#1 |
Member#: 329252
Vehicle:2012 Subaru WRX |
I've driven 2 wrx's (mine, 2012 and a 2013) and in both, 1st and 2nd gear never seem to go in smoothly. It just seems like it's rubbing on things when I put it into gear or something. No "knife through butter" feel.
Now, I've only driven ones with the spt short shifter so I wonder if thats the issue.
#2 |
Member#: 336204
Vehicle:1979 Z28 Camaro Burgundy |
I never had an issue(Only driven the STI 2013 though) Never had a problem getting it into gear/shifting. I have been told(By my friends) that the Subaru Short Shifter isn't the best and going to KartBoy would be the better choice.
Sorry if this wasn't spot on! Just giving my own experience, hopefully it has helped or shed some light on this question. |
#3 |
Member#: 339442
MWSOC
Vehicle:2010 Impreza OBS Obsidean |
shift early.... 1st is just a granny gear... Does that help?
#4 |
Member#: 7164
Vehicle:---> Spoiler alert: Everyone dies at the end. |
Subaru MTs are notchy, but if you can't make a quick and smooth 1-2 upshift, your technique needs work.
#5 |
Member#: 307359
South East
Vehicle:'05 STi Stage II OBP |
On my 05 Sti with a Kartboy SS, second gear is pretty smooth, but 1st is ROUGH unless I am at a stop AND stomping on the clutch like I want it to go through the floor. It's even worse on cold mornings.
#6 |
Member#: 329252
What's funny is my gears are WAY smoother when I first start driving it on a cold morning (maybe cause the fluid is still thick), but it starts becoming rough after driving and everything is warmed up
Wonder if I need a better fluid? Still using the factory fill. |
#7 |
Member#: 171948
Tri-State
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
its notchy when new. mines better thats its older. i have a kartboy ss and bushings. also i changed to subaru extra-s gear oil at 30k in the tranny and rear diff. that made a nice difference in smoothness.
#8 |
Member#: 267996
E. Canada
Vehicle:2011 Wrx Rallye blue |
I got a 11 wrx, and 1st and second gear are smooth. I got the stock shifter with the kartboy bushing.
I can only compare with my old 07 civic and 04 civic. The 07 was harsher than my wrx. |
#9 |
Member#: 324808
E. Canada
Vehicle:2006 IWL Stg2 OBP |
yup. did a tranny oil change recently to motlygear 75w90 and it still has the 1-2 hardness like the oem fluid. so it's just the way it is. even the 08 2.5i MT feels like this. civic shifting is quick because their tranny is lighter and smaller probably. as for short shifters, some had synchro issues, some had more engine noise complaints, or w.e. the case is. you would be btter off using subaru spt shifters if you are under warranty.
#10 |
Member#: 293423
NESIC
Vehicle:2011 WRX Limited 5dr WRB SPT/Stock |
The SPT shifter was an improvement to me, the lifeless clutch and Hill-Assist are my biggest complaints.
#11 |
Member#: 338099
MAIC
Vehicle:2013 WRX Limited 4dr CBS |
i have the SPT shifter as well, and yeah, it kinda sucks. My problem is 5th. Maybe 1 out of 3 times it won't go through the gate at speed ... i have to backout .. pause .. rev .. and then it goes in.
If you're having trouble getting it into first when the car is stopped, the key is to put it into 2nd first, then 1st. Works every time, I had that issue real bad with my RS and then I read that, and problem solved. I believe I saw that on here, the post was something like: "when i drove trucks in the military, they taught us to put it into second first, then first." the worst thing you can do is force it in |
#12 |
Member#: 329252
Is it easy to swap out the spt short shifter for a stock one?
#13 |
Member#: 304299
NESIC
Vehicle:2011 WRX Sedan White |
I have the factory short-shifter, Kartboy front and rear bushings, Cusco transmission mount, and Whiteline transmission member bushings. Definitely more NVH, but it shifts like sex.
#14 | |
Member#: 263954
Vehicle:2013 STi Dark Gray |
![]() ![]() ![]() Flame suit on! |
#15 |
Member#: 258219
South East
Vehicle:2011 WRX Limited WR Blue Pearl |
Sometimes mine shifts smoothly and sometimes it's tough, not sure why. Maybe it's better in warmer weather or after driving it a while? SPT shifter and Cobb bushings, BTW.
#16 |
Member#: 89283
Tri-State
Vehicle:2008 WRX Premium SSM |
#17 |
Member#: 318736
MWSOC
Vehicle:2013 WRX Hatch CBS (BLCK) |
I have the short throw shift also. Its a pain in the ass for 1rst sometimes it feels like its jammed. During winter season this gearbox suxks. Seems to freeze up on me. Eventually i will switch to kartboy amd see how that works out but right now i am hating on my short throw shifter.
Its not what car you drive. Its all the shifter. I cant blame the gearbox can you? |
#18 |
Member#: 331661
Tri-State
Vehicle:2013 Impreza WRX Dark Grey Metallic |
First is tough on cold starts for me but reverse is always tough. I almost always have to go into gear then back into reverse. Is this just what makes a Subaru a Subaru? Lol
#19 |
Member#: 307359
South East
#20 |
Member#: 281656
MAIC
Vehicle:2011 WRX Limited DGM |
I absolutely can blame the gearbox for being slow and notchy. Compared to the civic si and speed3 I've driven, the gearbox in the wrx feels more suited for a truck, and no amount shifters or bushings can change the nature of the transmission, though they do make it more livable. It's part of the character that the car has, and I've learned to like it.
#21 | |
Member#: 324808
E. Canada
#22 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
You can't compare shbaru's MTs to Honda's MTs. That's just not fair.
#23 |
Member#: 281656
MAIC
#24 |
Member#: 324808
E. Canada
still...civic is economy class. subaru is performance class. so compare within it's tier :P
#25 |
Member#: 139955
NESIC
