#3251 |
Member#: 118141
Vehicle:95 'lifted' legacy |
Subaru RX (85-89), aka 3rd generation Leone.
![]() ![]() they're upwards of $350-$400, because they're relatively rare. The datsun folks love them too as they swap into datsun/nissan R160 diffs. (e.g. :http://www.the510realm.com/viewtopic.php?f=10&p=150468 http://forums.nicoclub.com/subaru-r1...o-t186165.html (copied from wiki) "The RX 3-door hatchback is comparatively rare as only 2600 units were made during its 1987 to 1989 production run. Very few remain operational today. It can be recognized by a rear wing, factory ground effects kit and white paint with white wheels. Most RXs were white. The RX was equipped with the EA82T turbo engine, as found in the XT Vortex mated to a five speed manual transmission. The drivetrain featured a 3.70:1 rear Limited Slip Differential as well as a locking center differential and two speed transfer case. The gearbox also featured a 1.592:1 low range activated via a center console mounted lever. Other characteristics were; rally tuned suspension, four wheel disc brakes, power windows, A/C, central locking, power sunroof, adjustable seats and steering wheel, split fold-down rear seats, full indicative panel, Hill Holder and 1,070 kg (2,359 lb) of weight. 1989 marked the end of the production run for the RX."
#3252 |
Member#: 307627
Hmm. I was talking LSD for my 2012... Must have been some confusion
#3253 |
Member#: 304662
Vehicle:2001 Impreza L coupe Sedona red Pearl |
I've only ever seen one RX, and at first I was like WTF is this? Subaru? "Full time 4WD"? Coupe?!
Definitely a cool car though. |
#3254 |
Member#: 103208
Vehicle:2011 Outback Azurite Blue |
#3255 | |
Member#: 170489
SCIC
You can run the Kings without a damper upgrade, but they work out a lot nicer with one. The increased rates on their own work the standard dampers out pretty well, toss in rough terrain and the job gets even tougher for them. Greg's set up was Feal inserts/shocks. In front you get a insert that installs into the stock strut body, and in the rear you get a complete new shock. The inserts are valved to match the increased rates of the kings, as well as for rough terrain (gravel valving). The new inserts are also damping adjustable now. Ride quality is excelletn on paved or unpaved roads as the Feal units are far superior performance wise to the standard dampers. As for Forester suspension, I think stuff off the 09+ Foresters might work, as it is similar to the 08+ Impreza suspension. We haven't tried it yet though, so I don't really know what all would be involved. With the Kings+Feal+spacer set up though, you get a lift as well as improved dampers. -Anthony |
#3256 | |
Member#: 307627
#3257 | |
Member#: 280844
TXIC
Vehicle:2006 STi OBP |
#3258 |
Member#: 307627
Any steering issues Greg?
#3259 |
Member#: 260501
AKIC
Vehicle:2011 WRX 5dr SWP Ltd |
#3260 | |
Member#: 280844
TXIC
Then? No. Now? Yes.
![]() Quote:
#3261 |
Member#: 197764
Vehicle:02 WRX Stage DD PRND 01G |
#3262 |
Member#: 292608
Vehicle:2012 WRX Hatch WRB |
Will 225/70-R15's fit a stock suspension 2012 WRX or are spacers going to be needed?
#3263 |
Member#: 307627
#3264 |
Member#: 280844
TXIC
#3265 |
Member#: 318332
Vehicle:2012 Impreza 5-Door 1981 Corolla Wagon |
quick question about gravel tres -- are you able to use them for daily driving?
how noisy are they? do they last longer than standard tires when used dor daily driving? |
#3266 | |||
Member#: 280844
TXIC
#3267 | |
Member#: 318332
Thanks. I've been looking for a set of gravel tires I can use for daily driving as well. Any suggestions? Grabbers? Bridgestone? DMack? |
#3268 |
Member#: 73974
Vehicle:00 2.5RS Sedona Red Pearl |
so...decided that in lieu of the snow storm coming i would ad some clearance to my car....
just on some ISC coil overs...wheels are stock S5 TII RX-7 16"ers and i have some adapters on there so they poke slightly...but otherwise there just 16x7's with 205/55 stock sized General Altimax Artics.. the sedan u see poking its ass in the pic will be lifted on some Fozzy suspension and maybe more that will have a better spec sheet for this thread after its running... ![]() before: (quick setting as i just got it running before hand...will end up lower though )![]() Now: ![]() |
#3269 |
Member#: 280844
TXIC
No prob. I'd say Yokohama Geolanders. Smallest A/T tire I've found available. Unless someone else has found something that will work better.
#3270 | |
Member#: 170489
SCIC
Actual gravel tires will get burned up in no time on tarmac driving. So to be sure we're all on the same page..... All terrain (Geolander etc.....) Okay for road driving (designed for it in fact) Actual gravel tires ( Lassa, BFG Pirelli, Dmack etc....) Not okay for road driving ![]() The soft compound and sharp tread blocks make them awesome for dirt/gravel, but get super hot for road driving. You can trash a set of soft compounds real quick on tarmac driving. The harder compounds fair a little better, but still not advisable for daily driving by any means. -Anthony |
#3271 |
Member#: 280844
TXIC
Good call Anthony, wasn't even thinking about that. Gravels =/= all terrains.
#3272 | |
Member#: 318332
#3273 |
Member#: 221308
TXIC
Vehicle:2009 Impreza 2.5i Orange |
Here's what we do in Texas:
#3274 |
Member#: 337607
That video is so badass wish I had an area like that
#3275 | |
Member#: 337607
I want these lol
| Thread Tools | |
| Display Modes | |
| SOA gotta love 'em or just plain hate 'em | kalbo-1 | Warranty Issues & SOA Problems | 1 | 01-19-2004 08:29 PM |
| Hot or Not or Just Plain Ok.... | n20x3whitewrx | Member's Car Gallery | 28 | 07-29-2002 10:05 AM |
| McRae: Dedicated or just plain nuts? | SubaruStu | Motorsports | 2 | 03-20-2002 09:55 AM |
| Chamois, or just plain Sham? | Lifino | Interior & Exterior Modification | 7 | 04-11-2001 12:01 AM |
| Jinxed? Or just Plain UnLucky??!! | silverSurfer | General Forum Archive | 6 | 06-30-2000 10:27 PM |
