Old 12-09-2012, 01:47 PM   #1
121
Member#: 247832
Default Coolant level going up and down
hello,
recently got a WRX 2004. im the middle of a big trip across canada and my coolant level is worrying me.
i drove 900 miles in the past 2 days and checked the coolant in the reservoir and it was under the Low mark. Topped it up to the middle and drove another 300 miles. checked it this morning and it was again a bit under Low. topped it up to the three quarters of the reservoir in the morning before leaving fearing that i could have a leaking somewhere. checked it for leaks and theres, apparently no leaks. drove another 60 miles and checked for coolant with engine still hot and it was way above FULL ??
its been really cold those days (around 20F) and my question is it possible that the coolant is being kept inside the circuit when stopped for a long time to protect engine from cold and taken back to the reservoir when engine hot ?
my oil looks good, though very full, and coolant in the radiator is the color it should be.
would appreciate any help, thank you.
121 is offline   Reply With Quote
Old 12-09-2012, 01:48 PM   #2
121
Member#: 247832
btw, no overheating and we are pretty loaded.
Old 12-09-2012, 02:03 PM   #3
02MBPWRX
Member#: 310772
MBP
Do you smell any coolant burning in the engine bay when the car has been running? Is there any white smoke coming from your exhaust when revving? Coolant can only leak or burn. Otherwise it just recirculates. The level in the resevoir tank varies at times.
02MBPWRX is offline   Reply With Quote
Old 12-09-2012, 02:04 PM   #4
2002Bugseye
Member#: 294245
2002 Impreza WRX
Platinum Silver
The owners manual should state whether to check the coolant with the engine warm or cold. Sounds to me like you have nothing to worry about.
When the engine is hot, the coolant expands and flows out through the radiator cap into the overflow tank. When the engine is cold, the coolant does the exact opposite and condenses (Not in the sense of water condensing on a window, just molecularly gets smaller) and creates a vacuum which in turn causes a vacuum in the system which draws coolant back in from the overflow tank.
2002Bugseye is online now   Reply With Quote
Old 12-09-2012, 02:04 PM   #5
121
Member#: 247832
no, no smells in the engine bay. the smoke is white so as all the cars surrounding me, its so cold...
Old 12-09-2012, 02:07 PM   #6
121
Member#: 247832
okay, thats reassuring but could it make such differences in the reservoir (from middle level to too Full ?
Old 12-09-2012, 03:10 PM   #7
johnfelstead
Member#: 856
2005 JDM STi
When the engine is stone cold, take the header tank filler cap off and check the level in there. If it is full you have nothing to worry about. If it isnt full, top it up and then set your expansion tank level to full.
The water level in the expansion tank should then go above full when it gets hot, and then drop down to between full and low when it's cold.
johnfelstead is offline   Reply With Quote
Old 12-09-2012, 04:31 PM   #8
bluestone
Member#: 36583
2004 WRX sedan
I have the opposite problem. The level in my overflow tank is stuck like a rock and never moves. Radiator and upper reservoir tank are full. Operating temps are 200-207.
bluestone is offline   Reply With Quote
Old 12-16-2012, 08:12 PM   #9
121
Member#: 247832
Finally it was just the cold that made the coolant retract. Thanks for everything guys!
