Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 12-16-2012, 03:21 PM   #1
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Default Infrared Testing Volume 5 **featuring Process West/now enhanced with PTP Lava Wrap**
In this installment we will be taking a look at the Process West top mount intercooler for the 08+ WRX. I will be taking a look at the stock TMIC first, then the Process West TMIC under the same conditions. Now this will not be a true performance indicator, but it is just taking a look at the heat soak characteristics of the product, which in turn will have some impact on performance.
Stage 2 TP tuned
COBB catted downpipe wrapped with DEI titanium thermal wrap
SPT cat back exhaust
GRIMMSPEED turbo heat shield with DEI gold foil on underside
PTP Lava turbo blanket
Process West TMIC kit
FORGE recirc BPV
The WRX will be subjected to extended idle times of 20 min after operating temperature has be reached. The hood will remain closed until the infrared camera will be in use. The outside temperature is 38F. The temperature is very low and should be noted that his will not be typical results that you will encounter during any other time of year. Another important factor to remember is that these are results with thermal products in use so these results are almost a best case scenario with the outside temperature and the thermal products at work under the hood.
The OEM TMIC hot side also has DEI's gold foil on it.
Now after looking at the Process West TMIC installed, the unit is a far superior product compared to the stock TMIC. The core itself should resist heatsoak better than the OEM TMIC. The plastic end tanks of the OEM TMIC are made of some kind of plastic resin that is black in color, which is a poor performing color under the hood. Now initial concerns of the Process West TMIC kit is the black silicon hoses used on the ends of the TMIC. The placement also on the hot side locates the hose directly over the turbo, which would directly impact temperature performance. First lets take a look at the OEM TMIC through the eyes of the infrared camera.
This next image gives you an idea of how much heat is radiating from directly below the TMIC
Now on to the Process West TMIC images.
Old 12-16-2012, 03:23 PM   #2
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
(ran out of room in thread for pics)
Old 12-16-2012, 03:24 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I wish I had one of those nifty cameras...Keep these coming.
Old 12-16-2012, 09:07 PM   #4
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Here are some images of the Process West TMIC after some driving with 2 wot runs.
Old 12-16-2012, 10:09 PM   #5
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
and here are a few images of the OEM TMIC after a little driving and some wot runs.
Old 12-16-2012, 10:15 PM   #6
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Overall the Process West TMIC resists heat soak better than the OEM version. Some areas of both of the top mounts reach the same temperatures (cold side) while the hot side areas of the Process West TMIC stay much cooler while exposed to the same temperatures. There is some room for improvement using some of the thermal control products that we have seen before to help aid in keeping the temperatures as low as we can.
Old 12-16-2012, 10:37 PM   #7
alva8193
Member#: 318755
2012 Phatbotti Tuned
Thanks again for all your testing and contributions! Glad I have the PW
alva8193 is offline   Reply With Quote
Old 12-17-2012, 11:51 PM   #8
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
you're welcome!
Old 12-18-2012, 04:51 PM   #9
tekfoc
Member#: 21392
2014 CLA 45 AMG MB
WHITE /07 STI IS SOLD
nice job
tekfoc is offline   Reply With Quote
Old 12-19-2012, 08:47 PM   #10
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by tekfoc View Post
nice job
thanks!
Old 01-19-2013, 09:02 PM   #11
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I had some PTP lava wrap around so I decided to put it to some good use. I wrapped the silicon hoses of the PW TMIC to see if it would have a positive affect with temps.
I didnt get too involved with testing, just took a quick image and found it knocks down around 15F on average. So its nothing huge, but every little bit counts.
Old 01-19-2013, 10:36 PM   #12
cineris
Member#: 263329
2011 Impreza WRX
Very happy to see this as I have both this model and intercooler. Thanks for your service to the forum .
cineris is offline   Reply With Quote
Old 01-20-2013, 01:27 PM   #13
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Its the best tmic available for us at the moment. you are very welcome and hopefully there will be more to add in the future.
Old 01-20-2013, 11:18 PM   #14
flk
Member#: 280838
MY12 WRX DGM
EFI Stg2+
Hero, I would suggest gold wrapping your IC and hose if you're anal like me; not exhaust wrap. We are trying to reflect and not absorb / trap heat. Keep in mind the PW splitter for your hood directs air both onto the IC as well as the left and right corners which direct air over the hose as well as onto the turbo/DP. Here's mine.
flk is offline   Reply With Quote
Old 01-21-2013, 07:34 AM   #15
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
The reflect-a-gold is a far better choice for the application and would do pretty well. The hotside of the tmic is exposed to high temps from all around. Sometime I will get some more of that product.
Old 01-21-2013, 11:33 AM   #16
90crxfreak
Member#: 318642
2012 WRX Premium
Do you think the lava blanket can fit under the stock heat shield?
90crxfreak is offline   Reply With Quote
Old 01-21-2013, 12:50 PM   #17
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Its probably twice the thickness of the original but I bet you could squeeze it under. The grimmspeed heatshield would be a great addition too and would definitly house that blanket.
Old 01-21-2013, 12:59 PM   #18
90crxfreak
Member#: 318642
2012 WRX Premium
i was thinking of using a blanket, stock, and SPT heat shield. I hear they go over the stock one.
Old 01-21-2013, 01:32 PM   #19
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Awesome set up! I'd love to test that out for a nice comparison
Old 01-25-2013, 08:32 AM   #20
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Kinda curious to see how the heat reflective tape works on the IC to turbo hose and around the TMIC itself. I also have the PW unit (wrapping it in a week or so) and I'd love to see how much it helps.
Old 01-25-2013, 03:24 PM   #21
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Check out infrared testing volume 2 featuring DEI for the oem tmic. That thread should give you an idea of its effectiveness.
Old 01-26-2013, 08:37 AM   #22
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
I had this exact setup for a while. Just to let you know, the SPT "heat shield" is not much of one really. It is more for looks. It may do a little, but don't expect much difference. But I also account some of that to the stock ones excellent coverage of the turbo. If you are that devoted to anti heatsoak I recommend a ceramic coat on the outside of the stock shield.
gutie04 is offline   Reply With Quote
Old 02-15-2013, 12:24 PM   #23
kingsalami
Member#: 206257
2009 WRX 5-door
You are correct, sir.
I've got this exact setup on my Cobb catted DP & it works very well. To make the SPT actually block heat, you can place reflective material on the underside.
kingsalami is offline   Reply With Quote
Old 02-15-2013, 12:58 PM   #24
insaneimpreza
Member#: 83291
1998 Subaru RSTi
Red
Very cool pics and good info! I like that TMIC setup as well, def a nice alternative to the typical TMIC's.
insaneimpreza is offline   Reply With Quote
Old 02-15-2013, 07:08 PM   #25
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I've been running this tmic kit for about 2k miles with no issued yet. I've upgraded to t bolt clamps as the worm gear clamps gave me some problems. I'm glad you like the pics. Give the other infrared threads a peek to. Its not the time of year that most people think about this stuff.
