South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-13-2012, 06:22 PM   #1
sub_sifu
Member#: 301690
Default Let's play "Did I get ripped off?"
While out of state, my fiance purchased a 99 outback sport for xxxx. Since it runs, I told her to go for it at their crazy low asking price. Now I've seen it, I want to pass it on to the old pros here.
Vehicle is in AZ, was back East. I don't have a lot of experience with rust, but the car definitely does.
The question is:
How much is it worth knowing only the following:
Pros:
Starts up, runs clean. Everything works as it should.
Tires in good shape. Clean interior. Clean title, 2 owners.
Overall, looks like its in nice shape
Cons:
Needs break pads, possibly rotors.
Rust bucket (see pics)
Check engine light
185k miles.
I really got on here for advice on how bad the rust is (cosmetic, structural), what I should do to thoroughly check it out (pull up carpet? Anything easier?) ... what I should do to repair it (fiberglass/bondo or metalworker?)
I tried snapping the worst of the rust.
sub_sifu is offline   Reply With Quote
Old 12-13-2012, 06:37 PM   #2
yman
Member#: 199051
06 Subaru
$900-1100ish
yman is online now   Reply With Quote
Old 12-13-2012, 07:26 PM   #3
ktmrider
Member#: 125687
2006 Outback XT
ABP
CEL gonna make it no-dice for registration.
What is said CEL? Could be major $$$ to fix.
ktmrider is offline   Reply With Quote
Old 12-13-2012, 07:48 PM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Yeah, I'd put it at 1500 tops. Less if it can't be registered due to the CEL. And only if it has AC.
Old 12-13-2012, 08:11 PM   #5
tibug
Member#: 273906
1831 Conestoga Wagon
My oxen all died.
The rust is gonna be extremely difficult and costly to fix. It wouldn't be as difficult to hide it, but it would be crazy difficult to actually stop it. EDIT: You'll never "stop" it. I have that exact same car with almost identical rust and I can tell you where you very likely have rust.
This is the inside of the car. This picture shows the intersection of the passenger's side shock tower and the C-pillar. You can see the seat belt in the foreground. The rust goes all the way through and you can see the quarter panel inside.
This is what the rust inside the quarter panel looks like.
One more picture. Look on the right side on the shock tower; you can see rust spots on the side of the tower.
I paid $550 for my car. When I bought it, it had 1) leaky injector seals, 2) an EVAP system code, 3) Shot tires, 4) 259,000 miles. I replace the injector seals, replaced the tires, did the timing belt, and brought it to emissions. It had three codes (idle malfunction, EVAP, and catalytic converter) AND the CEL wasn't working. So...it failed.
I looked online and found that the EVAP code is common on old rusty Subarus and is very difficult to pinpoint (could be a pressure leak anywhere in the fuel system/charcoal canister/lines...). I'm only mentioning this because it is such a common problem. If your CEL is not EVAP related, you can breathe easy and disregard this. Most other common codes are simpler more straightforward fixes (but it's all relative). Now, here's the important part, if you have an EVAP code:
http://forums.nasioc.com/forums/show....php?t=2402867
Essentially, the car only runs the EVAP test if you have less than 9.6 gallons of fuel in the tank. SO, I never let my car get near 3/4 of a tank before filling it up, and lo and behold, the code shut off.
I replaced the CEL bulb and brought it to emissions again. Pass. The cat code and idle code did not show up, for some reason. Lucky me.
EDIT: Let me also point out that my car has the original clutch (which is in sad shape) and most of the exhaust exits before the tailpipe (it's that rusted). I think I got a good deal for $550, but it's also likely that your car is worth more than mine.
tibug is online now   Reply With Quote
Old 12-13-2012, 10:31 PM   #6
sub_sifu
Member#: 301690
This is an incredibly helpful post. Thanks a lot for taking the time to write this. I'll check out those areas and see what I'm dealing with. She paid $950, which I thought was a fantastic deal for such a reliable car. Hopefully just a little TLC is all that is needed.
Old 12-13-2012, 10:51 PM   #7
tibug
Member#: 273906
My oxen all died.
It really is reliable, and being that you're in the Southwest (I didn't notice I was in the SW forum at first), the rust won't get worse as fast as it does in CT where I am. Considering you're not in the rust belt, it may be worth trying to get the rust fixed, but I'm certainly no expert in that area. You'll also want to check out the underside of the car. Mine is not bad and it seems like the factory undercoat did its job, but you're gonna have to give that a look too.
I think $950 is very reasonable. If it can pass emissions (not sure what emissions is like where you are) and you can tolerate the rust, I see no reason why the car won't have a lot more miles left in it. The 2.2 liters are dead reliable and pretty gutsy for a small engine. At 262k miles it burns no appreciable amount of oil and has no leaks. I can hardly say the same for my 2.5L Outback.
Good luck with it!
Old 12-13-2012, 11:02 PM   #8
shemoves
Member#: 80663
1997 Outback
That rust is pretty bad...as you said, was definitely back east. Rust isn't an issue here in AZ (unless there are parts up north where it snows where they use salt instead of cinders). Know that rust near structural junctions can pose some major safety risks...as those spots are much more likely to 'give' when there simply isn't the material there that is supposed to be.
AZ won't pass with a CEL. It might be something simple...you can take it to a local AutoZone/Checker and they will pull the code for free. Do you have the car? Are you in AZ?
shemoves is offline   Reply With Quote
Old 12-19-2012, 07:26 PM   #9
sub_sifu
Member#: 301690
UPDATE:
Fought the rust to redo the brakes. Now to the CELs. I've been doing some research and so far addressed one code.
PO325- Knock Sensor ( I hopefully addressed this today)http://forums.nasioc.com/forums/show....php?t=2204739
I still have 3 to go. I noticed a hole in the gas tank. Fortunately, when you fill it up, the gas nozzle extends past the hole.
PO183- Fuel Temp Sensor
PO463-Fuel Level Sensor
PO1400-Fuel tank pressure control solenoid failure or short. I noticed there is a hole in the gas line. Fortunately, when you fill it up, the gas nozzle extends past the hole.
PO420-Cat or o2 sensor-Anyone want to weigh in on this?
Old 12-20-2012, 01:08 PM   #10
USLiberty
Member#: 294466
1993 Legacy SS
white
The fuel level sender probably just needs to be pulled out and cleaned. Did the trick for mine.
USLiberty is offline   Reply With Quote
Old 12-30-2012, 03:49 PM   #11
USLiberty
Member#: 294466
1993 Legacy SS
white
Electronic Anti rust protection www.counter-act.com . This is supposed to keep rust from getting worse
Message Board Statistics All times are GMT -4. The time now is 11:29 PM.
