Old 12-22-2012, 11:03 AM   #1
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
Default cel downstream o2 sensor. slight different
I had a CEL p1036 (I think that's the number). It was downstream o2 sensor. I replaced it, cleared it, and it turns off for a few miles and turns back on.
Not exactly sure where to go from here. What is going on?
lowranger is offline   Reply With Quote
Old 12-23-2012, 12:55 PM   #2
lowranger
Member#: 124370
03 wrx stg 2.34159
Bump. Any help?
Old 12-25-2012, 10:55 AM   #3
lowranger
Member#: 124370
03 wrx stg 2.34159
nuffin?
Old 12-26-2012, 10:07 AM   #4
tuzzio
Member#: 292532
05 STI
Are you catless without a tune to get rid of the codes?
tuzzio is offline   Reply With Quote
Old 12-26-2012, 06:50 PM   #5
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Mods to the car? Tuned? OEM replacement sensor?
Old 12-26-2012, 08:16 PM   #6
OK Houston
we have an Uncle
without the EXACT code.....we just pissin in the (cold) wind
Old 12-28-2012, 08:00 PM   #7
lowranger
Member#: 124370
03 wrx stg 2.34159
P0136. 02 sensor circuit malfunction.
I just didn't know the number. I wasn't near my car. But I did tell you it was the o2.
I've had a protune for years. Oem replacement.
Old 12-28-2012, 08:01 PM   #8
lowranger
Member#: 124370
03 wrx stg 2.34159
I am catless.
Old 12-29-2012, 11:44 AM   #9
Half Crazed
Member#: 321842
2008 STi
Maybe o2 sensor leak, wires shorting, or connector corrosion on the wire clip?
Or, how's your actual AFR's?
Half Crazed is offline   Reply With Quote
Old 12-29-2012, 05:07 PM   #10
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Your car has more then 1 o2 sensor FYI.
Old 12-30-2012, 12:59 AM   #11
lowranger
Member#: 124370
03 wrx stg 2.34159
Yeah pretty aware. Original post mentions
Old 12-30-2012, 09:40 AM   #12
lowranger
Member#: 124370
03 wrx stg 2.34159
Thanks for the response. I was partially thinking it was a leak or just wasn't reading flow correctly. It's at the shop now, so I can't check anything. Just gathering ideas
Message Board Statistics All times are GMT -4. The time now is 04:12 AM.
