Old 04-24-2011, 06:56 PM   #26
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Can someone post pictures or a diagram of where this valve is located? Just got the CEL code P1443 today like each of you have mentioned. Been having the gas pump click-off problem for a few months which makes me believe that I need to replace this "Vent Valve Part"
Thanks in advance.
ejicon is offline   Reply With Quote
Old 04-26-2011, 10:54 AM   #27
Siper2
Member#: 1134
2007 BMW 328xi wagon
Glad you bumped this, as my sister-in-law is getting the same code on her '98 Legacy Brighton. I know it's obviously not a FI car, but this code seems common and (I think) Subaru-specific, as it doesn't show up in most of the basic OBD-II diagrams I've seen.
I checked her hoses and none appeared to have popped off, but she has all the same symptoms. Anyone?
Siper2 is online now   Reply With Quote
Old 04-26-2011, 03:51 PM   #28
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I ended up resetting the code and have yet to filler-up to see what happens. I'll probably contact Subaru and see if this is covered under warranty if the code comes back on.
Old 04-27-2011, 10:15 AM   #29
Siper2
Member#: 1134
I have one of those small Actron code readers, which allows you to reset codes, if they're able to clear. This one won't reset, so it must be a persistent condition, I'd guess.
Old 04-27-2011, 02:10 PM   #30
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Well that's the thing. If I can figure out where this Vent Valve Sensor part, I can check it to see if it's clogged, dirty or what'ever. I'm not sure where or even how to look on my 2008 Hatch. See doing some research. Going to have to whip out with the shop manual for this one.
Old 06-12-2011, 09:22 PM   #31
bugeye sti
Member#: 186691
2011 sti
Having the same problem. Also have an 08 any idea were the valve is?
bugeye sti is offline   Reply With Quote
Old 06-27-2011, 12:41 PM   #32
KENLUDE97
Member#: 152010
2004 Forester XT 5sp
Red
I changed out my Vent Valve. The change was easy other than the rust issues.
But it did fix the CEL
KENLUDE97 is offline   Reply With Quote
Old 06-27-2011, 01:33 PM   #33
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
I found it. I'll post up some pictures once I get to my laptop.
Old 06-27-2011, 01:34 PM   #34
bugeye sti
Member#: 186691
2011 sti
How long did it take to change it?
Old 06-27-2011, 07:40 PM   #35
bugeye sti
Member#: 186691
2011 sti
Nice! thanks
Old 06-28-2011, 03:14 AM   #36
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
If you lift up the rear of the car and look under the rear passenger section a little past the wheel well, you'll see the Vent Valve/Pressure Control. It'll be tough to get to if you have larger hands.
Here are instructions on removing/replacing it.
Part number for the 2008 42084FG020
Part cost $89 bucks through SGP.
$125 at your local dealer unless you can make a deal with them.
Hope this helps. I have yet to find the time to replace mine.
Since so many people have been having this problem and there doesn't seem to be much info about 2008 models going through all of this, I'll probably document the installation just for future reference.
Old 06-28-2011, 10:04 AM   #37
bugeye sti
Member#: 186691
2011 sti
Sgp? Howcan I get the part from them? Do u have a website or phone number?
Old 06-28-2011, 12:03 PM   #38
bugeye sti
Member#: 186691
2011 sti
found it for $82 here: http://www.shopsubaruparts.com/Default.shtm 94 shipped
Old 06-28-2011, 03:40 PM   #39
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Before you go and make a purchase... you might want to try cleaning out your charcoal box. I honestly thought our year cars didn't have one because I searched everywhere on the car and couldn't find it. Apparently they do and they are prone to getting clogged up with charcoal pieces and spider webs.
Old 06-28-2011, 04:44 PM   #40
bugeye sti
Member#: 186691
2011 sti
Do you know were it's located?
Old 06-28-2011, 06:26 PM   #41
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
It's located under the trunk mat on the Passenger side. I have the Procedure info at home on my laptop. Will post it soon.
Old 06-28-2011, 07:39 PM   #42
bugeye sti
Member#: 186691
2011 sti
Ya found it. Just finished checking the hoses coming off the canister they Were all clear. Do you know what the thing on the driver side is?
Old 12-14-2012, 11:11 PM   #43
wvkartracer
Member#: 323616
I found Dorman 911-650 as an OEM replacement for $41 US at amazon.com. Ordered one up this evening. Had the fill up problem and just got the CEL this evening.
wvkartracer is offline   Reply With Quote
Problem filling tank (05 Sti) th1rd3y3 Newbies & FAQs 35 08-27-2012 12:04 PM
trouble filling gas tank. bad evap system? orionh2215 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 04-21-2010 12:21 PM
WTB: NEED thie radiator fill tank from WRX BADLY! Norcalrallyist Private 'Wanted' Classifieds 2 07-20-2007 08:21 PM
relocating coolant fill tank DJSuperSoul Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-05-2007 09:24 PM
odd...having trouble filling tire shemoves Tire & Wheel 2 08-30-2005 02:42 PM
