Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 04-19-2012, 02:12 AM   #1
williamseric7
Member#: 309700
MBP 05 Sti font end swp
Default fp green on modified 03??
I'm thinking about going tmic and short ram as a nice powerful daily driver. I feel like the large fmic was holding a lot of power back, i have a cobb ap so getting a real tune threw my friend from pro motor sports of n.e with the computer could help tune out some of the lag and create a little bit better drivability. I know there will still be some lag but, After doing some research the thought insted of selling parts maybe just upgrading to a more powerful tubro to work with the cai and dr 725. A good buddy said to look into a fp green. The thing im worried about is if thats too much power for the motor, would forged pistons, new bearings and rods be enough or getting a new bottom end? Could selling my motor w/110,000 and swapping for something also be an opption.
Anything would help Thanks
My mod list is as follows
ACT Light Weight Flywheel 13lbs
ACT HD Clutch
ACT HD Pressure Plate
APS DR725 FMIC
APS CAI
deatschwerks 750cc
PowerEnterprise PE1820 turbo
Cobb Access Port
Perrin Up-pipe
TurboXS turboback
Perrin Fuel Rails
Walbro 255lph fuel pump
wilwood bbk
williamseric7 is offline   Reply With Quote
Old 04-19-2012, 09:12 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
a green would probably only give up 2-500 rpm in spool to that pe1820, which was never known as a particularly fast spooler. the 1820 wakes up at higher pressure ratios as does the green. a good IC is necessary.
the safe route would be to pull your still running motor, sell it, and fold the money into a better build. forged pistons at the least. getting some cams in there would turn it into a monster. i would not go 2.5 block as you have a gearbox waiting to grenade. a big, slower spooling turbo that makes power up top via rpms and cams is easier on the gears than a low rpm torque monster.
Old 04-19-2012, 09:37 AM   #3
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
ACT HD Clutch
APS DR725 FMIC
APS CAI
deatschwerks 750cc
Cobb Access Port
Perrin Up-pipe
TurboXS turboback
Perrin Fuel Rails
wilwood bbk
Why a short ram? I would think that would loose you power.
tachrev is offline   Reply With Quote
Old 04-19-2012, 11:13 AM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
i'd be looking at a blouch turbo.
Old 04-19-2012, 01:17 PM   #5
williamseric7
Member#: 309700
thanks guys, after more talk with my guys I figured that the bottem end is just too weak for a big turbo. I'll keep the pe1820 go big top mount and swap the motor in the future any idea what a 2.0 w/ 110,000 is worth?
Old 04-19-2012, 02:00 PM   #6
Dr. octagon
Member#: 171127
02 Cyborg Warner
Rotated
I am on a green (OG 49lb/min) and enjoy it thouroughly. If i had the cash i would go hta green as it is basically a small 30r (56lb/min), but ideally rotated 30r would be the largest i would go on a stock 205 and trans.
Remember 2.0l will not yeild nearly as much torque as 2.5 unless you get crazy with the timing. Oh and i am on stock trans
Dr. octagon is offline   Reply With Quote
Old 04-19-2012, 02:01 PM   #7
Dr. octagon
Member#: 171127
02 Cyborg Warner
Rotated
Bottom end is to weak for what? 205 pistions imho a hell of a lot better than cast oem sti pistons. The rods are the short comming with usdm 205. Find someone that knows how to tune
Old 04-19-2012, 02:21 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
good luck on your 205, here's some carnage of my friend's bottom end after a green, made good power 365-370whp on a mustang dyno but his motor had alot of hard miles. It was definitely the rods.
http://forums.nasioc.com/forums/show...postcount=1190
Old 04-19-2012, 03:51 PM   #9
Dr. octagon
Member#: 171127
02 Cyborg Warner
Rotated
hum, well mines mo betta
Old 04-19-2012, 04:15 PM   #10
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I had a green on my 03 and it is very slow spooling on the 2.0L and not ideal for DD. If you want low lag good hp turbo, consider the Tomei 7760.
Old 12-15-2012, 12:46 PM   #11
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Last edited by bushflyr; 12-15-2012 at 12:48 PM. Reason: Spilled coffee on keyboard.
bushflyr is offline   Reply With Quote
Crushing the BOV for 30 WHP on 440 WHP 440 TQ '07 STI FP Green on Alchy Dyno Flash Proven Power Bragging 81 12-13-2007 02:24 AM
Socal" FP GREEN + perrinn modified sti injectors dezwrx03 Private 'For Sale' Classifieds 8 05-25-2006 07:02 AM
Who has a FP Green on a 2.0? spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 04-01-2005 09:39 AM
Help with install on FP Green on 2004 Sti SlidewaysSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-24-2005 10:41 PM
FP Green on sti pink w/ fpr dan avoN7 Engine Management & Tuning 3 10-09-2004 12:25 PM
