Old 12-18-2012, 11:38 AM   #4226
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
Really Ben.... SMH
The TS setup... He beat me to it man. No worries
FLEX'N WRX is offline   Reply With Quote
Old 12-18-2012, 11:46 AM   #4227
Jive Turkey
Member#: 219492
Originally Posted by FLEX'N WRX View Post
Really Ben.... SMH
BRO BRO BRO, quad scroll
Jive Turkey is offline   Reply With Quote
Old 12-18-2012, 11:51 AM   #4228
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Why not just put 1 turbo per cylinder?
Old 12-18-2012, 12:08 PM   #4229
Jive Turkey
Member#: 219492
Old 12-18-2012, 12:19 PM   #4230
climbhigh09
Member#: 254163
2011 WRX 20GXTR
You expect your engine internals to withstand that?
climbhigh09 is offline   Reply With Quote
Old 12-18-2012, 12:20 PM   #4231
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My motor can probably handle 500WHP or so.
Old 12-18-2012, 12:27 PM   #4232
tea eye
Member#: 340899
05 wrx sti
wrb
beautiful
tea eye is offline   Reply With Quote
Old 12-18-2012, 12:37 PM   #4233
rkjunior
Member#: 112220
2011 WRX 5DR Premium
rkjunior is offline   Reply With Quote
Old 12-18-2012, 12:59 PM   #4234
climbhigh09
Member#: 254163
2011 WRX 20GXTR
With only some piston, bearings, and studs? The rest of your block is stock STI internals, correct?
Old 12-18-2012, 01:01 PM   #4235
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep, the rods would be next to fail, but STI rods have been known to do pretty well. From some accounts, better than some of the cheaper aftermarket rods. Stock heads will choke flow eventually, but they shouldn't lead to a failure.
Old 12-18-2012, 01:34 PM   #4236
climbhigh09
Member#: 254163
2011 WRX 20GXTR
Interesting. I'm just starting to put together the design for my block, with my 20GXTR and meth, but wanted higher redline and more pressure to fully realize their potential. I was looking at doing some head work as well; mainly just valves and spring and whatever else I can do at home.
Old 12-18-2012, 01:36 PM   #4237
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
For the 20G XTR I think that is mostly unnecessary. It's already running out of breath up top. Maybe some head porting would help, but raising the rev limiter on it's own won't really get you much, especially on meth (vs E85). I don't know that valves/springs would be worth it. I'd discuss this with a more experienced builder though.
Old 12-18-2012, 01:46 PM   #4238
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
There are benefits to headwork outside of power such as throttle response and overall smoothness of acceleration among other variables.
rsutton1223 is offline   Reply With Quote
Old 12-18-2012, 01:58 PM   #4239
Ultimateone
Member#: 48025
17 SWP STI
Originally Posted by rsutton1223 View Post
interesting...
si
Ultimateone is offline   Reply With Quote
Old 12-18-2012, 03:50 PM   #4240
climbhigh09
Member#: 254163
2011 WRX 20GXTR
No E85 for me or I'd still be on the VF
My thought with increasing the RPM isn't necessarily to increase power numbers substantially, but to make staying within the powerband without tickling the rev limiter easier. With your setup, for instance, you can drive between 4.5 and 7k and stay above 400whp. With 93 and meth, I don't expect to make those numbers, but think that the curve will be similar. I'd much rather be able to push until I feel the power drop and shift; knowing I'm still in the power band rather than potentially shorting it and dropping out of boost. Yes... more precise driving could fix this, but so could a little engineering.
That and I know that I'll want more turbo some day, no matter how much I tell myself that I'll be done with this
I'm a long way from buying parts, with the exception of an EJ257 short block that I have sitting in my garage in case I blow up something along the way. For now I'm just trying to feel out what is available before bugging shops about a build.
And, to stay on topic, I found you the perfect tint:
Old 12-18-2012, 04:11 PM   #4241
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
By 7k your power will already be dropping off pretty hard. I rev mine up to about this, but there isn't much point in going past that. I can already tell the power is falling off by that point. Revving to 7k or slightly higher should be fine in case you need to hold the gear a little longer, but I don't see any point in building a motor that can rev to 8k for this turbo...
Old 12-18-2012, 04:50 PM   #4242
climbhigh09
Member#: 254163
2011 WRX 20GXTR
^Agreed; I'd love to see a reliable 7/7.5k though.
Along those lines, I was thinking a little about changing the tach to reflect the adjusted redline. Have you ever considered opening it up and replacing the printed backing? Or a different cluster? That and the stupid clock reflecting the wrong mpg with the larger injectors.
Old 12-18-2012, 04:56 PM   #4243
Jive Turkey
Member#: 219492
to flow above 8k you need a big ol' motha****in turbo most 30r's can't even do that.
as far as the tach i'm debating doing it on the brz, it seems pretty straight forward. however for thee cars there really in't much you can do with the tach because i haven't seen any crazy JDM designs like the GD's have or any over lays...i'm sure you can make that work though, splitting the cluster is pretty simple.
here is a destroked 2.35L with build heads and a 35R ON PUMP with only minor fueling mods. if it were me i'd do this exact setup but i dont know how much a five speed can handle.
http://www.youtube.com/watch?feature...&v=_F30Vzb0qHg
as far a the clock you can cover up that entire thing with a pod but i liked the time there, i know one member took his Accessport apart and put the screen in there instead of the MPG meter, thought that was pretty cool...saw a thread about it.
Old 12-18-2012, 05:26 PM   #4244
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I really couldn't care less about those things.
The tach and clock I mean.
Old 12-19-2012, 01:28 PM   #4245
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
2.5L can rev pretty high too
^That turbo is quite a bit bigger than a 35R though.
Twinscroll Uppipe with Fobia Custom Rotated Flange and Dump Tube with PTE 6266 Turbo:
With Turbo:
^FYI - This is not a twin scroll turbo. It's single scroll and the rotated mount combines the two runners in the twin scroll header. You can tell because there is only one EWG dump.
Old 12-19-2012, 04:05 PM   #4246
Jive Turkey
Member#: 219492
sii, full race makes a lot of headers like that. much more efficient than just having EL and opens up turbo choices.
i say you rotate that dump...to come out of the NA hood. RACECAR.
Old 12-19-2012, 04:10 PM   #4247
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, 1.5 scroll is what it's typically called. Just moves the collector to right before the turbo instead of right before the uppipe. Dump out the hood would be funny.
Old 12-19-2012, 04:20 PM   #4248
Jive Turkey
Member#: 219492
Old 12-19-2012, 04:21 PM   #4249
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I saw that. That's the exhaust though. Not just the dump, lol. That seems pretty common on the Honda drag cars. A little much for a DD though...
Some of the local Subaru's that have Fobia kits do the dump tubes coming out of the fender. That's a little more civil, lol.
Old 12-19-2012, 04:47 PM   #4250
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
smeerone is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
