Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 12-22-2012, 09:26 PM   #1
lj8915
Member#: 329252
2012 Subaru WRX
Default Why are 1st and 2nd gear so terrible in these cars?
I've driven 2 wrx's (mine, 2012 and a 2013) and in both, 1st and 2nd gear never seem to go in smoothly. It just seems like it's rubbing on things when I put it into gear or something. No "knife through butter" feel.
Now, I've only driven ones with the spt short shifter so I wonder if thats the issue.
lj8915 is offline   Reply With Quote
Old 12-22-2012, 09:29 PM   #2
Zaya
Member#: 336204
1979 Z28 Camaro
Burgundy
I never had an issue(Only driven the STI 2013 though) Never had a problem getting it into gear/shifting. I have been told(By my friends) that the Subaru Short Shifter isn't the best and going to KartBoy would be the better choice.
Sorry if this wasn't spot on! Just giving my own experience, hopefully it has helped or shed some light on this question.
Zaya is offline   Reply With Quote
Old 12-22-2012, 09:31 PM   #3
Jonny Up North
Member#: 339442
2010 Impreza OBS
Obsidean
shift early.... 1st is just a granny gear... Does that help?
Jonny Up North is offline   Reply With Quote
Old 12-22-2012, 09:32 PM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Subaru MTs are notchy, but if you can't make a quick and smooth 1-2 upshift, your technique needs work.
Spenk is offline   Reply With Quote
Old 12-22-2012, 09:34 PM   #5
easterbran
Member#: 307359
'05 STi Stage II
On my 05 Sti with a Kartboy SS, second gear is pretty smooth, but 1st is ROUGH unless I am at a stop AND stomping on the clutch like I want it to go through the floor. It's even worse on cold mornings.
easterbran is offline   Reply With Quote
Old 12-22-2012, 09:44 PM   #6
lj8915
Member#: 329252
2012 Subaru WRX
What's funny is my gears are WAY smoother when I first start driving it on a cold morning (maybe cause the fluid is still thick), but it starts becoming rough after driving and everything is warmed up
Wonder if I need a better fluid? Still using the factory fill.
Old 12-22-2012, 09:44 PM   #7
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
its notchy when new. mines better thats its older. i have a kartboy ss and bushings. also i changed to subaru extra-s gear oil at 30k in the tranny and rear diff. that made a nice difference in smoothness.
Old 12-22-2012, 10:01 PM   #8
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I got a 11 wrx, and 1st and second gear are smooth. I got the stock shifter with the kartboy bushing.
I can only compare with my old 07 civic and 04 civic. The 07 was harsher than my wrx.
Syrius78 is offline   Reply With Quote
Old 12-22-2012, 10:11 PM   #9
coalslaw
Member#: 324808
2006 IWL Stg2
yup. did a tranny oil change recently to motlygear 75w90 and it still has the 1-2 hardness like the oem fluid. so it's just the way it is. even the 08 2.5i MT feels like this. civic shifting is quick because their tranny is lighter and smaller probably. as for short shifters, some had synchro issues, some had more engine noise complaints, or w.e. the case is. you would be btter off using subaru spt shifters if you are under warranty.
coalslaw is offline   Reply With Quote
Old 12-22-2012, 10:12 PM   #10
lordgrinz
Member#: 293423
2011 WRX Limited 5dr
WRB SPT/Stock
The SPT shifter was an improvement to me, the lifeless clutch and Hill-Assist are my biggest complaints.
lordgrinz is offline   Reply With Quote
Old 12-22-2012, 10:12 PM   #11
jim_newton
Member#: 338099
2013 WRX 4dr
rattle trap
i have the SPT shifter as well, and yeah, it kinda sucks. My problem is 5th. Maybe 1 out of 3 times it won't go through the gate at speed ... i have to backout .. pause .. rev .. and then it goes in.
If you're having trouble getting it into first when the car is stopped, the key is to put it into 2nd first, then 1st. Works every time, I had that issue real bad with my RS and then I read that, and problem solved. I believe I saw that on here, the post was something like: "when i drove trucks in the military, they taught us to put it into second first, then first." the worst thing you can do is force it in
jim_newton is offline   Reply With Quote
Old 12-22-2012, 10:12 PM   #12
lj8915
Member#: 329252
2012 Subaru WRX
Is it easy to swap out the spt short shifter for a stock one?
Old 12-22-2012, 10:14 PM   #13
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
I have the factory short-shifter, Kartboy front and rear bushings, Cusco transmission mount, and Whiteline transmission member bushings. Definitely more NVH, but it shifts like sex.
Dale2011WRX is offline   Reply With Quote
Old 12-22-2012, 10:28 PM   #14
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Because it's not an STi?
Flame suit on!
Napalm3nema is offline   Reply With Quote
Old 12-22-2012, 10:34 PM   #15
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
Sometimes mine shifts smoothly and sometimes it's tough, not sure why. Maybe it's better in warmer weather or after driving it a while? SPT shifter and Cobb bushings, BTW.
shamrocker is offline   Reply With Quote
Old 12-23-2012, 12:04 AM   #16
curiousfish
Member#: 89283
2008 WRX Premium
SSM
^^ this. If youre accustomed to VW or Toyota or Honda MT, then Subaru MT will require some practice to get the shifts nice and smooth.
curiousfish is offline   Reply With Quote
Old 12-23-2012, 01:07 AM   #17
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
I have the short throw shift also. Its a pain in the ass for 1rst sometimes it feels like its jammed. During winter season this gearbox suxks. Seems to freeze up on me. Eventually i will switch to kartboy amd see how that works out but right now i am hating on my short throw shifter.
Its not what car you drive. Its all the shifter. I cant blame the gearbox can you?
JAMM0N is offline   Reply With Quote
Old 12-23-2012, 02:09 AM   #18
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
First is tough on cold starts for me but reverse is always tough. I almost always have to go into gear then back into reverse. Is this just what makes a Subaru a Subaru? Lol
13_DGM_Hatch is offline   Reply With Quote
Old 12-23-2012, 03:16 AM   #19
easterbran
Member#: 307359
'05 STi Stage II
Yeah, no synchro on the reverse iirc
Old 12-23-2012, 10:29 AM   #20
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I absolutely can blame the gearbox for being slow and notchy. Compared to the civic si and speed3 I've driven, the gearbox in the wrx feels more suited for a truck, and no amount shifters or bushings can change the nature of the transmission, though they do make it more livable. It's part of the character that the car has, and I've learned to like it.
ResidentR is offline   Reply With Quote
Old 12-23-2012, 10:59 AM   #21
coalslaw
Member#: 324808
2006 IWL Stg2
you should try the new dodge challenger's gears. holy ****...it feels super tough and weird positioned.
Old 12-23-2012, 11:14 AM   #22
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You can't compare shbaru's MTs to Honda's MTs. That's just not fair.
Old 12-23-2012, 11:47 AM   #23
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I can and will, as these cars are both directed at the same market segment and I looked at both before purchasing my wrx. They are vastly different in feel though.
Old 12-23-2012, 12:02 PM   #24
coalslaw
Member#: 324808
2006 IWL Stg2
still...civic is economy class. subaru is performance class. so compare within it's tier :P
Old 12-23-2012, 12:05 PM   #25
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Drink more of that KoolAid.
Your Subaru is an econobox just like the Civic is.
