Old 12-18-2012, 08:30 PM   #14951
scoutisimo
Member#: 315759
2012 Impreza 5 Door
Obsidian Black Pearl
Originally Posted by Dirt Bringer View Post
Does anyone know where to get the rims on the sport premium aftermarket? I could have sworn that someone posted a link to a site selling them a day or two ago on one of these forums but I can't find them anymore. Any clues? Thanks!
They are exactly the same as the WHEELS (not rims) as the legacy gt of a previous year. You may find them easier and cheaper searching that way. Granted they are silver and would need painted.
Old 12-18-2012, 08:43 PM   #14952
aeoporta
Member#: 334126
2013 5mt Sp Premium
Venetian Red & Dark Gray
aeoporta is online now   Reply With Quote
Old 12-18-2012, 08:52 PM   #14953
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Originally Posted by aeoporta View Post
ARRGGGHHHH. My wallet, it burns!
Old 12-18-2012, 09:04 PM   #14954
scoutisimo
Member#: 315759
2012 Impreza 5 Door
Find a wrecked legacy gt. In pa here on craigslist the parts yard has been posting cars. I inquired on wheels. He wanted 300 for the set with tires
Old 12-18-2012, 10:04 PM   #14955
nabokovfan87
Member#: 340943
Are fog lights available as an addition to the premium model? I see them as something you can add to the car in the build section of the Subaru website but on the vehicle specs the premium lists them as "not available"
Yes premium can get them, sport mods come with them stock. I had them added on my old car
nabokovfan87 is offline   Reply With Quote
Old 12-18-2012, 10:12 PM   #14956
Dirt Bringer
Member#: 340297
Ice Silver
I see two sets listed, one for 160 and the other for over 300. Whats the difference?
Old 12-18-2012, 10:23 PM   #14957
Dirt Bringer
Member#: 340297
Ice Silver
Thanks, I've always heard wheels reffered to as rims. Is that a misnomer or the outer edge of the wheel?
Old 12-19-2012, 12:44 AM   #14958
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Looks like one is OEM finish and one is Chrome.
jay25RS is offline   Reply With Quote
Old 12-19-2012, 01:28 AM   #14959
subiedude676
Member#: 241369
2012 2.0i Premium
Ice Silver Metallic
Is anyone having issues with condensation on the inside of their fog lights? My drivers side fog light always has condensation inside of it and I'm not sure what I can do to remove it? Take the bulb out and use a hair dryer to blow hot air inside. Since its getting colder in pa the air is a lot dryer here so I figured using a blow dryer to heat up dry air will dry up any condensation inside after I remove the bulb?
subiedude676 is offline   Reply With Quote
Old 12-19-2012, 09:24 AM   #14960
Dirt Bringer
Member#: 340297
Ice Silver
Is there any difference between the 17" wheels on the premium upgrade package and the sport premium models? They look like they have a different offset though I cant imagine that they actually would to any significant degree.
Old 12-19-2012, 09:55 AM   #14961
uspopo
Member#: 317014
2012 Impreza Sp Ltd.
Dark Grey Metallic
Same size and offset.
Old 12-19-2012, 11:45 AM   #14962
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
Originally Posted by flyboy1100 View Post
turn them on and touch them
my dealership said they only turn on below a certain temp when you hit the switch. I think 40 or below? I don't remember.
Xarthan is offline   Reply With Quote
Old 12-19-2012, 11:53 AM   #14963
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
The temperature on my center dash blinks a few times right after startup at 37F and below, or when driving and it hits 37F.
foghelmut is offline   Reply With Quote
Old 12-19-2012, 12:09 PM   #14964
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
thats a warning mechanism for possible freezing road conditions......nothing more.....a bit annoying if you even notice it....same thing happens if you drive continually for an hour...you get an hour..1:00 blinking as well on the dash
PAO56 is offline   Reply With Quote
Old 12-19-2012, 12:23 PM   #14965
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
If you press and hold the switch you can force them on
Old 12-19-2012, 12:38 PM   #14966
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
The owner's manual makes no mention of this temperature restriction, and I've never seen this restriction myself when using the mirror heater to defog condensation off my mirrors in above-40-degree temps. Here's the text straight from the owner's manual:
The vehicle is equipped with a rear
window defogger. Some models are also
equipped with an outside mirror defogger
and/or windshield wiper deicer. The defogger
and deicer system is activated only
when the ignition switch is in the “ON”
position.
To activate the defogger and deicer
system, press the control switch that is
located on the climate control panel. The
rear window defogger, outside mirror
defogger and windshield wiper deicer are
activated simultaneously. The indicator
light on the control switch illuminates while
the defogger and deicer system is activated.
To turn them off, press the control switch
again. They also turn off when the ignition
switch is turned to the “ACC” or “LOCK”
position.
The defogger and deicer system will
automatically shut off after approximately
15 minutes. If the rear window and the
outside mirrors have been cleared and the
windshield wiper blades have been deiced
completely before that time, press the
control switch to turn them off. If defrosting,
defogging or deicing is not complete,
you have to press the control switch to
turn them on again.
Old 12-19-2012, 04:24 PM   #14967
Zauri
Member#: 333487
2012 Impreza 4DR 2.0
Limited DGM CVT
I was JUST about to ask about that too... agreed it is quite annoying to see
Zauri is offline   Reply With Quote
Old 12-19-2012, 04:35 PM   #14968
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I think the "you've driven 1 hour" flashing digits is more annoying than the outdoor temp warning. At least the outdoor temp warning is trying to tell you to beware of possible icy conditions on overpasses. That's useful.
But tell me this: Why should I care that the car has been running continuously for 60 minutes? Or 120 minutes? Or 180 minutes? Why do I give a damn about that nugget of information?
Old 12-19-2012, 05:07 PM   #14969
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
The windshield deicer won't turn on above 41F or if the car's average speed has been very low. You can force it on by holding the defrost button for several seconds. It will blink, then stay on and you'll hear a click. This is in the service manual but not the owner's manual.
Old 12-19-2012, 05:52 PM   #14970
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
anyone tried to adjust the clutch positioning?
Old 12-19-2012, 06:32 PM   #14971
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
Whoa cool, didn't know about the over-ride or the blinking temp! It was 34 on my dash yesterday and I didn't even notice it blink.
Old 12-19-2012, 07:00 PM   #14972
imprzya
Member#: 12181
2004 STi WRBro
12 Impreza Sport Limited
On my way home from work today my 'at oil temp' light flashed on the called started to stall, then kinda chugged, then went off and the car seemed fine this rest of my way home. Any thoughts on what this is? Anyone else have this happen?
imprzya is offline   Reply With Quote
Old 12-19-2012, 07:25 PM   #14973
Niz
Member#: 340846
2013 CVT Sport Prem
Dark Gray Metallic
Where might one find/purchase the service manual?
Niz is offline   Reply With Quote
Old 12-19-2012, 07:33 PM   #14974
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Search for it on eBay.
Old 12-19-2012, 08:07 PM   #14975
jay25RS
Member#: 4273
2011 GR-STI
Which light is this that tells you the oil is up to temp?
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Message Board Statistics All times are GMT -4. The time now is 07:03 AM.
