Old 12-21-2012, 07:41 AM   #1
CrazyOC949
Member#: 330460
2012 WRX Hatch
Default Transmission whine in 2012 WRX
Okay, I did a lot of searching. I found some posts about this subject. All I'm asking all you Subaru owners is, does your transmission whine in 1st and 2nd gear under acceleration.. I took my car to the Subaru dealer on Wednesday originally for the ECM recall. When I got there I asked the service advisor if he could check you the whine in my transmission. So the service advisor assigned my car to their master tech. My car has 5.6k miles on it currently. That whine has always been present since day 1. I got a call Wednesday at around 4PM. The service rep told me that the tech wanted to do a tear down of the transmission. They also stated that if it was abuse related that they would charge me a tear down of $350. They would pay the other half. If its defective then, I would pay nothing. How do I prove the noise was there since the beginning. I need all your help in being honest and clearing things up. It never occurred to me that they would want to do a tear down. The tech said that most likely they would be replacing the first and second gears. Please help me out. Thanks for all your time.
CrazyOC949 is offline   Reply With Quote
Old 12-21-2012, 07:52 AM   #2
OK Houston
we have an Uncle
if you didnt document this with the service dept when you realized it....it may be a done deal
Old 12-21-2012, 07:53 AM   #3
SpamBot
Member#: 287534
If the whine is the same as when you first got the car, it's probably normal. Tell them not to tear the trans apart.
SpamBot is offline   Reply With Quote
Old 12-21-2012, 08:13 AM   #4
CrazyOC949
Member#: 330460
2012 WRX Hatch
What I'm thinking of doing is asking them to test drive a brand new car with them and see if the tranny whines.
Old 12-21-2012, 08:14 AM   #5
CrazyOC949
Member#: 330460
2012 WRX Hatch
I asked them about that, they said that they would document it that I brought the transmission whine up. The service rep also stated that 90% of cases, it's a warranty defect.
Old 12-21-2012, 08:49 AM   #6
SubaruTech84
Member#: 301472
The trans shouldn't whine on acceleration. It sounds like a bad wear pattern on the gears. There is no good way to prove that there was abuse, it is all up to the tech and the service department on how they go about wording it. If your car is stock and you haven't had any issues with it, you shouldn't have a problem warranting it. I know we would probably warranty it here. I've seen a a few low mile 2011+ STI's come in with cracked ring lands and that was warrantied by us with no problem. Just go out of your way to be extra nice and not combative to the service department and that goes a long way. Hope it all works out for you!
SubaruTech84 is offline   Reply With Quote
Old 12-21-2012, 09:15 AM   #7
CrazyOC949
Member#: 330460
2012 WRX Hatch
Thanks for the reply. The only mod I've done to it is shifter bushings. Both front and rear. but like I said, it has done it since day 1.
Old 12-21-2012, 09:53 AM   #8
imprezafreak3
Member#: 184136
2013 WRX
PBP
someone correct me if im wrong, but you should have taken those aftermarket shifter bushings out and put your stock ones back in before you went into the dealer with a trans issue. Did they say anything about the bushings when they looked at your car?
imprezafreak3 is offline   Reply With Quote
Old 12-21-2012, 10:00 AM   #9
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
whine in 1st and 2nd is normal. ive had it on my 2010 since day one. 80k miles later, it still sounds the same, no better, no worse.
its fine, really.
Old 12-21-2012, 10:03 AM   #10
CrazyOC949
Member#: 330460
2012 WRX Hatch
I'm not going to lie about what I've done to the car. I'm honest. No they didn't say anything.
Old 12-21-2012, 10:08 AM   #11
P-Train
Member#: 279233
2008 WRX, Stage II
I doubt they'll say anything about aftermarket bushings. At least they didnt for me when i went to them. But I ended up with a melted turbo, loose drain/fill plug, and more noise than I originally started with, so who knows. Three different Subaru Dealerships and every tech that touched my car sucked. If they determine your tranny is defective see if they'll replace the whole thing instead of rebuilding it. One less thing to **** up. Hopefully the techs where you are, are a little better.
P-Train is offline   Reply With Quote
Old 12-21-2012, 11:06 AM   #12
CrazyOC949
Member#: 330460
2012 WRX Hatch
It doesn't hurt to ask. I'll give them a call later on today. Thanks for the reply
Old 12-21-2012, 11:23 AM   #13
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Bought my 08 last year with 30000 miles. Went to the dealer for this same reason. They told me it was normal. Look up unabomber manifesto on trannies.
The tranny for the 08+ are from the lgt and have straighter cut gears for 1st and 2nd gear to make them tougher but they whine more.
Go on youtube and search for 08+ wrx 0-60. Check out the vids on how the trannies whine in the videos
Its all normal
fr0st is offline   Reply With Quote
Old 12-21-2012, 11:29 AM   #14
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
Welcome to the world of Subarus where whining, rattling heatshields and interiors, and noisy valvetrains are all sounds you'll just have to learn to live with.
Jessekrs123 is offline   Reply With Quote
Old 12-21-2012, 12:44 PM   #15
CrazyOC949
Member#: 330460
2012 WRX Hatch
Its all normal
That's what I thought. But the tech at the dealer says that it is not normal
Old 12-21-2012, 01:43 PM   #16
RM_2
Member#: 163058
2011 Impreza WRX
SWP Hatchback
http://forums.nasioc.com/forums/show....php?t=2362972
Pretty sure this isn't the first thread I've seen recently. They all whine.
RM_2 is offline   Reply With Quote
Old 12-21-2012, 01:44 PM   #17
SWP n Gold
Member#: 110783
2010 WRX
its fine, really.
Its all normal
These two posts. The whine in first and second is pretty loud on the 2008+ cars. It kind of sounds like a supercharger. In fact, that was the first thing one of my friends said the first time he rode in my car, "Your car sounds like it's supercharged." I would tell them not to tear down the transmission, take a video and post it here. We'll tell you in two seconds if it's normal or not.
SWP n Gold is offline   Reply With Quote
Old 12-21-2012, 01:55 PM   #18
CrazyOC949
Member#: 330460
2012 WRX Hatch
They already started to tear it down yesterday.
Old 12-21-2012, 01:56 PM   #19
kashikoi
Member#: 329897
2012 Base WRX Hatch
My '12 WRX whines too in 1st and 2nd; yup kind of sounds like a supercharger.
I believe changing your bushings to aftermarket ones will also significantly increase this whining sound?
I just have the STI short throw shifter.
kashikoi is offline   Reply With Quote
Old 12-21-2012, 02:00 PM   #20
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Like others said. Post a vid here and take it to another dealer to make sure
Check the oil too...
Some dealers will try to make a fast buck and fix things that arent broken
Old 12-21-2012, 02:12 PM   #21
BalboaT4
Member#: 336635
2013 WRX Limited
I had an 05 LGt and now a 13 wrx and they both whine on acceleration. Just a part of the Subaru charm
BalboaT4 is offline   Reply With Quote
Old 12-21-2012, 03:38 PM   #22
o0Spoony0o
Member#: 276079
Yes, they whine - not unusual at all. Mine's been like that from day 1.
Subaru AWD transmissions tend to be a little whiney under hard acceleration.
o0Spoony0o is offline   Reply With Quote
Old 12-21-2012, 04:14 PM   #23
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
Do keep us updated though, I'm curious what the dealership might tell you regarding gear/synchro/fork wear.
garudatwo is online now   Reply With Quote
Old 12-21-2012, 04:21 PM   #24
CrazyOC949
Member#: 330460
2012 WRX Hatch
I will. According to the dealer they ordered the gears ahead of time. They will come in on Thursday. I think they are just wanting to give work to the tech.
Old 12-21-2012, 05:28 PM   #25
fr0st
Member#: 41618
2008 WRX Hatch
wrb
they will look stupid opening a tranny, changing parts and then putting it back in the car and it still whines...
what then ? there just gonna say it's normal ?
Message Board Statistics All times are GMT -4. The time now is 08:16 AM.
