop.
Finally something that made sense.
THANK YOU SCOOBY4LIFE!!!! You have made it very clear for me.
I already have the exhaust and a map flashed.
