Old 12-15-2012, 07:43 PM   #126
diesel87
Member#: 337899
Default Part #s
Here are the part numbers i have for my 05 LGT (same as wrx, I think) which of these needs to be updated to the superseded (redesigned) numbers?
The tech on the phone said something about the 806322050 changes to 080.
Is that right? Any others?
any help would be great.
Item Detail Part# Qty Price Total
BALL BEARING
Make: Subaru 806230170 1 $26.22 $26.22
BALL BRG 55X80X13
Make: Subaru 806255010 1 $30.68 $30.68
ROLLER BEARING
Make: Subaru 806330110 1 $18.68 $18.68
ROLLER BEARING
Make: Subaru 806322050 1 $28.02 $28.02
OIL SEAL
Make: Subaru 806735210 1 $5.76 $5.76
diesel87 is offline   Reply With Quote
Old 12-16-2012, 09:55 PM   #127
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Originally Posted by MMaxim View Post
Hello everyone,
I've been reading up on the forum for a few months and found a great load of useful information including this thread.
After taking the tail section cover off and pulling the center differential out on my 2004 Subaru Forester XT I found nothing extreme. Just the bearings that are a little worn out and a little noisy. My main concern is the burnt discoloration on my center differential. Before I took it all apart there was no clunking or banging in tight turns.
Is there any way to test the differential, FSM says nothing about the procedure.
Some of them look that way. I think it's from the hardening process after they cut the splines into them. Nothing wrong with it.
Crazykev is offline   Reply With Quote
Old 12-18-2012, 02:39 PM   #128
alsointoaudis
Member#: 327979
2004 WRX
The only difference I got was 806330110 went to new part # 806330120. Where did you get these prices from? These are cheaper than what I paid last week and mine where the cheapest I could find?
BALL BEARING
BALL BRG 55X80X13
ROLLER BEARING
ROLLER BEARING
OIL SEAL
alsointoaudis is offline   Reply With Quote
Old 12-22-2012, 07:40 PM   #129
diesel87
Member#: 337899
Need help fast!
pulled the tranny on my 05 LGT today and found that yes the center diff bearings are shot. I also found that both sets of gears are missing teeth and the diff itself looks bad. I plan to crack the trans and check it as well.
I need the whole extension assembly including diff. Does anyone have any leads or know of the best place to look?
I may need the trans too ill let you know.
If I need to be posting in a LGT specific thread or forum, sorry, I've just found this thread to be the most resourceful.
Old 12-22-2012, 09:59 PM   #130
MMaxim
Member#: 314456
Thanks, that's what I thought.
MMaxim is offline   Reply With Quote
Old 01-12-2013, 07:19 PM   #131
Proper282
Member#: 294084
02 Wrx Wagon
MBP
Originally Posted by drewmob View Post
That happens. Luckily those are relatively cheap gears. Be sure to replace all 4 xfer bearings when you fix it. You'll be shocked @ how many shavings are in the bearing underneath the Allen bolts.
Cheap? I was quoted $425 for new ones. But if you can find a used set they can get pretty cheap
Proper282 is offline   Reply With Quote
Old 01-12-2013, 11:32 PM   #132
drewmob
Member#: 214192
2003 WRX
Apparently you either don't know what the word relatively means or you don't have a clue how expensive everything forward of that is to replace.
& yes, the way i meant it is the parts are plentiful in the second-hand market & extras are laying around at most make-specific shops.
drewmob is offline   Reply With Quote
Old 01-22-2013, 07:55 AM   #133
EE06STI
Member#: 124580
Thank you everyone who contributed to this thread. I just replaced these 4 bearings on my 2004 WRX, and it was fairly easy thanks to the input here.
EE06STI is offline   Reply With Quote
Old 01-23-2013, 12:23 PM   #134
03SedonaRedPearlWRX
Member#: 344629
2003 Impreza WRX
Sadona Red Pearl
I am new to this site. I have a 03 WRX & I'm having a slip problem. It would feel like a clutch slip, but here is the twist, the speed goes up as the rpms go up. Car accelerates very slow. It was random a couple months ago, yesterday it was the whole drive to work and back home. Car goes places, but on the way home I started to get noises and some clunking from the trans area. I feel its the center diff or about there. I changed the diff fluid 6,000 miles ago, no metal on the plug. I am willing to take the tail section out of the car. I'm very mechanically inclined, but after reading this post, I get wet feet and think I don't want to do this alone. Any insight on this is appreciated.
03SedonaRedPearlWRX is offline   Reply With Quote
Old 01-23-2013, 01:12 PM   #135
drewmob
Member#: 214192
2003 WRX
Is it a manual or auto? That sounds more like the clutch packs in an auto tranny...
Old 01-23-2013, 03:59 PM   #136
03SedonaRedPearlWRX
Member#: 344629
2003 Impreza WRX
Sadona Red Pearl
Manual Trans - Stock 5 Speed. Wish it was auto, would just send it to the tans shop and be done with it.
Old 02-01-2013, 07:40 PM   #137
USLiberty
Member#: 294466
1993 Legacy SS
white
What year transmission are these part numbers for? I ordered all the bearings to replace them and 3 of the 4 bearings were wrong parts. Those three part numbers were canceled and referred to another part number #. I have an 02 wrx trans
Edit* I found these bearing do fit! They were deferred to another design of bearings so visually they looked different. Got 2 of 4 bearing installed myself, hopefully one of the machine shops around here can get the rest.
USLiberty is offline   Reply With Quote
Old 02-05-2013, 03:05 PM   #138
USLiberty
Member#: 294466
1993 Legacy SS
white
Successful! Great thread! I would of had to drop a lot of money for the 6 speed swap. The transmission I installed was missing the large diameter bearing on the center diff all together. So I'm lucky nothing broke while I drove it.
Old 03-20-2013, 10:14 PM   #139
stiboss
Member#: 111811
98 Impreza RSTi
I have one set of these bearing available if anyone looking for them. thank you
http://forums.nasioc.com/forums/show....php?t=2480088
stiboss is offline   Reply With Quote
Old 03-23-2013, 02:50 PM   #140
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
FYI, this..
Originally Posted by poop24 View Post
For those of you that would rather pull your own bearings rather than take them in to a shop, I used the following kit from Harbor Freight. It was only $44 with the 20% off coupon. http://www.harborfreight.com/bearing...set-93980.html
The only one it doesn't work for is the big bearing on the center diff.
Good luck!
did not work on the below bearing for me. What did you guys use to pull this bearing?
Edit- did work, i didnt think i could pull from the flange. Thats exactly what i ended up doing, worked great. Waiting for my Ultra Grey to cure and then to see if i was successful or not.
Swine is offline   Reply With Quote
Old 03-23-2013, 03:18 PM   #141
klinebau
Member#: 122383
2006 WRX Wagon
You don't need a puller for that bearing. There is only a snap ring holding it on.
klinebau is offline   Reply With Quote
Old 03-24-2013, 09:58 AM   #142
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
negetive on the above response. The bearing is "pressed" on. The snap ring doesnt hold the bearing in place on the shaft.
I have 5mt rear shafts with bearings etc in classified if needed.
04stigeorge is offline   Reply With Quote
Old 03-24-2013, 11:14 AM   #143
drewmob
Member#: 214192
2003 WRX
I think he meant that you don't need a press. It hammers on/off without much force.
Old 03-24-2013, 11:39 AM   #144
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Full of ****. Haha atleast for me. Hammered the hell out of that thing and it didn't budge. Also, much safer for the gear teeth to use a puller then a possible accidental blow and a chipped gear tooth. Then your day is REALLY ruined.
Old 03-24-2013, 02:32 PM   #145
drewmob
Member#: 214192
2003 WRX
Meh. Different stokes...
Old 04-18-2013, 11:20 AM   #146
channoff
Member#: 240577
Just bought my stethoscope and looks like I am now in the center diff boat as well. It appears that most of you are WRXers and I have a 2005 LGT. With all the new and updated part numbers, can anyone direct me to correct part numbers for my car?
Update:
Looks like I found correct items:
806230170 BALL BEARING $29.23
806255010 BALL BRG 55X80X13 $33.88
806322080 ROLL BRG 22X56X17 $30.94
806330120 ROLL BRG 30X62X17 $26.87
Sub Total: $120.92
If any of these look wrong, please let me know.
channoff is offline   Reply With Quote
Old 06-03-2013, 01:01 AM   #147
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
So my wrx started making some tranny noises and it sounds like its coming from the back of the tranny. I cannot hear it at all in first and second gear, can kinda hear it in third, can definitely hear it in fourth, and fifth is the loudest. One other thing I noticed is if I push the shift knob when in fourth or fifth gear the whine gets louder (it does inside the cabin but I can't really tell if it makes it louder outside of the car). My question to you guys that replaced these four bearings, did the whine get louder as you went into higher gears without speeding up. For example I speed up to 40 mph and from third to fifth the fifth gear is loudest, oh and the whine disappears when I let the throttle off. Thanks to all of you.
alexmartynyuk is offline   Reply With Quote
Old 06-03-2013, 07:24 AM   #148
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i had a noise a lot like you describe. tore off the transfer case and bearings were fine. ended up being the snout bearing on the rear diff. sound conducted through the driveshaft and appeared to be coming from the tranny...
fwiw
ken
Old 06-03-2013, 07:25 AM   #149
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ps. the only way i found it was to put everything back together, get the car up on 4 jackstands, start it up, put it in gear, and CAREFULLY climb underneath with a stethescope.
Old 06-09-2013, 04:32 PM   #150
alexmartynyuk
Member#: 191967
2002 wrx
So I got 3 of 4 bearings replaced and i'm waiting on the fourth one because subaru didn't have it in stock. You don't need a hydraulic press to do this, but the harbor freight puller will be needed or something like it. To install the bearings I put the shafts in the freezer for a couple of hours and used a heat gun to heat up the bearings right before I pulled the shafts out of the freezer and used a wooden block and a hammer to "press" the bearings on. Before I put everything together I was wondering how do you check for clearances/play to choose the proper shims? my tranny is in the car. Also the parts diagram that subaru gave me lists three adjusting washers, one that I never had one in my car which is supposed to go behind the ball bearing that is secured by four 6mm hex bolts.
NEED: Center Diff/Transfer Case MyRuRex Private 'Wanted' Classifieds 8 08-26-2015 08:22 PM
WTB: center diff / transfer case for my 98 2.5RS MR2fanatic Private 'Wanted' Classifieds 1 10-01-2009 12:52 AM
FS: IN: 04 STi 6 Speed With Center Diff And Rear Diff STiGuy46554 Drivetrain 5 09-20-2008 12:10 PM
For sale 02 WRX tranny case,center diff and drive gears felixwankel88 Drivetrain 2 06-06-2007 06:22 PM
Bearing preload for center diff transfer gears. 340Duster Transmission (AT/MT) & Driveline 2 05-21-2007 04:24 PM
