Old 12-08-2012, 09:13 PM   #1
ierichuljev
Member#: 330442
Midnight Black Pearl
Default Idler pulley ?
I have this annoying noise coming from my engine starts to whine at about 1800k rpm ill post a Video when I have time but I believe it is the idle pulley has anyone had this problem ! It's a 2002 Wrx and is it easy to replace ? I looked for the part online and can't seem to find it
ierichuljev is offline   Reply With Quote
Old 12-09-2012, 08:02 PM   #2
Mental
Member#: 321773
2005 WRX
Could be the idler pulley. Go to any autozone type place and they should be able to look it up under the AC section of their parts catalog for your car. Costs around $30.
To install, remove the belt cover (1 bolt 1 nut) and the entire idler assembly (2 bolts at the top of it; I loosened the tension first though I'm not sure that that is necessary except to re install) Take off the pulley, knock out the center section to put in your new pulley, and re install.
Mental is offline   Reply With Quote
Old 12-09-2012, 09:40 PM   #3
shano
Member#: 223839
2004 WRX
Java black
Yup just did mine, the pulley was metal and better quality than the oem one. Annoying sound gone!
shano is offline   Reply With Quote
Old 12-10-2012, 06:09 PM   #4
multiplexer
Member#: 39518
I've got a similar noise on mine. Every morning, about a minute after I start her up, I hear this low frequency whine. It goes away as it warms up. I went ahead and replaced the idler pulley since it was a relatively cheap part but it wasn't the cause in my case.
Removing the Alt/PS belt eliminates the noise. I noticed there's a little play in the PS pulley and none in Alt pulley. Is this an indication of PS pump going out? Any way to service it? I don't see any leaks.
I tried to use a screwdriver as a stethoscope but both Alt and PS are noisy. I couldn't tell if one sounds worse than other. Both pulleys spin by hand without noise, but the PS pullet is considerably harder to keep spinning (it stops almost instantly).
multiplexer is offline   Reply With Quote
Old 12-10-2012, 06:12 PM   #5
Member#: 301037
2004 Forester XT
Yeah this is one of those limited times that Advance Auto Parts has a better part than oem.
art@grimmspeed is offline   Reply With Quote
Old 12-10-2012, 06:13 PM   #6
Prlbluwrx
Member#: 307853
2005 WRX
Very easy to replace most parts store will stock it. Mine went out at about 115k. it started making a grinding noise. It took me about 30 min to swap.
Prlbluwrx is offline   Reply With Quote
Old 12-12-2012, 03:18 AM   #7
ierichuljev
Member#: 330442
Are there any write ups for this ? Or should I just taw it to Subaru ? I know Incan do it I just need the guidance lol.
Old 12-16-2012, 05:19 PM   #8
ierichuljev
Member#: 330442
I fixed it today was the easiest fix ever I didn't even need directions . It's only 3 bolts and no more annoying whine ! Thanks everyone for the help !
