Old 05-24-2010, 01:48 PM   #1
1hotsubaru
Member#: 244748
2002 WRB Impreza WRX
"aka" NGRY REX
Default jdm ej20 sti v4 engine into a 03 wrx???
Has anyone done this swap or does anyone know what i would need other than a jdm ecu???
1hotsubaru is offline   Reply With Quote
Old 05-24-2010, 07:44 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
bad idea
many many many things are different
cam/crank pickups
ignition
injector size/type/mounting
IAC
the block could be used but you will need to swap the cam pickup and your 03 heads
Old 05-24-2010, 08:21 PM   #3
RealDealTarheel
Member#: 142447
06 Outback
Things that won't work/shouldn't be done.....
RealDealTarheel is offline   Reply With Quote
Old 05-25-2010, 09:51 AM   #4
1hotsubaru
Member#: 244748
"aka" NGRY REX
alright thxs guys! but an ej207 fits right?
Old 05-25-2010, 10:17 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
they both "fit". but the 207 "works".
kheff46 is offline   Reply With Quote
Old 05-25-2010, 10:29 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
/thread
Old 05-25-2010, 12:41 PM   #7
1hotsubaru
Member#: 244748
"aka" NGRY REX
yeah thats what i meant lol, if it works... i heard its all just plug and play other than needing to splice avcs into the harness... is this correct??
Old 05-25-2010, 03:28 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not "splice" ,should be "add"
Old 05-26-2010, 01:02 PM   #9
1hotsubaru
Member#: 244748
"aka" NGRY REX
ok but will the ej207 plug into 02-03 wrx wiring harness???
Old 05-26-2010, 02:07 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
EJ207 GC8 Ver5/6 LONGBLOCK (minus intake manifold) will run like a USDM WRX. You would have to use the USDM WRX crank sprocket and camshaft sprocket.
EJ207 GDB Ver7-9 will work but you have no control over your AVCS from your factory USDM WRX ECU. You need the other wires or whatever is out there to make use of the AVCS.
Old 05-26-2010, 03:42 PM   #11
yuik
Member#: 247632
2014 mustang
blue
also remember see what sight you buy it from and see how well they are known. alot of these japanese chop shops are just that and they cut wires and alot of times they cut stuff in the wrong places which makes the job alot longer. i personally like to stay domestic
yuik is offline   Reply With Quote
Old 05-28-2010, 02:16 PM   #12
1hotsubaru
Member#: 244748
"aka" NGRY REX
yeah i want to run a ej207, and i found kits that help u wire up avcs, so thats not a problem... and does anyone know where i could get a ej207? i cant seem to find any at all....
Old 12-15-2012, 11:57 AM   #13
Wrx03Dreaming
Member#: 340694
2003 wrx
blue
Default EJ20K Impreza WRX STI Version 3 Fit a 03 Wrx?? HELP!
hey i have a 03 wrx that my short block is gone and i am looking for a engine and i came across jdm engine depot here in NJ and saw that they had a EJ20K Impreza WRX STI Version 3 and i wanted to know if it would fit my 03 wrx.. now im not very good with motor i only know a bit .. need major help! thank you
- Luis
Wrx03Dreaming is offline   Reply With Quote
Old 12-15-2012, 12:41 PM   #14
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
If you are only swapping the sb itself, it can be done although you might want to have your heads looked at. If you want to do the whole long block, look at the advice above. What are your plans for the car and other mods i.e. tuning methods?
SpamMansXe is offline   Reply With Quote
Old 12-15-2012, 05:51 PM   #15
Wrx03Dreaming
Member#: 340694
2003 wrx
blue
Yeah i read but didnt understand much about the part where the AVCS and stuff ... would i be able to use my 03 AVCS ? or i would have to get another AVCS for it?... Also is my 03 Engine parts compatible with EJ20K Impreza WRX STI Version 3 ? .. My plan for the car is just replace the motor. Sti or relagular wrx. im really just trying to get it running. its been a while. she has been collecting dust.
Old 12-15-2012, 05:54 PM   #16
Wrx03Dreaming
Member#: 340694
2003 wrx
blue
any help is appreciated
Old 12-15-2012, 06:31 PM   #17
69subaru360
Member#: 159682
1995 WRX
2015 F150
- Luis
No, the engine will not work. You could use the shortblock if you really wanted to but the EJ20K shortblock is not reliable.
Old 12-15-2012, 07:04 PM   #18
SpamMansXe
Member#: 15920
1999 White Mock 22B
^This.
If you are going to use the short block alone, you would probably want to rebuild it while it is out.
Old 12-15-2012, 07:30 PM   #19
Wrx03Dreaming
Member#: 340694
2003 wrx
blue
ahh okay thanks
Jdm EJ20 STI V8 Engine japanpower Engine/Power/Exhaust 26 06-30-2010 09:11 AM
JDM EJ20 STi ver8 Engine Swap --> $7499 jdm-online.com Engine/Power/Exhaust 12 07-30-2009 10:09 PM
*******jdm EJ20 STI V8 engine ******HKS JdmRacingMotors Engine/Power/Exhaust 22 05-13-2009 07:58 AM
HELP! 05 STi engine into an 03 WRX KillerBumbleBee Subaru Conversions 5 01-24-2007 11:10 AM
Can i put an STi engine into my 03 wrx? affinity1 Newbies & FAQs 32 04-08-2006 03:24 AM
