Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-19-2012, 12:24 PM   #251
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
I cut and had my line re-brazed. I'll send you a picture
What kind of boost will you be running once its all together and tuned?
gotsugg is offline   Reply With Quote
Old 10-19-2012, 08:17 PM   #252
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
Originally Posted by Zee Biker View Post
And you're on a 2.0/bc 280 motor, correct?
si i am.. i blame the cams for the far right power band and spool up, but top end is pretty much AMAZING. 4600-7,800 feels pretty decent. i havent been past that. when I get tuned on e85, I plan on running 28-29psi. and hopefully rev it to 8,600 rpm.
em1bugeye is offline   Reply With Quote
Old 10-19-2012, 08:28 PM   #253
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
and I got the pics. im going to do that this weekend. thanks man. appreciate it
Old 11-25-2012, 06:27 PM   #254
207STi
Member#: 197062
1998 Swapped Impreza
black
This thread needs to get bumped!
207STi is offline   Reply With Quote
Old 11-29-2012, 12:39 PM   #255
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
I have search and searched and probably searched too much becuase i can not find out if HX-35 can be use on turbo xs rotated kit.
Perrins kit (tuner) cost is quite a bit more, and i now wonder if it would be cheaper to have someone make me a v band dp, v band up w/ewg vband. I have a downpipe that i could ship that could be worked.
Any oppinons or experience welcomed
Old 11-29-2012, 06:53 PM   #256
207STi
Member#: 197062
black
I had an adapter made to be used with my stock up pipe. You can see in the picture above that fitment is pretty awesome. I also plan on having a v-band downpipe made locally. By my count I'm getting away with spending a lot less money than buying a kit minus the turbo. I can post up pictures of the adapter if you would like.
Old 11-30-2012, 09:59 AM   #257
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
That would be stellar, i am/was concerned with the "clocking" of the turbo as far placement is concerned. From what i read in the thread the holset must be positoned +or- 5 degrees to compensate for tilt back and such.
Other than that my main concern was height of the turbo when using the txs kit. So in essence i can use that adaptor and have my spare down pipe reworked into rotated correct.
Tgv deletes :$70
Holset HX35: $600 (est highend)
FPR:aem $100
Clutch: $600
aem meth: $500
new fuel pump: $100
Need:
up pipe adaptor: $ unknown
Rework spare dp to rotated v band: $ unknown
Tims Turbos T3 .63 A/R 4 : $195
Rotated piping (not sure if txs rotated piping will work taking in consideration the of turbo angle?)
Not sure on going speed density on utec, if not bigger maf housing
*Buddy's help to install all above $300
*Tune $300
Have all prerequisite supporting mods including injectors
Old 11-30-2012, 03:42 PM   #258
207STi
Member#: 197062
black
Here are some pictures of the adapter I had made.
Old 12-19-2012, 09:55 PM   #259
railguy
Member#: 53756
I had a hx35 on a 2.7 block, and it made more power than my fp red and built boost about 2k faster, it seems that the big difference between holset and other turbos, is that diesel turbos start building boost much much faster, I remember seeing 5 psi by like 2800 rpms in 4th gear, I dont have any facts to back it up but I promise they spool way better, but they dont give you that hit you in your face until like 20psi..... Its more gradual... I loved it, I will be showing pics of an hx60 on a suby... get ready for pics.
railguy is offline   Reply With Quote
Old 12-20-2012, 01:21 AM   #260
skizzler
Member#: 341116
00 RS
blueish
Hx60, super excited for pics! Assuming the passenger seat was removed for fitment?
skizzler is offline   Reply With Quote
Old 12-20-2012, 09:31 AM   #261
railguy
Member#: 53756
It weighs like 50 lbs... I got it off the bay for 200 bucks, I was going to make some type of big comparison..... but never got around to it... but its 6inch in and 6 inch out...... =)
Old 12-20-2012, 11:33 AM   #262
WhatTurboLag?
Member#: 243992
2006 WRX TR
Good luck spooling it. Diesel trucks have a hard time spooling it.
Anyway does this exist? A billet wheel hx35 but a hx40 compressor cover and a bep vband hot side? I want a big cover but still good spool. And don't need more than the hx35.
WhatTurboLag? is offline   Reply With Quote
Old 12-20-2012, 12:14 PM   #263
3MI Racing
Member#: 200987
ignore...moving right along.
3MI Racing is offline   Reply With Quote
Old 12-20-2012, 12:25 PM   #264
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Eric, that HX60 will probably flow comparably with that S475 (75 or 85, don't recall) that you have.
As for the text from yesterday; I'd certainly hope that a 3.8L EG with an S475 is quicker than a 2.43 with an HX55
As for the spoolgate idea, tell your fab guy to size things correctly. I'd have used a 44-50mm gate for my crossover. The 60 might bleed pressure to quickly and prove to make tuning quite difficult...just a hint from someone that spent two years calibrating similar situations on diesel engines.
Old 12-20-2012, 01:48 PM   #265
albersondh
Member#: 196882
08 WRX
Yes, its an HE351CW. This is a 69lb/min turbo with a 9cm hot side. The compressor is the same as a 7-blade HX40 but the hot side is very close to a HY35. Overall this is comparable to a FP black, but forget about stock location.... The v-band it comes with on the hot side is an odd size (its like a 3.83" v-band) so its best to just weld on a common size, mine is 4".
The alternative to this is to simply build a hybrid HX35/40.....
albersondh is offline   Reply With Quote
Old 12-20-2012, 01:54 PM   #266
WhatTurboLag?
Member#: 243992
2006 WRX TR
Does a hx40 compressor cover fit on a hx35?
Old 12-20-2012, 03:31 PM   #267
railguy
Member#: 53756
That hx60 is almost 40% larger than that s475..... so if that is true... holset is doing it wrong... It must weigh 10 lbs more than the s475.. Ill post pics and you let me know if you think that the hx60 I have is comparable to the bw..... unless holset makes a larger than hx60...Dont hate micah...=)
Old 12-20-2012, 05:30 PM   #268
albersondh
Member#: 196882
08 WRX
Im going off research I did years ago so best to verify. You use the HX35 turbine housing, turbine, and CHRA, with the HX40 compressor and wheel. If Im remembering correctly there is just a bit of work to get the compressor to fit on the CHRA. Loads of info on this procedure just google HX40 hybrid. By the time your done buying two turbos or a mismash of parts to make it work, why not buy the off the shelf version of the hybrid, for the same price as a single HX40?
Old 12-20-2012, 05:32 PM   #269
3MI Racing
Member#: 200987
I just did a quick search and see that the HX60 family is rated up to 0.95 kg/s (about 126 lb/min) and found an S480 (which size was it again?) map peaking at 0.90 kg/s (119 lb/min).
So yeah, the HX60 model, if the largest wheel, could flow about 50 more hp...going by the rule of thumb 10 lb/min = 100 hp.
Old 12-20-2012, 11:13 PM   #270
railguy
Member#: 53756
So.. I just did some measurements and I'm 90%sure it's a hx80 series which flows 196 lbs/min... So it's About 35lbs more than a s510......Can I spool it?
Old 12-20-2012, 11:15 PM   #271
gotsugg
Member#: 204014
02 02 WRB Bugeye
Albertsondh is spot on. The HX40 comp cover and wheel on a HX35 CHRA is the HX40/35 hybrid. Add a HX40 BEP Batmowheel and you have yourself a billet wheel Hybrid. Thats what I am hoping to try next.
Tim's Turbo can convert your HX35 to a 40/35 hybrid pretty inexpensively.... if you already own an hx35. He can also just build a complete unit if you don't already have one. I'm not sure if he has worked with the Batmowheel but I plan to find out.
Old 12-20-2012, 11:19 PM   #272
Juice66
Member#: 340526
2004 WRX STi
HTA86
Dumb.
Juice66 is offline   Reply With Quote
Old 12-20-2012, 11:49 PM   #273
railguy
Member#: 53756
Originally Posted by Juice66 View Post
Dumb.
So do you know how many lbs/min a s598 flows? They spool those babies on supras.. I have or will have a 3.75 liter flat 6 with all the bells and whistles.....
Old 12-21-2012, 11:32 AM   #274
Homemade WRX
Member#: 33782
96 bastard child
Removed by request.
Old 12-21-2012, 12:35 PM   #275
WhatTurboLag?
Member#: 243992
2006 WRX TR
Exactly, diesel guys have a hard time spooling a hx60.
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-23-2010 12:50 AM
Air oil coolers; Who is running them and What Size line? cueballsi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-26-2009 12:37 AM
True twin scroll headers who sells them and are anyone running them tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 03-09-2007 01:57 PM
WRX Koni inserts: Who has them, where did you get them, and who has them in stock? Cosworth Brakes, Steering & Suspension 4 09-13-2002 04:18 PM
Headers/Exhaust/Cams who has them and dyno'd them Silky Normally Aspirated Powertrain 14 04-13-2001 10:07 AM
