Old 12-12-2012, 12:04 AM   #1
dirtymatt89
Member#: 266599
Default Legacy 2.2 cold starting issue
Hello all,
Quick question for everyone if you don't mind. My friend has a 1994 2.2 NA Legacy, and on cold mornings/nights it wont start, it just cranks, however if you play with the gas pedal, it may or may not start. It had been doing this for a while so I put a new fuel pump in there, just to be sure. Ive done a little research and found that it could be the coil packs being corroded, or maybe even the coolant temp sensor. Just wondering if anyone has any experience with these.
Many thanks!
Matt
dirtymatt89 is offline   Reply With Quote
Old 12-15-2012, 12:03 AM   #2
oldscoobyturbo
Member#: 237441
1990 Legacy RS-RA
check the ground on the fuel sender first, make a new one if need be I have done this to every older legacy I ever owned.
then if its good check the throttle position sensor and coolant temp sensor.
oldscoobyturbo is offline   Reply With Quote
