Old 12-18-2012, 12:08 AM   #1
PAHULL
Member#: 257247
2005 WRX STI
Subaru WRX STI
2.5L
WRB W/bbs
110,000 miles
Full interior and completely stock exterior
Currently 225/45/17 Bridgestone Blizzaks until the build is completely done
I bought this car completely stock with the intention of building it into a reliable, high powered weekend car. My daily driver is a stock 2013 WRX hatchback PB.
Our first successful dyno run was in September/October. It was the day or the first New England snow event (32F)
This car(as well as every Subaru I have owned) has been tuned by Matt Miner at Wicked Innovation.
The car was dyno tuned at Dynotech in seekonk, Ma. They use a mustang dyno.
I'm sure I'm forgetting some but at the time of the Dyno run the modifications were as follows:
SHORTBLOCK:
Wiseco pistons
Manley rods
Arp head studs
Killer B pick up/plate
ACL bearings
Oem Nitrited crankshaft
Oem gasket kit
Oem case bolts
Oem timing belt kit
TURBOKIT:
Perrin rotated GTX3076R kit
Perrin EQL headers
Perrin Fmic kit
Kstech 86mm rotated intake
Invidia G200 exhaust
FUEL:
Wicked parallel fuel kit(aeromotive reg, lines, fittings etc)
Top feed TGV housings with Kstech delete kit
Aeromotive 340lph pump
1000cc injectors
NGK Iridiums
Premium unleaded- 93 octane
SUPPORT:
Crawford AOS V2
ACT HDR4 clutch kit
STRI gauge set up/Ati pod
Grimmspeed hybrid ebcs
Aem 3.5bar map sensor
Map sensor adapter
Tial 44mm wastegate
Bov
A/c delete
Had a vacuum leak the day of the dyno(fitting on the waste gate was loose)
Car made 455/415 on 27 psi peak from 4300-7000
With a heavier waste gate spring and a few more adjustments the car should make another 20-30 more ft lbs of torque and some more hp as well. Haven't decided on meth injection yet, to reach my 500hp goal.
I will keep this updated! More details to come over winter . Thanks for viewing!
PAHULL is offline   Reply With Quote
Old 12-18-2012, 12:11 AM   #2
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
That's awesome!
07wrx84 is offline   Reply With Quote
Old 12-18-2012, 12:12 AM   #3
PAHULL
Member#: 257247
2005 WRX STI
Thank you!
Old 12-18-2012, 12:34 AM   #4
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Have a dyno plot?
pet3r is offline   Reply With Quote
Old 12-18-2012, 12:38 AM   #5
Tiller35
Member#: 217006
Ive been waiting for a build exactly like this.
Subscribed.
Also, .82 AR?
Tiller35 is offline   Reply With Quote
Old 12-18-2012, 06:08 AM   #6
PAHULL
Member#: 257247
2005 WRX STI
Yes I do, just would have any idea how to post a picture of it here
Old 12-18-2012, 10:58 AM   #7
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Nice build and power! Post the dyno plot up! Matt's a good guy to work with
Old 12-18-2012, 11:57 AM   #8
PAHULL
Member#: 257247
2005 WRX STI
Matt is the best! Thank you!
Old 12-21-2012, 05:46 PM   #9
What v8
Member#: 254718
Subscribed.
Also, .82 AR?
wondering this as well.
What v8 is offline   Reply With Quote
Old 12-21-2012, 09:43 PM   #10
induction addiction
Member#: 340643
I'm sure your using race gas and not E85 correct?
induction addiction is offline   Reply With Quote
Old 12-21-2012, 09:44 PM   #11
induction addiction
Member#: 340643
I'm sure your using race gas and not E85 correct??
Old 12-22-2012, 12:16 AM   #12
Tiller35
Member#: 217006
It says 93 under fuel
Old 12-22-2012, 12:27 AM   #13
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Would still love to see a dyno plot -- upload to www.imgur.com and post a link
Old 12-22-2012, 07:38 AM   #14
PAHULL
Member#: 257247
2005 WRX STI
Work has been nuts! Ill upload a picture of the dyno plot tonight
Old 12-22-2012, 11:31 AM   #15
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Subscribed.
Also, .82 AR?
not sure the .63 could even make this much power, assuming .82 not fully cranked up yet
Irv Weissmanhowerton is online now   Reply With Quote
Old 12-22-2012, 11:48 AM   #16
PAHULL
Member#: 257247
2005 WRX STI
Sorry, yes .82 AR. Back to dyno in the spring
Old 12-22-2012, 02:13 PM   #17
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Nice set up, fun for sure, need the plot
Kastley85891 is offline   Reply With Quote
Old 12-23-2012, 03:23 PM   #18
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Im waiting on my tgv delete and intake and ill be ready to break in nearly the same build. Slight differences. Be awesome to get more specifics and a chart up.
Scuby04STi is online now   Reply With Quote
Old 12-23-2012, 03:58 PM   #19
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Same, just finished my build myself, pretty similar setup.
Old 12-23-2012, 07:49 PM   #20
funk32
Member#: 245787
2004 STi
which sping are you using in your ewg right now? and what will you go to?
funk32 is offline   Reply With Quote
Old 12-29-2012, 06:04 PM   #21
chongl
Member#: 187694
2009 GTX3076 WRX
520whp on E85
I made 5whp and 3wtq less on the same turbo. Nice numbers!
chongl is offline   Reply With Quote
Old 12-29-2012, 06:58 PM   #22
PAHULL
Member#: 257247
2005 WRX STI
Am using 14psi springs. Going to 20psi on a hybrid boost control setup. And thank you!
Old 12-31-2012, 01:35 AM   #23
Member#: 278519
30r E85 sti 450+whp
kb'izzle
get that spring and push this thing gtx shines in high boost
Old 12-31-2012, 08:38 AM   #24
PAHULL
Member#: 257247
2005 WRX STI
I had a boost leak on dyno. But swapping out springs tonite to a 1.4 bar (20 psi) set up. Then ordering a grimmspeed mbc
Old 02-02-2013, 02:09 AM   #25
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
in for dyno sheet.
Excision is offline   Reply With Quote
