Old 12-08-2012, 10:55 PM   #1701
08fg2
Member#: 281219
2012 wrx hatchback
satin white pearl
subscribed. maybe one day ill get to doing this. looks like PITA though.
08fg2 is offline   Reply With Quote
Old 12-08-2012, 11:07 PM   #1702
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Originally Posted by mistathugh4844 View Post
Where do you guys hide the harness that enters above the turbo?
A lot of people just let it hang. I don't know what other people do.
It is a PITA but it's rewarding. Recently when I go to regional car meets with other people doing the same thing, we spend more time comparing tradecraft and ideas than looking at the rest of the meet.
Smurftastic is online now   Reply With Quote
Old 12-09-2012, 01:40 PM   #1703
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I was working on cleaning up the bay in my 07 wrx wagon...until I hit a deer, totaling both the car and the deer. Now I'm fiddling with my Miata a bit.
The holes in the firewall are for braces, much like the ones that are already there. The tunnel is widened to clear an ls1 & t56.
With regard to shaving bays, I guess the only unique thing here is the relocation of the wiper motor.
Still have to clean this up a bit.
573 is offline   Reply With Quote
Old 12-09-2012, 02:25 PM   #1704
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Originally Posted by sfk1412 View Post
Did you have any issues getting the tmic to fit right with those 8mm spacers? When I bought mine, I grabbed the 3mm ones because I had read that the 8mm wouldn't allow the tmic to line up right.
Jackie leggs is online now   Reply With Quote
Old 12-09-2012, 04:49 PM   #1705
sfk1412
Member#: 290974
2005 WRX Wagon
That's just a mock up. But I did throw the intercooler brackets on and snuggly bolted it all down to make sure everything was gonna fit. Plus I was anxious to see what it was gonna look like . Everything fit fine though and the hood closed perfect with out issues. I was going to get the 3mm ones too then I emailed Grimmspeed and asked them and they said that there wouldn't be a problem so I took my chances.
sfk1412 is offline   Reply With Quote
Old 12-16-2012, 08:29 PM   #1706
SubaL0U
Member#: 322795
Figured I'd share some of my progress. Just started this as a side project for the winter.
Everything out.
Possible fuse box location.
SubaL0U is offline   Reply With Quote
Old 12-16-2012, 10:32 PM   #1707
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Hey guys. Engine shaving newbie here just looking for some tips from those more experienced than i am (read everyone). I've got an old STI and the engine bay is in need of a little brightening up. Right now it just looks like a crowded mess of crap and i just don't know where to start.
I know shaving is quite an undertaking, but I've got to start somewhere and it would be great to know a little before i get going on a project that could take me a very long time.
I've tried my best to start small and break it down to manageable bits so please tell me what you think of my plan. Tips and criticisms are welcome
Remove/clean/paint intake manifold and alternator
Remove turbo chimney and replace with heat shield
Remove/relocate boost control solenoid
-I plan on mounting my new MBC in the same place as the old BCS but I hear the old BCS needs to be reatined to avoid throwing a CEL. Is this true and if so, where can I put it so I no longer see it
Clean/paint rad mounts
-I'm not sure how these come off. It appears to be bolts on the chassis side, but pins or something on the rad side. How do i take these off
Relocate throttle cable
-Can i melt the cable insulation if it ends up touching either the block or the intake manifold or is there a safer way to route it
Tuck in as many hoses as i can
-What kind of hose can i use if i just want to make my own new lines to make it easier to tuck them away so i don't see them anymore
Here's a shot of my bay to give you a general idea of what im dealing with
Millhouse_5 is offline   Reply With Quote
Old 12-16-2012, 10:53 PM   #1708
dub c
Member#: 145069
Keep It Sleazy
Cool project.
In the rain gutter though?
dub c is offline   Reply With Quote
Old 12-16-2012, 11:43 PM   #1709
SubaL0U
Member#: 322795
^ If I do end up putting it there, I am going to shave the vents as well. And probably some weather proofing. I'm trying to keep my harness extending to a minimum.
Old 12-18-2012, 02:08 AM   #1710
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Remove and repaint everything with rust or salt scum on it. Everything. Powder coating is cheap and looks great. Black or silver is clean and blends well. Bright colors on an otherwise dirty or old bay is janky. Trust me on this.
Also, hit up McMaster Carr or a similar vendor and order huge bags of stainless bolts in M6 and M8 sizes with washers and in various lengths. They are WAY cheaper than you'd think. For 50 to 100 bucks you can replace every single bolt that's visible in the bay. It makes a huge difference. Takes a bit of planning, but it's cheaper and less ricey than those dress up kits they sell. I've done my hood bolts, fender bolts and everything else in there. Looks great.
Old 12-18-2012, 03:35 PM   #1711
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Here's my tuck and semi shave until tax time. Then the motor is coming out for the full shave. Any tips on the abs delete. Was gonna do chase bay but keep hearing bad things. What do you guys do.
under0athh51189 is offline   Reply With Quote
Old 12-18-2012, 03:36 PM   #1712
under0athh51189
Member#: 193959
2001 Lexus IS300
Old 12-18-2012, 06:42 PM   #1713
kpluiten
Member#: 120273
06 WRBWRXWGN
The green silicone on that car is incredible. That's my idea of cleaned up. Strightened and sorted while still being functional. Good work; that's what I'm shooting for.
Old 12-18-2012, 07:13 PM   #1714
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
+1 the green looks great.
and yeah, there's a couple issues with the chase bays delete. just get a wilwood brake proportioning valve, and run the lines yourself. it's pretty simple.
ohemgeeitsNiko is offline   Reply With Quote
Old 12-18-2012, 07:30 PM   #1715
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
How are those Fuku Works hoses? I came across them the other day but hadn't heard anything about them.
Old 12-18-2012, 08:20 PM   #1716
sfk1412
Member#: 290974
2005 WRX Wagon
Thats what I was shooting for too. But seeing that my car is going to see winter driving I decided to hold off on the relocation and I just stuck it back in the bay. I couldn't find a way to mount it under my headlight and feel 100% that it was going to stay dry. Better safe then sorry Cool idea though! looking forward to see it done,
Old 12-19-2012, 12:03 AM   #1717
under0athh51189
Member#: 193959
2001 Lexus IS300
Thanks guys. The fuku couplers are awesome. I've got the couplers, rad hoses and inlet and all are very well made and all fit perfect. The quality is top notch. They are double the thickness of eBay ones and are all really stiff. The inlet should hold high power with no collapsing like eBay ones. They currently sell the green, blue and black and are all snake skin looking. Also they will be dropping white and purple soon as well. Highly recommend them.
Old 12-19-2012, 04:21 PM   #1718
WRXWTF
Member#: 257230
02 Silvia S15
GGP
That green wheel is Bitchin
WRXWTF is offline   Reply With Quote
Old 12-19-2012, 09:48 PM   #1719
under0athh51189
Member#: 193959
2001 Lexus IS300
Haha thanks matches everything so had to get it. Grip royal wheel with nrg v2 neo chrome and black quick release with nrg hub.
Old 12-19-2012, 11:33 PM   #1720
iceman967
Member#: 275798
2005 2.61L WRX
Ridiculous Red Metallic
Here is my contribution. There are a lot of wires and hoses that can be relocated, but this will do for now. Eventually Ill do a full tuck and get rid abs, and get rid of power steering. The cold air intake is also only there to run the stock ECU for inspection. When the stand alone is in its a shorty pipe w/ 4 inch diameter.
Oh did I mention its a 2.61l, sleeve, stroked, cammed, and ported motor . Was an 05 wrx now its a hybrid with sti drivetrain swap.
iceman967 is offline   Reply With Quote
Old 12-24-2012, 06:08 PM   #1721
Thenewerguy
Member#: 325141
Itsssss gorgeous
Thenewerguy is offline   Reply With Quote
Old 12-24-2012, 11:44 PM   #1722
under0athh51189
Member#: 193959
2001 Lexus IS300
Thanks bro
Old 12-25-2012, 12:32 PM   #1723
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Has anyone else done a bay on a subaru lately?
D Money is offline   Reply With Quote
Old 12-25-2012, 12:38 PM   #1724
1breel
Member#: 189314
2002 GGSTi
01G
I'd like to push mine into a bay
1breel is offline   Reply With Quote
Old 12-25-2012, 02:00 PM   #1725
Smurftastic
Member#: 243697
02 | BLOD Founding
My bay is coming along, working on the engine harness right now. Sheet metal sitting in the garage waiting to be cut :-)
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 04:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 09:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 02:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-16-2004 12:58 AM
