Old 12-15-2012, 10:41 PM   #1
Andrew04WRX
Member#: 340271
Default Quick question cobb access port
Ok found a cobb access port and it is unmarried will it work in mine if unmarried ?
Andrew04WRX is offline   Reply With Quote
Old 12-15-2012, 10:42 PM   #2
Andrew04WRX
Member#: 340271
He says he will plug it in and show me
Old 12-15-2012, 11:43 PM   #3
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
Depends which AP it is. Unmarried will work.
SUB-001 - 02-05 WRX
SUB-002 - 04-07 STi, 06-07 WRX
SUB-003 - 08+ WRX/STI
Chaz2.5 is offline   Reply With Quote
Old 12-16-2012, 09:50 AM   #4
Cobb Tuning
Member#: 4803
It depends on what AccessPORT version it is. If it is the older, discontinued version 1 AccessPORT (black brick-shaped), then there are separate devices for each model/year, for the most part. You can look at the part number on the back to determine what vehicle it is for. If it does not match your vehicle exactly, it will not work.
If it is a version 2 AccessPORT (gray with color screen), there are 3 part numbers for Subaru (SUB-001, SUB-002, SUB-003). Each part number will work on a certain group of vehicles. You can find the complete listing of the vehicles per part number at the following link (under vehicle compatibility):
http://www.cobbtuning.com/AccessPORT...rt-s/40200.htm
Both the version 1 and version 2 AccessPORT have to be uninstalled from the previous vehicle before you can use it on your car.
Bill
Old 12-25-2012, 04:29 PM   #5
Rooster907
Member#: 302963
I have a 2006 STI bone stock with a aftermarket warranty. ive had ALOT of warranty work done on my car including turbo, rear diff, and rear struts. After i uninstall and un marry this tuner from my ECU will it leave any "taddle tales" on ECU that may void my warranty?
Rooster907 is offline   Reply With Quote
Old 12-26-2012, 10:44 AM   #6
Cobb Tuning
Member#: 4803
A version 2 AccessPORT (i.e. current version with color screen) will restore the ECU back to the image that was on there when you installed it, whether that was the factory original map or something else. A version 1 AccessPORT (i.e. the old, discontinued model) will restore a factory map but not necessarily exactly the same factory map that you had on there before (Subaru makes multiple ECU revisions for a given car/year throughout the year).
We can't make any guarantees about any warranty-related issues (no Subaru tuning solution can) or about what a dealership can or cannot detect, but some details about some assumptions we can make (based on available evidence/rumor) is here:
http://forums.nasioc.com/forums/show...7&postcount=25
If this is an independent shop, their capability is even less so, but we still can't make any guarantees.
Bill
