#1 |
Member#: 315019
MWSOC
Vehicle:2012 Impreza 5-Door Ice Silver Metallic |
I've got a '12 Impreza 5 door that I absolutely love. Not having a turbo on it isn't the end of the world for me, but with the announcement of the '14 Forester and the XT that'll go along with it, I couldn't help but think that having a turbo in my Impreza wouldn't be too far of a stretch.
If you've missed it, 2014 has a 4th Gen Forester coming with a 2.0 powertrain that'll also be available with the XT. The Forester XT only came in an automatic transmission before, but since Subaru is switching nearly all of it's vehicles over to the CVT transmission, the new XT will have a CVT paired with it. My '12 Impreza is a CVT (mainly because it got better gas mileage than the manual) and I can't help but wonder if the turbos on these 2.0 engines for the 2014 Forester and unconfirmed 2014 WRX would be either a good guide to getting a turbo on my Impreza or maybe even an engine swap if my current powertrain wouldn't be able to handle that sort of performance. Your thoughts?
#2 |
Member#: 106747
South East
Vehicle:99 RS i make plate deletes!!! |
just sell your current impreza,and buy a wrx.
#3 |
Member#: 134005
MAIC
Vehicle:2004 WRX Premium PSM |
#4 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Wiring of the '14s is certain to be very different for the DI. The BRZ uses a completely different ECU that is in no way compatible with the previous Subaru ECUs.
So if you want to do this, you start by ripping out your *entire* dash and spending a month re-wiring and pinning new connectors. Certain swaps are easy. That's because they are pin compatible on wiring and require only mechanical changes. The mechanical stuff is easy... it's the wiring and figuring out what should go where that's difficult. You do NOT want to undertake a swap that requires re-wiring unless you are very patient, proficient at wiring, and have a wiring diagram. You also need a TON of spare time and another car to use while yours sits in pieces. A month is NOT an exaggeration. People who manually re-wired their old GC 2.5RS to be able to swap in an WRX engine generally took well over a month until there started to be businesses that made the necessary wiring harnesses for these swaps. All the mechanical stuff is not too difficult. The wiring and what ECU you're going to use are a huge question mark on these swaps. This also assumes that your CVT is built to the specs of the Forester's CVT, which is another large question mark. CVTs traditionally have a difficult time dealing with high torque engines, and the 2.0DIT is ~double the peak torque of your FA20... you have no idea if your transmission is built to a level that will support a stock 2.0DIT. Last edited by Concillian; 09-26-2012 at 12:11 PM. |
#5 |
Member#: 315019
MWSOC
This isn't an immediate "I want to do this NOW" idea, just something I'm mulling around after reading the news of the new Forester.
If CVTs have a tough time working with high torque engines, one would assume that the one in the '14 XT would be able to handle this? |
#6 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
I'm glad I got my fozzie xt before the cvt.
That is all. |
#7 | |
Member#: 4414
It's something that if you are going to do it, you need to understand the amount of time and effort involved, that's all I was getting at. It's not one of the simple swaps, the direct injection on the 2.0DIT will guarantee that. |
#8 | |
Member#: 118209
MWSOC
Vehicle:2002 WRX Sedan |
#9 | |
Member#: 139444
Vehicle:2008 Impreza Dark Gray |
There is already a technology in place to make this all seamless. It's called CANbus and is now standard on all vehicles sold in the U.S. since 2006. Although, some manufacturers have been using it for much longer. Most engines in larger vehicles and semi's already employ this method for full engine control. Simply put, the engine controller is a completely seperate unit from the rest of the cars functions. The car would require a separate main controller and a seperate ECU(Engine Controller). The engine controller is usually mounted directly on the engine or in the engine bay and only requires 2 wires to communicate with the main controller. With throttle by wire now standard, this makes it all the more seamless. The main controller simply reads the potentiometer in the throttle and sends a data packet to the ECU as a percentage of throttle. The ECU takes into the consideration the current load and injects fuel accordingly. So in the future engine swaps will be super easy in regards to wiring. Just pull out the old engine and ECU. Plop in the new engine/ECU and wire up the alternator and starter. You may have to figure out something with the coolant temperature sensor. You may have to splice in the 2 CAN bus wires and Power Wires, but that's the extent of it. Of course, i'm not sure what the architecture of the 2012 impreza is like. But if your ECU and car's main controller are in fact seperate. The swap may not be so difficult. Last edited by gggplaya; 10-22-2012 at 03:04 PM. |
#10 | |
Member#: 290547
I think you just answered my ultimate question that I've been mulling over in my head for the past couple months. I've got a '97 legacy that I want to cram ALLLLLL of the features of an '08 STI into, drivetrain wise. Dual AVCS heads, stock ecu, vdc, si drive, 4 channel abs etc. I want to do this in phases, so my first phase would be installing the minimum to properly run the stock ECU and dual AVCS heads. If what your saying about CANBUS ECUs is true, then the engine ECU is seperate from the computers controlling ABS, VDC, SI drive, DCCD, etc. Is that right? Any info you could be provide would be much appreciated. |
#11 | |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
The CAN BUS ECM has to talk to all of the CAN BUS modules (Trans, ABS,security etc..) before it will start. While ggplaya has a decent bit of info I think he is talking theory rather than practice as anyone that has ever tried a CAN BUS swap will tell you that it is a PITA. |
#12 |
Member#: 315019
MWSOC
After continuing to toy around with this idea, I can't help but notice that no-one else is really attempting to switch over or do work on their 12/13 Impreza 2.0s either. It "makes sense" to put the money into a WRX or to wait and see what the next WRX will have to offer since it will likely be built around a 2.0 with a Turbo. I'll likely wait to see what the next WRX is like, but I'm pretty married to the aesthetics on my 4th Gen 2012 Impreza 2.0i, which is the main reason that I've been seriously considering keeping it and doing some major engine work.
I also am intrigued by the fact that no-one else has done it, making my car unique. In that same vein, many times the reason why something hasn't been done before is because it's just a bad idea in the first place. My significant other has been looking pretty seriously at the '14 Forester, which entertains the idea of convincing her to get the Turbo and do an engine swap with me. It's silly and likely improbable, but it would still be nice if I could get it to work. |
