Welcome to the North American Subaru Impreza Owners Club Friday September 19, 2014
Old 12-14-2012, 01:42 PM   #1
Flawlers
Member#: 340608
2004 STI
Platinum Silver
Default Swap motor exhaust question
This may sound abit stupid but i have a 2003 WRX with a 2005 Sti engine,tranny and everything. When shopping around do I have to get a 03 WRX exhaust or a 05 STI?
Sti seems like the right answer to me, but will it fit under?
Flawlers is offline   Reply With Quote
Old 12-14-2012, 01:52 PM   #2
Loyale93
n00b Moderator
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
you will need STi exhaust for anything that you've replaced with STi parts. If memory serves, the turbo bolt pattern and housing size is the same on the TD04 and the VF43, so downpipes and uppipes should mate up. Please someone correct me if I'm wrong on this one.
Once you're back past the downpipe, everything should be the same 02-07 Impreza. Just have to make sure pipe sizes match up. If you're buying all stock pipes, I believe the STi was 2.5" and the WRX is 2.25. If buying Aftermarket, just buy everything the same size.
Old 12-14-2012, 01:55 PM   #3
Flawlers
Member#: 340608
2004 STI
Platinum Silver
Alright thanks alot!
Old 12-14-2012, 02:01 PM   #4
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Also, fill out your profile
Old 12-14-2012, 02:22 PM   #5
Flawlers
Member#: 340608
2004 STI
Platinum Silver
i will :P
Old 12-14-2012, 06:20 PM   #6
hudsonvalleybugeye
Member#: 295068
2003 wrx
Sedona Red Pearl
When you say exhaust, are you refering to downpipe back or manifold back? Either way, downpipe back, all 02 through 07 wrx/sti will fit, the important part, is what ecu are you running? And, I would tune it once you are done with the swap even if you replace the exhaust with stock parts. Good luck!
hudsonvalleybugeye is offline   Reply With Quote
Old 12-14-2012, 07:14 PM   #7
sc00by4life
Member#: 97135
the only difference is the exhaust manifolds. uppipes, downpipes, catback, all the same.
