Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 12-02-2012, 02:12 PM   #26
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
I usually increase the decay delay and slightly increase the enrich, you want to prevent the initial swing to running lean right after you start the car since that starts the fueling correction oscillations. It usually happens in the <80F range, above that I dont see any issues.
lukeskywrx is offline   Reply With Quote
Old 12-03-2012, 11:04 PM   #27
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Ill definitely give that a try. Just fixing a turbo issue first
Thanks for posting!
OC_Nooby is online now   Reply With Quote
Old 12-12-2012, 02:08 PM   #28
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I guess the rule of thumb for the cranking tables for the ID injectors is taking 30% out and go from there. Still working with my tuner on this since it's pretty bad.
Subian is online now   Reply With Quote
Old 12-21-2012, 09:14 PM   #29
bilt2run
Member#: 134211
just noticed this thread, I have had this same cold start problem for two years now with maf and still with the cobb sd and all sorts of different injectors.. Im getting sick of it now Im ready to switch back to 93 pump
bilt2run is offline   Reply With Quote
Old 12-31-2012, 10:25 AM   #30
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
So your problem is cold starts with E85? Do you have TGV deletes as well? I've spent more than $1k worth of injectors in the past year and im not happy about it.
Old 10-28-2014, 07:37 PM   #31
2JZ
Member#: 291949
Any updates to this thread? Same issue: ID1000s 83mm KStech big maf idle oscillates on cold starts car runs very rich at idle (throws a P0172 - system too rich bank 1)
Tuner told me the 'turbulence' from the 83mm MAF causes the cold start idle and the rich issue requires a retune (scaling for smaller injectors)
2JZ is offline   Reply With Quote
