Old 04-14-2009, 06:00 PM   #126
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
i just found another small issue that needs tending to before it runs. i need a catch can b/c i got 4 hoses that don't need to be routed back into the intake...catch can needs a custom bracket for mounting, grrr.
2.5rsTurbo is offline   Reply With Quote
Old 04-15-2009, 01:00 PM   #127
stikiller1234
Member#: 200480
96 impreza
if you want a great east coast shop to hook you up....andrewtechautomotive.com....
stikiller1234 is offline   Reply With Quote
Old 04-15-2009, 11:30 PM   #128
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
what can they hook me up with?
Old 05-02-2009, 07:00 PM   #129
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
this looks better
Old 05-06-2009, 10:04 PM   #130
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
update:
other than the issues at hand which i think is either my coil pack or ecu, this is basically finished. notice the catch can on the right and the coolant reservoir on the left which are the two things that were last to go on.
Old 07-14-2009, 05:25 AM   #131
b1bflyer
Member#: 106180
1998 Ver 4 STI
Sonic Blue
How did you end up routing the IACV hose? This last pic shows it running right over the hot side of the turbo so I'm guessing that's temporary.
I've got a 20k in process of rebuild and I'm trying to see if I can run the IACV feed under the intake manifold and attach it to dump valve return. That way I don't have to get the v3/4 specific samco silicone inlet.
Great build BTW
Ryan
b1bflyer is offline   Reply With Quote
Old 07-14-2009, 05:37 PM   #132
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
You'll still need that specific inlet hose because of the power-steering reservoir. It's possible to shoehorn a newer model one in, but that reservoir will eventually cut it. (that's what happened to mine)
scrappydoo is offline   Reply With Quote
Old 07-16-2009, 10:21 AM   #133
b1bflyer
Member#: 106180
1998 Ver 4 STI
Sonic Blue
Thanks for the replies, I went with the Samco specific one, just have to wait more than a month for it to be made. *SIGH*
Ryan
Old 07-16-2009, 03:37 PM   #134
scrappydoo
Member#: 23630
97 v4 STi RA
There's a bunch on ebay that are v4 specific and members here have said they're pretty good.
Old 08-28-2011, 12:21 PM   #135
561wrx
Member#: 166427
03 wrx
nice work
561wrx is offline   Reply With Quote
Old 09-10-2011, 02:26 AM   #136
oucheewawa
Member#: 293173
What causes a spun bearing
oucheewawa is offline   Reply With Quote
Old 09-10-2011, 09:49 AM   #137
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Severe detonation, insufficient oil pressure, or a combonation of both.
Old 06-10-2012, 07:14 PM   #138
Fanmail
Member#: 236208
is this thing running correctly?
Fanmail is offline   Reply With Quote
Old 12-13-2012, 11:14 PM   #139
stiguy2008
Member#: 332709
Anybody In this thread know why a friend of mines ej20k over heats after about 15 minutes of cruising? It's only got about 28 thousand miles at this point so any info would be great!! Thanks guy!
stiguy2008 is offline   Reply With Quote
The "my ej20k spun a rod bearing" count thread 2slofouru Subaru Conversions 0 02-22-2008 02:34 PM
NY:02 wrx spun bearing otherwise great for motorswap GTIWRX83 Private 'For Sale' Classifieds 2 02-28-2006 06:16 PM
Spun Bearing? Jaships Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-12-2005 09:29 PM
spun bearing snowman4us Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-17-2005 03:55 PM
FS:STi V7 Shortblock- with spun bearing (perfect for rebuild!!) Blugin Private 'For Sale' Classifieds 29 09-15-2004 10:55 AM
