Old 04-01-2012, 09:09 PM   #576
Wirtz
Member#: 286408
WFC #952
Function:error!
Great Lake Dragway, Wisconsin. Temp was in the 40s.
Stage 2 2005 STi
Invidia V2
HKS Ti-Carbon
Walboro 255
Grimmspeed Boost control solenoid
Conservative 270hp/305ft-lb tune on my winter tires @33psi. I was right lane versus an S2000
Wirtz is offline   Reply With Quote
Old 04-01-2012, 11:12 PM   #577
HonduhPowa
Member#: 269076
2012 Wrx
Ran this in my 06 wrx tr today, very happy with it.
Mid Michigan Motorplex, 60 degrees.
Stock block, Stock heads, Stock clutch, Stock turbo, stock fuel system, 93 octane. (had over half tank of gas)
3" SRS Turboback, K&N typhoon Intake, built transmission with RA gearset, Cobb dynotuned.
HonduhPowa is offline   Reply With Quote
Old 04-08-2012, 01:21 AM   #578
drummerej20
Member#: 148875
07 WRX Sti
IM having trouble putting the pic of my slip up ill mess with it tomorrow.
Either way ran a [email protected] 1.6 60ft
Done with:
Biult motor w/cams
TBE
Intake
Stock VF-43
Car only makes 300whp and 315wtq due to the turbo being way to small for the motor.Cant hold anything more than 12psi after 5k even with 100% duty cycle.
Aiming for 11s on this turbo soon
drummerej20 is offline   Reply With Quote
Old 04-12-2012, 09:23 AM   #579
JayBurd3
Member#: 314702
06 WRX
Default time slip
I ran in bradenton fl. It was 86 and humid with a head wind. I have a 06 wrx. vf39 turbo, intake, exhaust, tune, tmic
JayBurd3 is offline   Reply With Quote
Old 04-13-2012, 10:32 AM   #580
subarupagan
Member#: 315716
2013 Wrx premium
Plasma blue pearl
my very first time ever at the track with my 07 2.5i on a very cold day i don't think i did that bad im the one circled
subarupagan is offline   Reply With Quote
Old 04-19-2012, 09:58 AM   #581
naturalsmooth
Member#: 311067
02 WRX
2.5L, T67 turbo, 4 x 1000cc, Hydra EMS
running C14 until I get the methanol injection working.
My first trip to the drag strip in my WRX. 12.713 @ 111.05MPH just a hair under 1BAR, power meter showed 350HP at that boost level, need to fix the boost controller too.
naturalsmooth is offline   Reply With Quote
Old 04-26-2012, 06:51 PM   #582
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
2005 wrx
Engine mods:
Brand new Sti short block
Wiseco pistons (99.5mm)
Stock 2.0 heads
vf34 turbo
565cc injectors
walbro 255 fp
Perrin turbo inlet
Turbo XS fmic
tuned by TXS 318whp 353wtq
invidia bellmouth dp-catless
invidia n1 street catback
gt-spec EL header
killer-B utlimate oil pickup
sti oil pan
sti dip sti
sti baffle
IAG 38mm ewg
spt sri w/heatshield
halman mbcs
suspension/wheels/brakes:
rota 17x8 boosts
nitto neo gen 225-45-17 tires
bc br+ racing coilovers
kartboy rear endlinks
cobb from 25.4mm sway bar
whiteline front endlinks
whiteline front shifter stay bushings
whiteline rear diff lock down kit
Torque solutions motors and pitch stop
Groupe n trans mount
trans:
kartboy trans bushings (front and rear)
spt wrx short shifter linkage
Kartboy short shifter
shadowmd is offline   Reply With Quote
Old 05-07-2012, 08:57 PM   #583
pearlSubie21
Member#: 185575
2007 wrx 351whp368tq
pearl white
Originally Posted by Speed View Post
Fresh off the press.
Who said you can run 10's with a bolt-on turbo? hehe You just need a lot of supporting mods and push things a little
Mods:
Perrin Equal length Header (wrapped)
Ultimate Racing up pipe with Tial 38mm EWG (Wrapped)
Ultimate Racing 3" cat less downpipe (wrapped)
3.5” Apex’ I GT spec cat back
3" inch inlet SZ (superzilla) 55 Turbo (55lb/min compressor, turbine "fat boy)
3" inch Perrin turbo inlet
Custom intake
PE 850cc injectors
Perrin FMIC
APS hybrid BOV
Walbro fuel pump
Hallman Evolution RX MBC
Perrin crank pulley
Custom grounding wires
TGV Deletes
Hydra EMS
Hydramist
RPS Turbo MAX clutch
Driveshaft.com axle bars
Bridgestone RE01-R 245/45/17
And a bunch of suspension mods.
Car weight 3243 pounds with me in it (190) This was done with C16 race gas @ 29 psi (tappering 27 psi by redline) This turbo is max out! Next mods Electric cut-out and maybe 07 STi gears (3rd and 4th).
i know this is a really old post buthow much whp did you make when you made this run?
pearlSubie21 is offline   Reply With Quote
Old 05-10-2012, 09:31 PM   #584
pearlSubie21
Member#: 185575
pearl white
anyone that has a car with a 20g in the mid to high 11 second range in the quarter mile ?
Old 05-18-2012, 05:42 AM   #585
bim123
Member#: 320520
Default yes
oh yes !!
bim123 is offline   Reply With Quote
Old 06-14-2012, 01:10 PM   #586
RoadKillDMD
Member#: 284792
2011 STI
Blurple
RoadKillDMD is offline   Reply With Quote
Old 06-17-2012, 06:12 PM   #587
06STi Gary
Member#: 250466
I know it's only for 100' but this is what we do on Friday nights. It's great for tree and hole shot practice. Granted, my light was garbage and the rest of the night was all .0--, but this was my fastest time in the 100' so far. I also cut a 2.62 at 47MPH, but the 2.37 at 42MPH was better IMO.
06STi Gary is offline   Reply With Quote
Old 07-09-2012, 02:17 PM   #588
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
R/T - .535
60' - 2.676
330 - 7.799
1/8 - 11.969
MPH - 59.37
1000 - 15.532
1/4 - 18.544
MPH - 74.72
We were equal at 60'.
CarverSnell is offline   Reply With Quote
Old 08-05-2012, 05:09 PM   #589
antmo920
Member#: 255945
2004 Rotated sti
Matte white
antmo920 is offline   Reply With Quote
Old 08-06-2012, 08:13 AM   #590
Freezeweld
Member#: 294643
2011 WRX 5 dr
2011 WRX stock except KB SS. Hadn't really planned on running but my buddy talked me into it. It cooled off to about 86 degrees and humid. 1st time at the track and this was the best of 3 passes. Launch at about 4500.
I went so fast I jumped into the future LOL. Ok the actual date was 8/2/12
Freezeweld is offline   Reply With Quote
Old 08-24-2012, 08:11 AM   #591
Jarzar06
Member#: 268928
2011 WRX HATCH
SWP Stage 2
Went to the track Last night with the WRX
Mods...
Invidia Catted Downpipe
Ultimate racing catback
Tp Stage 2 map for Cobb AP
BC coilovers
Full weight
First pass i was sleeping on the line,
Second thru Forth was pretty consent
And final pass pulled this out of my @$$
all in all was pretty happy with it now its back to easy driving
Jarzar06 is offline   Reply With Quote
Old 08-25-2012, 02:32 AM   #592
yellowjacket757
Member#: 296879
2003 Impreza WRX
Sonic Yellow
Default i feel like im doing something wrong
after looking at the times on here, i suck! lol. first time at the strip with the WRX. Track is the Top Gun Raceway in Fallon, NV. 2003 Cobb Stage 2 WRX (yes a 5 speed). temps were high, ranging from ~90 at the start to mid to low 70's after the sun was down..
2 best runs:
R/T: .548
60': 2.462
1/8: 10.306 (72 mph)
1/4: 15.840 (88.94 mph)
R/T: .358
60': 2.327
1/8: 10.264 (68 mph)
1/4: 15.983 (85.90 mph)
Sucky numbers. but new to drag and trying not to kill my 5 speed yet. (lower rpm launches)
*edit* looked up some more numbers, now im pissed and im wondering if there is issues. i was doing 4k launches. still terrible 60's.. WTF! most stock WRX's run faster than this. im on the ACN 91 Octane stage 2 OTS tune from Cobb. ugh.
yellowjacket757 is offline   Reply With Quote
Old 09-10-2012, 11:21 PM   #593
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
Just hit up Byron Dragway on Sunday only got a few passes in this being the best.
little teaser pic
spoolinej25 is offline   Reply With Quote
Old 10-20-2012, 03:27 AM   #594
07STi TX
Member#: 266749
07 sti
satan's white pearl
Stage 2 tune from Clark turner
fully built bottom end
stock turbo
perrin dp w/cat
invidia catback
sf intake w/box
07STi TX is offline   Reply With Quote
Old 10-22-2012, 11:20 AM   #595
TwiceDubbin
Member#: 290381
Impreza WRX
2011 Stock, untuned WRX - 10k miles, factory wheels, tires, suspension, etc... cat-back removed, spare removed, portion of backseats removed. Driver weight @ approx. 240-250 w/helmet, pants, etc... Some additional details about the track/conditions in the link. They misspelled my last name, but it was close enough
I have all three of my runs from this past Saturday in the scan - the car kept going faster every run with the more time it had to cool down. I really think that if I hadn't gotten rained out I may have been able to turn a 13.0x or even cut into the 12s. If I had gotten that close I would've started leaving more interior parts alongside the staging lanes The first run was immediately as I arrived to the track (tech'd and ran) - all of the rounds are labeled on the slips (Rd 1 - Rd 3).
Link to YouTube video of the fastest run of the day:
TwiceDubbin is offline   Reply With Quote
Old 10-28-2012, 07:01 PM   #596
candamo
Member#: 288732
2003 JDM STi
Today did my first passes at the drag strip.
My car has an ej207 with [email protected]
GS ebcs
Avo 18psi actuator
3" turboback
The runs where done with 93 oct.
Are the times any good?
candamo is offline   Reply With Quote
Old 11-15-2012, 01:24 PM   #597
fast_xr4
Member#: 73335
2005 WRX STi
12.47 @ 107mph. 05 STi
pro tune
el header
open 3" downpipe
spt intake
grimmspeed tgv deletes and spacers
fast_xr4 is offline   Reply With Quote
Old 12-06-2012, 09:16 AM   #598
Jonney Knuckles
Member#: 339061
2013 Impreza WRX 5d
Plasma Blue Pearl
Mods...
BC coilovers
Full weight
The hatch looks great, this is the similar look and mod list I want to go with my '13 wrx...
Jonney Knuckles is offline   Reply With Quote
Old 12-21-2012, 10:13 AM   #599
imidealistic
Member#: 341244
what rpm is your LC set at? not sure what you mean by tranny locking you out.
imidealistic is offline   Reply With Quote
Old 12-21-2012, 08:20 PM   #600
Corifto
Member#: 330652
1993 Legacy TW
First time to the strip in any car, getting a baseline for the '93 Legacy Wagon
Florida, temp was in the 70's.
Best run of the night,
Corifto is offline   Reply With Quote
Happy Birthday cassieswrx your inappropriate pics here car_cursed Rocky Mountains Impreza Club Forum -- RMIC 11 07-11-2008 02:23 AM
Add Your Timeslip Today! Nick Proven Power Bragging 29 07-20-2004 10:06 AM
get your Hatorade pics here! RidinLow Tri-State Area Forum 16 10-16-2002 11:24 PM
Post your leather pics here! Fernely Interior & Exterior Modification 12 10-30-2001 10:15 AM
