Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 12-04-2012, 10:13 PM   #1
Wheels
Member#: 5410
2008 BMW 335XI
Default I feel for all you BRZ owners. :(
Your in for a rough time with the intake valves. My BMW 335 has Direct injection and it suffers from pretty bad carbon and oil build up on the intake valves thanks to the PVC hitting the valves and then they never see gas because of the direct injection and the heat build up makes the oil become a film then a builds up and up till the valves close no more.
Wheels is offline   Reply With Quote
Old 12-04-2012, 10:27 PM   #2
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
I'm just gonna put this here. Take it as you will, I'm not here to argue.
"The Toyota direct injection system I described above is referred to as D-4S and it was implemented on the FR-S/BRZ. However you'll note that Subaru had to resort to just direct injection alone on their own new cars, so those engines will experience the same carbon build up as everyone else. The FR-S/BRZ has D-4S and therefore will not."
Read entire thread here:
http://www.ultimateyota.com/index.ph...&topic=10273.0
Here's a video explaining D-4S
tibug is offline   Reply With Quote
Old 12-05-2012, 09:38 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Correct there is port injection also on the FRS/BRZ so the valves should stay much cleaner. It's been proven on the newer Toyota/Lexus models to help with that issue.
Old 12-05-2012, 12:18 PM   #4
Sub!eDr!ver
Member#: 88924
2007 Tribeca Limited
05 LGT (98 LGT, 88 Justy)
This is factually incorrect. Subaru has designed their own oil/particulate separator for PCV, so no particulates should make it into the intake stream, thus avoiding carbon buildup.
Sub!eDr!ver is offline   Reply With Quote
Old 12-05-2012, 01:16 PM   #5
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I was wondering about that statement about Subaru's Direct Injection. They use Port Injection normally, so it would be odd to not use some form of PI in conjunction with DI, I would think.
Old 12-05-2012, 01:44 PM   #6
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Carbon build up, that's what Seafoam is for. Check out their site, the stuff really works.
LIChuck is offline   Reply With Quote
Old 12-05-2012, 05:46 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Correct it uses both and that's a good thing. First off it keeps the valves clean and secondly it allows for much more HP potential since it's much easier to add larger port injectors and tune them vs. finding and installing larger direct injectors.
The whole direct injected engine apparently was a Toyota must have and apparently Subaru didn't want to use it. In the end it's a huge performance advantage to have DI.
Old 12-05-2012, 06:36 PM   #8
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Is this in all the new Subaru engines? I didn't even know that new Subarus had DI, besides the BRZ, of course.
Old 12-05-2012, 06:47 PM   #9
Sub!eDr!ver
Member#: 88924
This is in all Subaru's new Direct Injection engines (aside from the BRZ). That would include the Legacy DIT (2.0 turbo - Japan-only for now), and the new Forester 2.0 turbo (coming here next year).
Old 12-05-2012, 07:32 PM   #10
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Ah okay, I didn't mean to spread false information. Thanks for the correction.
Old 12-06-2012, 02:35 AM   #11
Tedde22
Member#: 184981
2013 BRZ
Galaxy Blue Silica
I'm curious, how exactly does port injection make any difference to build up?
It's not burning in the intake port so what does it matter? New to this engine stuff, sorry.
Tedde22 is offline   Reply With Quote
Old 12-06-2012, 05:01 AM   #12
ChrisTahoe
Member#: 244749
13 BRZ
14 690 Thumper
It allows fuel to pass over the intake valves, which prevents the carbon buildup.
ChrisTahoe is offline   Reply With Quote
Old 12-07-2012, 10:53 AM   #13
Rootus
Member#: 89821
2015 STI LE
Gasoline is a great solvent. As it passes through the intake port it dissolves any carbon that has started to accumulate.
Rootus is offline   Reply With Quote
Old 12-07-2012, 03:11 PM   #14
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
Use Shell, Chevron as best at no deposit and cleaning up what you get.
Techroline best cleaner.
Masterauto is online now   Reply With Quote
Old 12-20-2012, 11:59 AM   #15
SpamBot
Member#: 287534
Actually, it's the detergent additives in the fuel that prevent carbon buildup. In the BRZ Port/DI engine, you really want to use a Top Tier gasoline. http://www.toptiergas.com/
SpamBot is offline   Reply With Quote
Old 12-20-2012, 12:40 PM   #16
Element Tuning
Member#: 54918
673 WHP Element
I agree but any gas from the addition of port injection really helps to prevent major mechanical issues plagued by DI. Now I can attest to higher quality fuels that have a higher "add pack" to the fuel because we've torn apart hundreds of engines, some with very high mileage and very clean intake ports, and engines with less miles with very dirty intake ports. When we see abnormally clean intake ports I always ask the customer what fuel they run and I hear a lot of Shell and Sunoco. I know Chevron is good but it's just not as common as the others.
OP,
As for feeling sorry about us, feel sorry that our taillights are full of water and our windows squeal like a pig
Old 12-20-2012, 01:23 PM   #17
Sub!eDr!ver
Member#: 88924
Originally Posted by Element Tuning View Post
<snip>
OP,
Possible taillight water solution: Years ago I had a Plymouth Voyager minivan that had the quite-common problem of the front turn signal lights filling with water.
Solution: drill a couple small holes at the bottom of the lens, large enough for the water to drain out. Problem solved.
Old 12-20-2012, 01:49 PM   #18
Element Tuning
Member#: 54918
673 WHP Element
No way, it has only 3400 miles.
There is a recall on this and the dealer is taking care of it. Apparently the taillights are 5 pieces and this is an assembly issue.
I'm glad I didn't smoke the lenses yet!
